See http://hudson.opengeo.org/hudson/job/geoserver-trunk/895/changes
Changes:
[arneke] Adding gwc dependency to web2-app, thanks aaime
[...truncated 404 lines...]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:compile]
[INFO] Compiling 216 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:ows:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:testCompile]
[INFO] Compiling 40 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.552 sec
Running org.geoserver.catalog.impl.InfoObjectProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.974 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.219 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
30 Mar 05:38:21 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Mon Mar 30 05:38:21 EDT 2009]; root of context hierarchy
30 Mar 05:38:21 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
30 Mar 05:38:21 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
30 Mar 05:38:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8730data
30 Mar 05:38:21 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
30 Mar 05:38:21 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
30 Mar 05:38:21 INFO [geoserver.catalog] - Default namespace: 'gs'
30 Mar 05:38:21 INFO [geoserver.catalog] - Loaded style 'Default'
30 Mar 05:38:21 INFO [geoserver.catalog] - Loaded style 'Buildings'
30 Mar 05:38:21 INFO [geoserver.catalog] - Processed data store 'cite', enabled
30 Mar 05:38:21 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
30 Mar 05:38:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
30 Mar 05:38:21 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Mon Mar 30 05:38:21 EDT 2009]; root of context hierarchy
30 Mar 05:38:21 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Mar 30, 2009 5:38:21 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Running org.geoserver.config.util.XStreamPersisterTest
30 Mar 05:38:21 INFO [org.geoserver] - Loaded store 'bar', disabled
30 Mar 05:38:21 INFO [org.geoserver] - Loading workspace 'foo'
30 Mar 05:38:21 INFO [org.geoserver] - Loading namespace 'acme'
30 Mar 05:38:21 INFO [org.geoserver] - Loaded store 'foo', disabled
Mar 30, 2009 5:38:21 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
30 Mar 05:38:21 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.111 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.163 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
30 Mar 05:38:21 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
30 Mar 05:38:21 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
30 Mar 05:38:21 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
30 Mar 05:38:21 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
30 Mar 05:38:21 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
30 Mar 05:38:21 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
30 Mar 05:38:21 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
30 Mar 05:38:21 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
30 Mar 05:38:21 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
30 Mar 05:38:21 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
30 Mar 05:38:21 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
30 Mar 05:38:21 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.106 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.281 sec
Running org.geoserver.security.SecureCatalogImplTest
30 Mar 05:38:22 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
30 Mar 05:38:22 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
30 Mar 05:38:22 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
30 Mar 05:38:22 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
30 Mar 05:38:22 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
30 Mar 05:38:22 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
30 Mar 05:38:22 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
30 Mar 05:38:22 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
30 Mar 05:38:22 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
30 Mar 05:38:22 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
30 Mar 05:38:22 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.211 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.154 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.064 sec
Running org.geoserver.catalog.SchemaMappingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.156 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.042 sec
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
30 Mar 05:38:24 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
30 Mar 05:38:24 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
30 Mar 05:38:24 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
30 Mar 05:38:24 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
30 Mar 05:38:24 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.679 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.335 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Results :
Tests run: 174, Failures: 0, Errors: 0, Skipped: 0
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
opengeo (http://repo.opengeo.org/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
geotools (http://maven.geotools.fr/repository/)
Path to dependency:
1) org.geoserver:main:jar:2.0-SNAPSHOT
2) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
3) org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi-pending/2.3-SNAPSHOT/geoapi-pending-2.3-SNAPSHOT.jar
[INFO] Total time: 59 seconds
[INFO] Finished at: Mon Mar 30 05:38:25 EDT 2009
[INFO] Final Memory: 31M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
