See http://hudson.opengeo.org/hudson/job/geoserver-trunk/917/changes
Changes:
[tenzochris] First pass at updating GS2 UI to match acochran's comp - bringing things more in line with our GeoServer branding in other contexts
[jdeolive] renaming geoserver directory to src
started
Updating https://svn.codehaus.org/geoserver/trunk/src
U community/web2/core/src/main/java/org/geoserver/web/css/geoserver.css
U community/web2/core/src/main/java/org/geoserver/web/GeoServerBasePage.html
AU community/web2/core/src/main/java/org/geoserver/web/favicon.ico
U community/web2/core/src/main/java/org/geoserver/web/img/logo.png
AU community/web2/core/src/main/java/org/geoserver/web/img/page-bg.png
AU community/web2/core/src/main/java/org/geoserver/web/img/main-bg.png
AU community/web2/core/src/main/java/org/geoserver/web/img/main-wrap-bg.png
AU community/web2/core/src/main/java/org/geoserver/web/img/transparent.gif
AU community/web2/core/src/main/java/org/geoserver/web/img/page-header-bg.png
A community/web2/core/src/main/java/org/geoserver/web/js
A community/web2/core/src/main/java/org/geoserver/web/js/jquery.inline-info.js
A community/web2/core/src/main/java/org/geoserver/web/js/jquery-1.2.6.min.js
Fetching 'http://svn.osgeo.org/geotools/trunk/modules/unsupported/app-schema/app-schema/src/test/resources/test-data’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/app-schema/app-schema-test/src/test/resources/test-data’
At revision 32734
Fetching 'http://svn.opengeo.org/geoext/apps/styler2/trunk’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app’
Fetching 'http://svn.opengeo.org/geoext/core/trunk’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/core’
At revision 1330
Fetching 'http://svn.opengeo.org/geoext/ext/2.2’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/ext’
At revision 1330
Fetching 'http://svn.openlayers.org/sandbox/topp/styler’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/openlayers’
At revision 9179
Fetching 'http://svn.opengeo.org/who/ems/trunk/lib’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/tree’
At revision 115
Fetching 'http://svn.opengeo.org/geoext/ux’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/ux’
At revision 1330
At revision 1330
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal’
At revision 11963
Fetching 'https://svn.codehaus.org/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/css’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/test/java/org/geoserver/wicket/test/css’
U community/web2/app/src/test/java/org/geoserver/wicket/test/css/geoserver.css
At revision 11963
Fetching 'https://svn.codehaus.org/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/img’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/test/java/org/geoserver/wicket/test/img’
U community/web2/app/src/test/java/org/geoserver/wicket/test/img/logo.png
AU community/web2/app/src/test/java/org/geoserver/wicket/test/img/page-bg.png
AU community/web2/app/src/test/java/org/geoserver/wicket/test/img/main-bg.png
AU community/web2/app/src/test/java/org/geoserver/wicket/test/img/main-wrap-bg.png
AU community/web2/app/src/test/java/org/geoserver/wicket/test/img/transparent.gif
AU community/web2/app/src/test/java/org/geoserver/wicket/test/img/page-header-bg.png
At revision 11963
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/legacy/web/minimal’
At revision 11963
At revision 11963
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/core/trunk at geoserver/externals/core
org.tmatesoft.svn.core.SVNException: svn: 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/externals’ is not a working copy
svn: Cannot read from to 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/externals/.svn/format’ : path refers to directory or read access is denied
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:49)
at org.tmatesoft.svn.core.internal.wc.admin.SVNAdminAreaFactory.open(SVNAdminAreaFactory.java:132)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:344)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:261)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.probeOpen(SVNWCAccess.java:279)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:1881)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:1818)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:2172)
at hudson.scm.SubversionSCM$BuildRevisionMapTask.invoke(SubversionSCM.java:631)
at hudson.scm.SubversionSCM$BuildRevisionMapTask.invoke(SubversionSCM.java:601)
at hudson.FilePath.act(FilePath.java:301)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:308)
at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
at hudson.model.Run.run(Run.java:659)
at hudson.model.Build.run(Build.java:101)
at hudson.model.ResourceController.execute(ResourceController.java:70)
at hudson.model.Executor.run(Executor.java:65)
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/ext/2.2 at geoserver/externals/ext
ERROR: Failed to parse svn info for external http://svn.openlayers.org/sandbox/topp/styler at geoserver/externals/openlayers
ERROR: Failed to parse svn info for external http://svn.opengeo.org/who/ems/trunk/lib at geoserver/externals/tree
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/ux at geoserver/externals/ux
no change for http://svn.osgeo.org/geotools/trunk/modules/unsupported/app-schema/app-schema/src/test/resources/test-data since the previous build
no change for http://svn.opengeo.org/geoext/apps/styler2/trunk since the previous build
no revision recorded for null in the previous build
no change for http://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
[geoserver] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,web2 clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoWebCache (GWC) Module
[INFO] Community Space
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] WFS UI Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] ArcSDE DataStore Extension
[INFO] H2 DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] Versioned Web Feature Service Module
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Building GeoServer
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt-api:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-referencing:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-metadata:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:geoapi:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:parent:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:geoapi-pending:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-main:2.6-SNAPSHOT: checking for updates from opengeo
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.opengis:geoapi:jar:2.3-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
opengeo (http://repo.opengeo.org/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
geotools (http://maven.geotools.fr/repository/)
Path to dependency:
1) org.geoserver:geoserver:pom:2.0-SNAPSHOT
2) org.geotools:gt-api:jar:2.6-SNAPSHOT
3) org.geotools:gt-referencing:jar:2.6-SNAPSHOT
4) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
5) org.opengis:geoapi:jar:2.3-SNAPSHOT
Caused by I/O exception: Connection timed out
[INFO] Total time: 3 minutes 16 seconds
[INFO] Finished at: Fri Apr 03 13:41:06 EDT 2009
[INFO] Final Memory: 18M/32M
Failed to send e-mail to tenzochris because no e-mail address is known, and no default e-mail domain is configured
