[Geoserver-devel] Build failed in Hudson: geoserver-trunk #948
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/948/changes
Changes:
[aaime] Use a palette for supported formats
[aaime] Suppress serialization warnings
[aaime] A simple, no nonsense chiocerenderer that does not interact poorly with palette
[aaime] A model to bind live collections
[aaime] http://jira.codehaus.org/browse/GEOS-2840, Catalog event subsystem should protect itself from listeners throwing exceptions
[...truncated 404 lines...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.255 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.06 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.042 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:compile]
[INFO] Compiling 220 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:ows:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:testCompile]
[INFO] Compiling 40 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.617 sec
Running org.geoserver.catalog.impl.InfoObjectProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.969 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.222 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.241 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
09 Apr 14:38:30 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Apr 09 14:38:30 EDT 2009]; root of context hierarchy
09 Apr 14:38:30 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
09 Apr 14:38:30 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
09 Apr 14:38:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock478data
09 Apr 14:38:30 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
09 Apr 14:38:30 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
09 Apr 14:38:30 INFO [geoserver.catalog] - Default namespace: 'gs'
09 Apr 14:38:30 INFO [geoserver.catalog] - Loaded style 'Default'
09 Apr 14:38:30 INFO [geoserver.catalog] - Loaded style 'Buildings'
09 Apr 14:38:30 INFO [geoserver.catalog] - Processed data store 'cite', enabled
09 Apr 14:38:30 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
09 Apr 14:38:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
09 Apr 14:38:30 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Apr 09 14:38:30 EDT 2009]; root of context hierarchy
09 Apr 14:38:30 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Apr 9, 2009 2:38:30 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.config.util.XStreamPersisterTest
09 Apr 14:38:30 INFO [org.geoserver] - Loaded store 'bar', disabled
Apr 9, 2009 2:38:30 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
09 Apr 14:38:30 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.109 sec <<< FAILURE!
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.159 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
09 Apr 14:38:30 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
09 Apr 14:38:30 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
09 Apr 14:38:30 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
09 Apr 14:38:30 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
09 Apr 14:38:30 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
09 Apr 14:38:30 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
09 Apr 14:38:30 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
09 Apr 14:38:30 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
09 Apr 14:38:30 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
09 Apr 14:38:30 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
09 Apr 14:38:30 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
09 Apr 14:38:30 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
09 Apr 14:38:30 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
09 Apr 14:38:30 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
09 Apr 14:38:30 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
09 Apr 14:38:30 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
09 Apr 14:38:30 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
09 Apr 14:38:30 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.1 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.241 sec
Running org.geoserver.security.SecureCatalogImplTest
09 Apr 14:38:31 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
09 Apr 14:38:31 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
09 Apr 14:38:31 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
09 Apr 14:38:31 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
09 Apr 14:38:31 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
09 Apr 14:38:31 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
09 Apr 14:38:31 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
09 Apr 14:38:31 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
09 Apr 14:38:31 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
09 Apr 14:38:31 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
09 Apr 14:38:31 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
09 Apr 14:38:31 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
09 Apr 14:38:31 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
09 Apr 14:38:31 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
09 Apr 14:38:31 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
09 Apr 14:38:31 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
09 Apr 14:38:31 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.294 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.449 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.088 sec
Running org.geoserver.catalog.SchemaMappingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.227 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.catalog.ResourcePoolTest
09 Apr 14:38:33 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
09 Apr 14:38:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
09 Apr 14:38:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
09 Apr 14:38:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
09 Apr 14:38:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.362 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.676 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.386 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Results :
Tests in error:
  testCatalog(org.geoserver.config.util.XStreamPersisterTest)
Tests run: 175, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 4 seconds
[INFO] Finished at: Thu Apr 09 14:38:35 EDT 2009
[INFO] Final Memory: 31M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/949/changes
Changes:
[aaime] Use the live collection model instead of a custom one
[aaime] Adding a palette and dropdown for interpolations as well
[jdeolive] changed properties wrapped in modification proxies, added flag to tell if proxy is dirty
[...truncated 403 lines...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.23 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.628 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.9 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.262 sec
09 Apr 15:38:11 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Apr 09 15:38:11 EDT 2009]; root of context hierarchy
09 Apr 15:38:11 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
09 Apr 15:38:11 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
09 Apr 15:38:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock53371data
09 Apr 15:38:11 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
09 Apr 15:38:11 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
09 Apr 15:38:11 INFO [geoserver.catalog] - Default namespace: 'gs'
09 Apr 15:38:11 INFO [geoserver.catalog] - Loaded style 'Default'
09 Apr 15:38:11 INFO [geoserver.catalog] - Loaded style 'Buildings'
09 Apr 15:38:11 INFO [geoserver.catalog] - Processed data store 'cite', enabled
09 Apr 15:38:11 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
09 Apr 15:38:11 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
09 Apr 15:38:11 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Apr 09 15:38:11 EDT 2009]; root of context hierarchy
09 Apr 15:38:11 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.08 sec
Apr 9, 2009 3:38:11 PM org.geoserver.platform.GeoServerExtensions checkContext
09 Apr 15:38:11 INFO [org.geoserver] - Loaded store 'bar', disabled
Apr 9, 2009 3:38:11 PM java.util.prefs.FileSystemPreferences$7 run
09 Apr 15:38:11 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.175 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Apr 9, 2009 3:38:12 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.258 sec
09 Apr 15:38:12 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
09 Apr 15:38:12 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
09 Apr 15:38:12 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
09 Apr 15:38:12 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
09 Apr 15:38:12 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
09 Apr 15:38:12 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
09 Apr 15:38:12 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
09 Apr 15:38:12 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
09 Apr 15:38:12 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
09 Apr 15:38:12 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
09 Apr 15:38:12 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
09 Apr 15:38:12 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
09 Apr 15:38:12 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
09 Apr 15:38:12 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
09 Apr 15:38:12 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
09 Apr 15:38:12 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
09 Apr 15:38:12 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
09 Apr 15:38:12 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.113 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.128 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.348 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.155 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.059 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.823 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
09 Apr 15:38:16 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
09 Apr 15:38:16 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
09 Apr 15:38:16 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
09 Apr 15:38:16 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
09 Apr 15:38:16 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.455 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.713 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.346 sec
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Results :
Tests in error:
[INFO] Total time: 53 seconds
[INFO] Finished at: Thu Apr 09 15:38:17 EDT 2009
[INFO] Final Memory: 32M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/950/changes
Changes:
[arneke] First pass at improved i18n for WMS,WFS and WFS modules
[...truncated 418 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.586 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.281 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.245 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
10 Apr 10:38:38 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 10:38:38 EDT 2009]; root of context hierarchy
10 Apr 10:38:38 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
10 Apr 10:38:38 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
10 Apr 10:38:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock45011data
10 Apr 10:38:38 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Apr 10:38:38 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Apr 10:38:38 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Apr 10:38:38 INFO [geoserver.catalog] - Loaded style 'Default'
10 Apr 10:38:38 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Apr 10:38:38 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Apr 10:38:38 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Apr 10:38:38 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Apr 10:38:38 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 10:38:38 EDT 2009]; root of context hierarchy
10 Apr 10:38:38 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Apr 10, 2009 10:38:38 AM org.geoserver.platform.GeoServerExtensions checkContext
10 Apr 10:38:38 INFO [org.geoserver] - Loaded store 'bar', disabled
Apr 10, 2009 10:38:38 AM java.util.prefs.FileSystemPreferences$7 run
10 Apr 10:38:38 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.16 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.146 sec
10 Apr 10:38:38 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 10:38:38 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 10:38:38 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 10:38:38 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 10:38:38 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 10:38:38 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 10:38:38 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 10:38:38 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 10:38:38 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 10:38:38 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 10:38:38 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 10:38:38 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 10:38:38 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 10:38:38 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 10:38:38 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 10:38:38 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 10:38:38 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
10 Apr 10:38:38 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.129 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.349 sec
10 Apr 10:38:39 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 10:38:39 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 10:38:39 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 10:38:39 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 10:38:39 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 10:38:39 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 10:38:39 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 10:38:39 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 10:38:39 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 10:38:39 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 10:38:39 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 10:38:39 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 10:38:39 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 10:38:39 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 10:38:39 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 10:38:39 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 10:38:39 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.083 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.25 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.254 sec
10 Apr 10:38:41 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
10 Apr 10:38:41 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 10:38:41 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
10 Apr 10:38:41 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 10:38:41 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.817 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.426 sec
Results :
Tests in error:
[INFO] Total time: 1 minute 12 seconds
[INFO] Finished at: Fri Apr 10 10:38:44 EDT 2009
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/951/changes
Changes:
[aaime] GEOS-2575 Tone down client stream aborted exceptions in kml/kmz map producers
[...truncated 400 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.052 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.849 sec
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.315 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.256 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.26 sec
10 Apr 11:38:00 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 11:38:00 EDT 2009]; root of context hierarchy
10 Apr 11:38:00 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
10 Apr 11:38:00 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
10 Apr 11:38:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4553data
10 Apr 11:38:00 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Apr 11:38:00 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Apr 11:38:00 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Apr 11:38:00 INFO [geoserver.catalog] - Loaded style 'Default'
10 Apr 11:38:00 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Apr 11:38:00 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Apr 11:38:00 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Apr 11:38:00 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Apr 11:38:00 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 11:38:00 EDT 2009]; root of context hierarchy
10 Apr 11:38:00 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.077 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Apr 10, 2009 11:38:00 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
10 Apr 11:38:00 INFO [org.geoserver] - Loaded store 'bar', disabled
Apr 10, 2009 11:38:00 AM java.util.prefs.FileSystemPreferences$7 run
10 Apr 11:38:00 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.126 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.173 sec
10 Apr 11:38:00 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 11:38:00 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 11:38:00 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 11:38:00 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 11:38:00 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 11:38:00 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 11:38:00 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 11:38:00 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 11:38:00 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 11:38:00 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 11:38:00 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 11:38:00 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 11:38:00 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 11:38:00 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 11:38:00 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 11:38:00 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 11:38:00 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
10 Apr 11:38:00 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.107 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.295 sec
10 Apr 11:38:01 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 11:38:01 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 11:38:01 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 11:38:01 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 11:38:01 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 11:38:01 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 11:38:01 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 11:38:01 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 11:38:01 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 11:38:01 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 11:38:01 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 11:38:01 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 11:38:01 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 11:38:01 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 11:38:01 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 11:38:01 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 11:38:01 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.273 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.246 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.213 sec
10 Apr 11:38:03 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
10 Apr 11:38:03 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 11:38:03 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
10 Apr 11:38:03 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 11:38:03 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.436 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.707 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.496 sec
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Results :
Tests in error:
[INFO] Total time: 54 seconds
[INFO] Finished at: Fri Apr 10 11:38:05 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/952/changes
Changes:
[aaime] GEOS-2629 Try to provide better error messages when the capabilities document fails due to a misconfigured layer
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.057 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.556 sec
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.017 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
10 Apr 12:38:23 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 12:38:23 EDT 2009]; root of context hierarchy
10 Apr 12:38:23 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
10 Apr 12:38:23 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
10 Apr 12:38:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock2793data
10 Apr 12:38:23 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Apr 12:38:23 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Apr 12:38:23 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Apr 12:38:23 INFO [geoserver.catalog] - Loaded style 'Default'
10 Apr 12:38:23 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Apr 12:38:23 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Apr 12:38:23 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Apr 12:38:23 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Apr 12:38:23 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 12:38:23 EDT 2009]; root of context hierarchy
10 Apr 12:38:23 INFO [geoserver.catalog] - Disposing datastore 'cite'
Apr 10, 2009 12:38:23 PM org.geoserver.platform.GeoServerExtensions checkContext
10 Apr 12:38:24 INFO [org.geoserver] - Loaded store 'bar', disabled
Apr 10, 2009 12:38:24 PM java.util.prefs.FileSystemPreferences$7 run
10 Apr 12:38:24 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.107 sec <<< FAILURE!
Apr 10, 2009 12:38:24 PM org.geoserver.platform.GeoServerExtensions checkContext
10 Apr 12:38:24 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 12:38:24 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 12:38:24 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 12:38:24 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 12:38:24 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 12:38:24 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 12:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 12:38:24 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 12:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 12:38:24 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 12:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 12:38:24 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 12:38:24 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 12:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 12:38:24 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 12:38:24 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 12:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
10 Apr 12:38:24 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.098 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.251 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.19 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.08 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.17 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.253 sec
10 Apr 12:38:26 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
10 Apr 12:38:26 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 12:38:26 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
10 Apr 12:38:26 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 12:38:26 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.674 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.385 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Results :
Tests in error:
[INFO] Finished at: Fri Apr 10 12:38:27 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/953/changes
Changes:
[groldan] GEOS-2850
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.293 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: -0.005 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.605 sec
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.164 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.269 sec
10 Apr 14:38:57 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 14:38:57 EDT 2009]; root of context hierarchy
10 Apr 14:38:57 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
10 Apr 14:38:57 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
10 Apr 14:38:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock58227data
10 Apr 14:38:57 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Apr 14:38:57 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Apr 14:38:57 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Apr 14:38:57 INFO [geoserver.catalog] - Loaded style 'Default'
10 Apr 14:38:57 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Apr 14:38:57 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Apr 14:38:57 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Apr 14:38:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Apr 14:38:57 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Apr 10 14:38:57 EDT 2009]; root of context hierarchy
10 Apr 14:38:57 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.081 sec
Apr 10, 2009 2:38:57 PM org.geoserver.platform.GeoServerExtensions checkContext
10 Apr 14:38:57 INFO [org.geoserver] - Loaded store 'bar', disabled
Apr 10, 2009 2:38:57 PM java.util.prefs.FileSystemPreferences$7 run
10 Apr 14:38:57 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.12 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.169 sec
10 Apr 14:38:57 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 14:38:57 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 14:38:57 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 14:38:57 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 14:38:57 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 14:38:57 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 14:38:57 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 14:38:57 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 14:38:57 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 14:38:57 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 14:38:57 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 14:38:57 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 14:38:57 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 14:38:57 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 14:38:57 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 14:38:57 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 14:38:57 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
10 Apr 14:38:57 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.158 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
10 Apr 14:38:58 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
10 Apr 14:38:58 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
10 Apr 14:38:58 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
10 Apr 14:38:58 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
10 Apr 14:38:58 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
10 Apr 14:38:58 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
10 Apr 14:38:58 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
10 Apr 14:38:58 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
10 Apr 14:38:58 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
10 Apr 14:38:58 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
10 Apr 14:38:58 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
10 Apr 14:38:58 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
10 Apr 14:38:58 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
10 Apr 14:38:58 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
10 Apr 14:38:58 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
10 Apr 14:38:58 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
10 Apr 14:38:58 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.267 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.282 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.042 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
10 Apr 14:39:00 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
10 Apr 14:39:00 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 14:39:00 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
10 Apr 14:39:00 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
10 Apr 14:39:00 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.894 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.373 sec
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Results :
Tests in error:
[INFO] Total time: 1 minute 17 seconds
[INFO] Finished at: Fri Apr 10 14:39:01 EDT 2009
Build is broken since yesterday with the following test failure, anyone knows what is it about?
Tests in error:
Gabriel
Changes:
[groldan] GEOS-2850
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 220 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes [INFO] [resources:testResources]
[INFO] Compiling 40 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes [INFO] [surefire:test]
T E S T S
10 Apr 14:38:57 ERROR [geoserver.global] - ----------------------------------
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock58227data ----------------------------------
Results :
Tests in error: testCatalog(org.geoserver.config.util.XStreamPersisterTest)
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
The commit logs don't really tell the story, and Andrea didn't find it, so we're still hoping it's obvious to Justin :slight_smile:
-Arne
Gabriel Roldan wrote:
Tests in error:
Gabriel
Gabriel Roldan ha scritto:
Tests in error:
I already looked into it but I don't recognize the build
error, and it's happening while serializing a whole catalog,
not sure just one object soo... some step by step debugging
is in order. I was hoping to see jdeolive pop up and have
a look at it, since he wrote the test and he's playing with
the catalog more than us two...
Andrea Aime
Tests in error:
Fixed. It was actually my fault, thought a bit surprising.
Yesterday I added a static final logger field, and XStream needs
that to be registered in a custom map used to sort fields even if
the field is not meant to be serialized. The exception was
quite criptic, but some step by step debugging helped me out
Andrea Aime
ah, cool. thanks Andrea!
Gabriel
Tests in error:
Gabriel Roldan
I doubt we would ever want to really persist the logger to I added an omit for it as well.
Tests in error:
Justin Deoliveira
Hmmm.. you mean XStream actually tries to store in xml
a static final field? Odd!
Andrea Aime
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/954/changes
Hmmm... not sure, I did not actually try. Might not... if not then the omit is unnecessary.
Justin Deoliveira
