[Geoserver-devel] Build failed in Hudson: geoserver-trunk #962
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/962/changes
Changes:
[jdeolive] refactored into version 1.0 and 1.1 schema encoder
[jdeolive] schema override lookup based on new config, filtering out duplicate entities in the schema, removed resourceLoader reference in constructor
[jdeolive] removed unnecessary passing of resource loader into constructor
[jdeolive] added a loader for cite data
[jdeolive] using prefixed name instead of non-prefixed
[jdeolive] added checks to validate to test for strings made up of empty names as well as null, setting keywords on resource validate
[jdeolive] added setter for keywords
[jdeolive] added stripExtension method
[...truncated 3869 lines...]
Apr 13, 2009 11:23:59 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.51 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0-SNAPSHOT/web-demo-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0-SNAPSHOT/web-demo-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0-SNAPSHOT/web-demo-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Application
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-directory:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:compile]
[INFO] Compiling 9 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 10 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.475 sec
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.367 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.295 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[720 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/geoserver.war
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT-tests.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target
[INFO] snapshot org.geotools:gt-arcsde:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT-sources.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc-core:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.977 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target
[INFO] snapshot org.geotools:gt-jdbc-oracle:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/response/v1_1_0/VersionedSchemaBuilder.java :[20,8] cannot find symbol
symbol : constructor FeatureTypeSchemaBuilder(org.geoserver.config.GeoServer,org.geoserver.platform.GeoServerResourceLoader)
location: class org.geoserver.wfs.xml.FeatureTypeSchemaBuilder
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/response/v1_1_0/VersionedXmlSchemaEncoder.java :[65,22] cannot find symbol
symbol : constructor GML3(org.geoserver.config.GeoServer,org.geoserver.platform.GeoServerResourceLoader)
location: class org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.GML3
[INFO] Total time: 5 minutes 5 seconds
[INFO] Finished at: Mon Apr 13 23:24:36 EDT 2009
[INFO] Final Memory: 41M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/963/changes
