[Geoserver-devel] Build failed in Hudson: geoserver-trunk #91
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/91/changes
[...truncated 344 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 34 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Validation Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target
[INFO] Compiling 6 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Feature Service Model
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target
[INFO] Compiling 80 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Feature Service Module
[INFO] artifact org.geotools.maven:gt2-xmlcodegen: checking for updates from central
[INFO] snapshot org.geotools.maven:gt2-xmlcodegen:2.5-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-xmlcodegen:2.5-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.geotools.maven:gt2-maven:2.5-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-maven:2.5-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.geotools.maven:gt2-build:2.5-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-build:2.5-SNAPSHOT: checking for updates from refractions-plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target
[INFO] snapshot org.geotools:gt2-xml-gml3:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-filter:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 160 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
Failure executing javac, but could not parse the error:
An exception has occurred in the compiler (1.5.0_14). Please file a bug at the Java Developer Connection (http://java.sun.com/webapps/bugreport) after checking the Bug Parade for duplicates. Include your program and the following diagnostic in your report. Thank you.
java.lang.NullPointerException
  at com.sun.tools.javac.jvm.ClassReader.fillIn(ClassReader.java:1583)
  at com.sun.tools.javac.jvm.ClassReader.complete(ClassReader.java:1535)
  at com.sun.tools.javac.code.Symbol.complete(Symbol.java:355)
  at com.sun.tools.javac.code.Symbol$ClassSymbol.complete(Symbol.java:612)
  at com.sun.tools.javac.jvm.ClassReader.loadClass(ClassReader.java:1635)
  at com.sun.tools.javac.comp.Resolve.loadClass(Resolve.java:815)
  at com.sun.tools.javac.comp.Resolve.findIdentInPackage(Resolve.java:984)
  at com.sun.tools.javac.comp.Attr.selectSym(Attr.java:1801)
  at com.sun.tools.javac.comp.Attr.visitSelect(Attr.java:1724)
  at com.sun.tools.javac.tree.Tree$Select.accept(Tree.java:987)
  at com.sun.tools.javac.comp.Attr.attribTree(Attr.java:275)
  at com.sun.tools.javac.comp.Attr.attribType(Attr.java:303)
  at com.sun.tools.javac.comp.MemberEnter.attribImportType(MemberEnter.java:656)
  at com.sun.tools.javac.comp.MemberEnter.visitImport(MemberEnter.java:540)
  at com.sun.tools.javac.tree.Tree$Import.accept(Tree.java:397)
  at com.sun.tools.javac.comp.MemberEnter.memberEnter(MemberEnter.java:383)
  at com.sun.tools.javac.comp.MemberEnter.memberEnter(MemberEnter.java:395)
  at com.sun.tools.javac.comp.MemberEnter.visitTopLevel(MemberEnter.java:507)
  at com.sun.tools.javac.tree.Tree$TopLevel.accept(Tree.java:382)
  at com.sun.tools.javac.comp.MemberEnter.complete(MemberEnter.java:778)
  at com.sun.tools.javac.comp.Enter.complete(Enter.java:455)
  at com.sun.tools.javac.comp.Enter.main(Enter.java:433)
  at com.sun.tools.javac.main.JavaCompiler.compile(JavaCompiler.java:404)
  at com.sun.tools.javac.main.Main.compile(Main.java:592)
  at com.sun.tools.javac.main.Main.compile(Main.java:544)
  at com.sun.tools.javac.Main.compile(Main.java:85)
  at org.codehaus.plexus.compiler.javac.JavacCompiler.compileInProcess(JavacCompiler.java:420)
  at org.codehaus.plexus.compiler.javac.JavacCompiler.compile(JavacCompiler.java:141)
  at org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:493)
  at org.apache.maven.plugin.CompilerMojo.execute(CompilerMojo.java:114)
  at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:443)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:539)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:480)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:459)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:311)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:278)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:143)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:334)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:125)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:280)
  at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
  at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
  at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
  at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO] Total time: 42 seconds
[INFO] Finished at: Mon Jan 14 08:55:16 EST 2008
[INFO] Final Memory: 28M/52M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/92/changes
