[Geoserver-devel] Build failed in Hudson: geoserver-trunk #96
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/96/changes
Changes:
[arneke] Switch default description template for KML from table to <li>, filtering out geometries.
[arneke] Missed redundant Document tag
[...truncated 1866 lines...]
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:render:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:shapefile-renderer:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:wms:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:xml:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 128 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 26 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.map.gif.GifMapProducerTest
Apr 17, 2008 7:38:32 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
17 Apr 19:38:33 ERROR [geotools.rendering] -
java.lang.NullPointerException
  at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1532)
  at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:649)
  at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1456)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1325)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:266)
  at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:302)
  at org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest.testSimpleGetMapQuery(DefaultRasterMapProducerTest.java:119)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:112)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Apr 17, 2008 7:38:33 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Streams: pixel count=192000 non bg pixels: 3777
INFO: testDefaultStyle Bridges: pixel count=192000 non bg pixels: 49
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 56
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 63
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 49
Apr 17, 2008 7:38:34 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 49
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.196 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.488 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.396 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.wms.CapabilitiesTest
Apr 17, 2008 7:38:37 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.664 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.492 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.752 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.268 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Apr 17, 2008 7:38:39 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Running org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest
Apr 17, 2008 7:38:39 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
17 Apr 19:38:39 ERROR [geotools.rendering] -
Apr 17, 2008 7:38:40 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.316 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.324 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
[Fatal Error] :3:2: The markup in the document following the root element must be well-formed.
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.012 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.16 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.184 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.22 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Results :
Tests in error:
  testTemplate(org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest)
Tests run: 68, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 7 seconds
[INFO] Finished at: Thu Apr 17 19:38:43 EDT 2008
[INFO] Final Memory: 31M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/97/changes
