[Geoserver-devel] Build failed in Hudson: geoserver-trunk #987
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/987/changes
Changes:
[arneke] Further i18n, still need to clean up .properties file and make a translation for actual testing
[...truncated 3782 lines...]
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Building Community Space
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/target/web2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/pom.xml to /home/tomcat/.m2/repository/org/geoserver/web2/2.0-SNAPSHOT/web2-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/target/web2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web2/2.0-SNAPSHOT/web2-2.0-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-postgis:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:compile]
[INFO] Compiling 109 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 19 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/surefire-reports
T E S T S
Running org.geoserver.web.admin.ContactPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.142 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.886 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.319 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.284 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Apr 16, 2009 2:40:40 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.212 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
16 Apr 14:40:41 ERROR [wicket.RequestCycle] - Tag '<button type="submit" wicket:id="saveButton">' (line 24, column 5) has a mismatched close tag at '</wicket:message>' (line 24, column 95)
[markup = http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/classes/org/geoserver/web/data/resource/ResourceConfigurationPage.html
<html>
<head>
</head>
<body>
<wicket:extend>
<h1><span wicket:id="resourcename"></span></h1>
<p><wicket:message key="configureTheResourceAndPublishingInformation">Configure the resource and publishing information for the current layer</wicket:message></p>
<form wicket:id="resource" name="resource">
    <div class="tabpanel" wicket:id="tabs"></div>
    <!-- <div wicket:id="resources">
        <div wicket:id="content"/>
    </div>
    <div wicket:id="layers">
    </div> -->
  <!-- [FIXME] this should be updated to use the submit pattern we're using elsewhere (<input> tags for submit and cancel. Basically, the following (I've stripped the trailing colon after "wicket" to avoid errors
  <ul>
    <li class="button-group selfclear">
      <input class="btnTxt" wicketid="submit" type="submit"><wicketmessage key="submit"/></input>
      <input class="btnTxt" wicketid="cancel" type="submit"><wicketmessage key="cancel"/></input>
    </li>
  </ul>
    <button type="submit" wicket:id="saveButton">wicket:message key="saveChanges">Save changes</wicket:message></button>
</form>
</wicket:extend>
</body>
</html>
, index = 21, current = [Raw markup]]
org.apache.wicket.markup.MarkupException: Tag '<button type="submit" wicket:id="saveButton">' (line 24, column 5) has a mismatched close tag at '</wicket:message>' (line 24, column 95)
<html>
<head>
</head>
<body>
<wicket:extend>
    </div>
    </div> -->
  <ul>
    </li>
  </ul>
</form>
</wicket:extend>
</body>
</html>
  at org.apache.wicket.markup.MarkupParser.parseMarkup(MarkupParser.java:393)
  at org.apache.wicket.markup.MarkupParser.parse(MarkupParser.java:270)
  at org.apache.wicket.markup.loader.SimpleMarkupLoader.loadMarkup(SimpleMarkupLoader.java:52)
  at org.apache.wicket.markup.loader.InheritedMarkupMarkupLoader.loadMarkup(InheritedMarkupMarkupLoader.java:62)
  at org.apache.wicket.markup.loader.DefaultMarkupLoader.loadMarkup(DefaultMarkupLoader.java:55)
  at org.apache.wicket.markup.MarkupCache.loadMarkup(MarkupCache.java:458)
  at org.apache.wicket.markup.MarkupCache.loadMarkupAndWatchForChanges(MarkupCache.java:553)
  at org.apache.wicket.markup.MarkupCache.getMarkup(MarkupCache.java:319)
  at org.apache.wicket.markup.MarkupCache.getMarkupStream(MarkupCache.java:215)
  at org.apache.wicket.MarkupContainer.getAssociatedMarkupStream(MarkupContainer.java:343)
  at org.apache.wicket.Page.onRender(Page.java:1463)
  at org.apache.wicket.Component.render(Component.java:2317)
  at org.apache.wicket.Page.renderPage(Page.java:904)
  at org.apache.wicket.request.target.component.PageRequestTarget.respond(PageRequestTarget.java:63)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:104)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1181)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1252)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1353)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:493)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:484)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:472)
  at org.apache.wicket.util.tester.BaseWicketTester.executeListener(BaseWicketTester.java:248)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:233)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:277)
  at org.geoserver.web.data.resource.ResourceConfigurationPageTest.testBasic(ResourceConfigurationPageTest.java:12)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: java.text.ParseException: Tag '<button type="submit" wicket:id="saveButton">' (line 24, column 5) has a mismatched close tag at '</wicket:message>' (line 24, column 95)
  at org.apache.wicket.markup.parser.filter.HtmlHandler.nextTag(HtmlHandler.java:144)
  at org.apache.wicket.markup.parser.filter.WicketRemoveTagHandler.nextTag(WicketRemoveTagHandler.java:60)
  at org.apache.wicket.markup.parser.filter.WicketLinkTagHandler.nextTag(WicketLinkTagHandler.java:94)
  at org.apache.wicket.markup.parser.AbstractMarkupFilter.nextComponentTag(AbstractMarkupFilter.java:82)
  at org.apache.wicket.markup.parser.filter.WicketNamespaceHandler.nextTag(WicketNamespaceHandler.java:72)
  at org.apache.wicket.markup.parser.filter.WicketMessageTagHandler.nextTag(WicketMessageTagHandler.java:81)
  at org.apache.wicket.markup.parser.filter.HtmlHeaderSectionHandler.nextTag(HtmlHeaderSectionHandler.java:77)
  at org.apache.wicket.markup.parser.filter.HeadForceTagIdHandler.nextTag(HeadForceTagIdHandler.java:77)
  at org.apache.wicket.markup.parser.filter.OpenCloseTagExpander.nextTag(OpenCloseTagExpander.java:51)
  at org.apache.wicket.markup.parser.filter.EnclosureHandler.nextTag(EnclosureHandler.java:76)
  at org.apache.wicket.markup.parser.filter.RelativePathPrefixHandler.nextTag(RelativePathPrefixHandler.java:116)
  at org.apache.wicket.markup.MarkupParser.getNextTag(MarkupParser.java:302)
  at org.apache.wicket.markup.MarkupParser.parseMarkup(MarkupParser.java:322)
  ... 51 more
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.204 sec <<< FAILURE!
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.331 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.757 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.739 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.249 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.96 sec
Results :
Tests in error:
  testBasic(org.geoserver.web.data.resource.ResourceConfigurationPageTest)
Tests run: 31, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 30 seconds
[INFO] Finished at: Thu Apr 16 14:40:50 EDT 2009
[INFO] Final Memory: 40M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/988/changes
Changes:
[aaime] Add dependency to jdbc-oracle so that the datastore is included, removed the inclusion of jdbc-core from the oracle extension as it's already part of the core jar set
[arneke] Fixes for i18n in core, not sure why these didnt show up before
[...truncated 4114 lines...]
        </script>
      </form>
      <div wicket:id="logoutform">
        <a href="j_acegi_logout" class="button-logout icon"><div>Logout</div></a>
        <span class="username">Logged in as <span wicket:id="username">User von Testenheimer</span></span>.
      </div>
      </div>
    </div><!-- /.wrap -->
  </div><!-- /#header -->
  <div id="main">
    <div class="wrap selfclear">
    <div id="sidebar">
      <ul id="navigation">
        <li wicket:id="category" class="navigation-tab">
          <div class="navigation-tab-header">
            <span wicket:id="category.header">[Category Header]</span>
          </div>
          <ul class="navigation-tab-content plain">
            <li wicket:id="category.links" class="nav-administer-service">
              <a title="title" wicket:id="link">
                <img wicket:id="link.icon" src="#"/><span wicket:id="link.label"></span>
              </a>
            </li>
          </ul>
        </li>
        <li wicket:id="standalone" class="navigation-tab">
          <div class="navigation-tab-single">
             <a href="#" wicket:id="link"><span wicket:id="link.label">[Link]</span></a>
          </div>
        </li>
      </ul>
      <div wicket:id="devButtons" class="button-group selfclear"></div>
    </div><!-- /#sidebar -->
    <div id="page">
      <div class="page-header">
        <div wicket:id="feedback" id="feedback"></div>
        <h1><wicket:message key="page.title"></wicket:message></h1>
        <p><wicket:message key="page.description"></wicket:message></p>
      </div>
      <div class="page-pane">
        <wicket:child><wicket:extend>
<form wicket:id="form">
  <ul>
    <li>
      <fieldset>
        <legend><span><wicket:message key="serviceMetadata">Service Metadata</wicket:message></span></legend>
        <ul>
          <li>
            <input type="checkbox" class="field checkbox" wicket:id="enabled"></input>
            <label class="choice"><span wicket:id="service.enabled"><wicket:message key="enable">Enable</wicket:message></span></label>
          </li>
          <li>
            <input type="checkbox" class="field checkbox" wicket:id="citeCompliant"></input>
            <label class="choice"><wicket:message key="strictCITECompliance">Strict CITE compliance</wicket:message></label>
          </li>
          <li>
            <label><wicket:message key="maintainer">Maintainer</wicket:message></label>
            <input class="field text" wicket:id="maintainer"></input>
          </li>
          <li>
            <label><wicket:message key="onlineResource">Online resource</wicket:message></label>
            <input class="field text" wicket:id="onlineResource"></input>
          </li>
          <li>
            <label><wicket:message key="titleMsg">Title</wicket:message></label>
            <input class="field text" wicket:id="title"></input>
          </li>
          <li>
             <label><wicket:message key="abstract">Abstract</wicket:message></label>
             <textarea class="field textarea" wicket:id="abstract"></textarea>
          </li>
          <li>
             <label><wicket:message key="fees">Fees</wicket:message></label>
             <input class="field text" wicket:id="fees"></input>
          </li>
          <li>
             <label><wicket:message key="accessConstraints">Access Constraints</wicket:message></label>
             <input class="field text" wicket:id="accessConstraints"></input>
          </li>
          <li>
             <div wicket:id="keywords"></div>
          </li>
        </ul>
      </fieldset>
    </li>
    <li>
      <fieldset>
        <legend><span><wicket:message key="rasterRenderingOptions">Raster Rendering Options</wicket:message></span></legend>
        <ul>
          <li>
            <label><wicket:message key="defaultInterpolation">Default Interpolation</wicket:message></label>
            <select class="field" wicket:id="interpolation"></select>
          </li>
        </ul>
      </fieldset>
    </li>
    <li>
      <fieldset>
        <legend><span><wicket:message key="watermarkSettings">Watermark Settings</wicket:message></span></legend>
        <ul>
          <li>
            <input type="checkbox" wicket:id="watermark.enabled" class="field checkbox"></input>
            <label class="choice"><wicket:message key="enableWatermark">Enable Watermark</wicket:message></label>
          </li>
          <li>
            <label><wicket:message key="watermarkUrl">Watermark URL</wicket:message></label>
            <input type="text" class="field text" wicket:id="watermark.uRL"></input>
          </li>
          <li>
            <label><wicket:message key="watermarkTransparency">Watermark Transparency (0 - 100)</wicket:message></label>
            <input type="text" class="field text" wicket:id="watermark.transparency"></input>
          </li>
          <li>
            <label><wicket:message key="watermarkPosition">Watermark Position</wicket:message></label>
            <select wicket:id="watermark.position"></select>
          </li>
        </ul>
      </fieldset>
    </li>
    <li>
      <fieldset>
        <legend><span><wicket:message key="svgOptions">SVG Options</wicket:message></span></legend>
        <ul>
         <li>
            <label><wicket:message key="svgProducer">SVG producer</wicket:message></label>
            <select wicket:id="svg.producer"></select>
          </li>
          <li>
            <input type="checkbox" wicket:id="svg.antialias" class="field checkbox"></input>
            <label class="choice"><wicket:message key="enableAntialiasing">Enable antialiasing</wicket:message></label>
          </li>
        </ul>
      </fieldset>
    </li>
  </wicket:extend></wicket:child>
      <button type="submit" wicket:id="submit"><wicket:message key="submit"/></button>
      <button type="submit" wicket:id="cancel"><wicket:message key="cancel"/></button>
    </li>
  </ul>
</form>
      </div>
    </div><!-- /#page -->
    </div><!-- /.wrap> -->
  </div><!-- /#main -->
</body>
</html>
, index = 106, current = '<wicket:message key="enable">' (line 12, column 69)]
  at org.apache.wicket.markup.MarkupStream.throwMarkupException(MarkupStream.java:464)
  at org.apache.wicket.Component.replaceComponentTagBody(Component.java:3894)
  at org.apache.wicket.markup.html.basic.Label.onComponentTagBody(Label.java:111)
  at org.apache.wicket.Component.renderComponent(Component.java:2480)
  at org.apache.wicket.markup.html.WebComponent.onRender(WebComponent.java:60)
  at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1297)
  at org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1476)
  at org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1401)
  at org.apache.wicket.markup.html.form.Form.onComponentTagBody(Form.java:1710)
  at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1411)
  at org.apache.wicket.markup.html.form.Form.onRender(Form.java:1774)
  at org.apache.wicket.MarkupContainer.autoAdd(MarkupContainer.java:223)
  at org.apache.wicket.markup.resolver.MarkupInheritanceResolver.resolve(MarkupInheritanceResolver.java:66)
  at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1324)
  at org.apache.wicket.markup.resolver.MarkupInheritanceResolver.resolve(MarkupInheritanceResolver.java:73)
  at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1427)
  at org.apache.wicket.Page.onRender(Page.java:1470)
  at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:231)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:539)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:458)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:367)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:289)
  at org.geoserver.wms.web.data.WMSAdminPageTest.testValues(WMSAdminPageTest.java:12)
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 6.099 sec <<< FAILURE!
Running org.geoserver.wms.web.data.StylePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.104 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.632 sec
Results :
Tests in error:
  testValues(org.geoserver.wms.web.data.WMSAdminPageTest)
Tests run: 4, Failures: 0, Errors: 1, Skipped: 0
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 39 seconds
[INFO] Finished at: Thu Apr 16 15:02:58 EDT 2009
[INFO] Final Memory: 38M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/989/changes
Changes:
[arneke] Further fix for i18n in core
[jdeolive] removing unneeded gt-oracle-spatial dependency
[...truncated 3926 lines...]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/surefire-reports
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.312 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0-SNAPSHOT/web-wfs-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0-SNAPSHOT/web-wfs-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0-SNAPSHOT/web-wfs-2.0-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target
[INFO] Compiling 2 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/classes
[INFO] snapshot org.geoserver:wcs1_1:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 3 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/surefire-reports
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
Apr 16, 2009 3:26:48 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.961 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.174 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0-SNAPSHOT/web-wcs-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0-SNAPSHOT/web-wcs-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0-SNAPSHOT/web-wcs-2.0-SNAPSHOT-sources.jar
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target
[INFO] Compiling 8 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/classes
[INFO] Compiling 2 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/surefire-reports
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.278 sec
Running org.geoserver.web.demo.SRSListPageTest
Apr 16, 2009 3:27:08 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.98 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0-SNAPSHOT/web-demo-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0-SNAPSHOT/web-demo-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/web-demo-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0-SNAPSHOT/web-demo-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
[INFO] snapshot org.geotools:gt-jdbc-postgis:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc-core:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-directory:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 9 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/classes
[INFO] Compiling 10 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.606 sec
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.415 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.385 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.051 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[3024 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/geoserver.war
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT-tests.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target
[INFO] snapshot org.geotools:gt-arcsde:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:2.6-SNAPSHOT: checking for updates from opengeo
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  opengeo (http://repo.opengeo.org/),
  maven2-repository.dev.java.net (http://download.java.net/maven/2),
  geotools (http://maven.geotools.fr/repository/)
Path to dependency:
  1) org.geoserver.extension:arcsde:jar:2.0-SNAPSHOT
  2) org.geotools:gt-api:jar:2.6-SNAPSHOT
  3) org.geotools:gt-referencing:jar:2.6-SNAPSHOT
  4) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
  5) org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi-pending/2.3-SNAPSHOT/geoapi-pending-2.3-SNAPSHOT.jar
[INFO] Total time: 4 minutes 39 seconds
[INFO] Finished at: Thu Apr 16 15:27:38 EDT 2009
[INFO] Final Memory: 41M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/990/changes
