See http://hudson.opengeo.org/hudson/job/geoserver-trunk/958/changes
Changes:
[jdeolive] GEOS-2721, added functionality to reorder and remove layer entries, and to set CRS
[jdeolive] Added up, down, and blank icons
[jdeolive] passing model object directly to edit page
[...truncated 3449 lines...]
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor107.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
</ServiceException>
</ServiceExceptionReport>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.313 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
12 Apr 13:40:59 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:619)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:703)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:454)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:435)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:709)
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.134 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.163 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Results :
Tests run: 153, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports
T E S T S
Running org.geoserver.gwc.GWCCatalogListenerTest
12 Apr 13:41:09 ERROR [util.XMLConfiguration] - Failed to find geowebcache.xml
12 Apr 13:41:09 ERROR [layer.TileLayerDispatcher] - Unable to determine configuration directory.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.72 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/target/web2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/pom.xml to /home/tomcat/.m2/repository/org/geoserver/web2/2.0-SNAPSHOT/web2-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/target/web2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web2/2.0-SNAPSHOT/web2-2.0-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target
[INFO] snapshot org.geotools:gt-postgis:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 104 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEntryPanel.java :[24,32] cannot find symbol
symbol : class ImageAjaxLink
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEditPage.java :[65,20] calculateLayerGroupBounds(org.geoserver.catalog.LayerGroupInfo) in org.geoserver.catalog.CatalogBuilder cannot be applied to (org.geoserver.catalog.LayerGroupInfo,org.opengis.referencing.crs.CoordinateReferenceSystem)
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEntryPanel.java :[132,19] cannot find symbol
location: class org.geoserver.web.data.layergroup.LayerGroupEntryPanel
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEntryPanel.java :[191,25] cannot find symbol
location: class org.geoserver.web.data.layergroup.LayerGroupEntryPanel.PositionPanel
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEntryPanel.java :[202,25] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEntryPanel.java :[210,25] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/src/main/java/org/geoserver/web/data/layergroup/LayerGroupEntryPanel.java :[221,25] cannot find symbol
[INFO] Total time: 3 minutes 26 seconds
[INFO] Finished at: Sun Apr 12 13:41:16 EDT 2009
[INFO] Final Memory: 39M/63M
