[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #1000
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/1000/changes&gt;
Changes:
[riniangreani] Corrected example for isList.
[...truncated 547 lines...]
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot;&gt; does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt;
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt; . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
[INFO] Compiling 58 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1&gt; (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset&gt; are up to date.
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/generated-sources/jjtree&gt; are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs&gt; (directory)
[INFO] Copying 10 resources
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 233 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/classes&gt;
[INFO] Copying 17 resources
[INFO] Compiling 63 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms&gt; (directory)
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 175 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/classes&gt;
[INFO] Copying 56 resources
[INFO] Compiling 69 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/wms/target/wms-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/gwc/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/gwc&gt; (directory)
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] snapshot org.geowebcache:gwc-core:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-georss:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-kml:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-rest:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-tms:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-ve:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wms:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/gwc/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/gwc/src/main/java/org/geoserver/gwc/layer/CatalogConfiguration.java&gt;:\[57,7\] org.geoserver.gwc.layer.CatalogConfiguration is not abstract and does not override abstract method addLayer(org.geowebcache.layer.TileLayer) in org.geowebcache.config.Configuration
[INFO] Total time: 2 minutes 35 seconds
[INFO] Finished at: Mon Feb 13 03:34:55 UTC 2012
[INFO] Final Memory: 67M/407M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-02-13-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/1001/changes&gt;
