See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/333/changes>
Changes:
[aaime] Bolsena WPS work
[simboss] GEOS-4017
[aaime] Whoops, fixing this compile failure, did not know this module was in the build at all
[jdeolive] GEOS-3998, fixing GeoServerInfo client properties bug and adding test
[jdeolive] GEOS-4008, removed unused styles that have no SLD
[aaime] Forgot to update one provider
[aaime] [GEOS-4015] GeoServerTablePanel is not setup to support editable tables
[arneke] Removing outdated copy of REST module, with afabiani's blessing
[...truncated 861 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target>
[INFO] [resources:resources]
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/src/main/resources>
[INFO] [compiler:compile]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/classes>
[INFO] [resources:testResources]
[INFO] Copying 0 resource
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/test-classes>
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target>
[INFO] Copying 8 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/src/main/resources>
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/classes>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target>
[INFO] Copying 10 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/classes>
[INFO] Copying 2 resources
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target>
[INFO] Copying 20 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/src/main/resources>
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/classes>
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target>
[INFO] [config:clean {execution: configClean}]
clean:
[delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/resources>
[INFO] snapshot org.geotools:gt-directory:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/classes>
[INFO] Copying 77 resources
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-tests.jar>
[INFO] snapshot org.geoserver.maven:config:2.1-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-sources.jar>
[INFO] [config:config {execution: configPackage}]
config:
[echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/../../../data/release>
[copy] Copying 437 files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data>
[copy] Copied 63 empty directories to 1 empty directory under <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[1345 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver.war>
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target>
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.1-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/pom-transformed.xml> to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer CSS Styling
[INFO] artifact org.scala-tools:maven-scala-plugin: checking for updates from scala-tools.org
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/java>
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala>
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/test/scala>
[INFO] [scala:compile {execution: scala-compile-first}]
[INFO] Checking for multiple versions of scala
[INFO] includes = [**/*.scala,**/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala>:\-1: info: compiling
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1276882348208
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/SummaryTable.scala>:81: error: error overriding method model in class GeoServerDataProvider of type (Any)org.apache.wicket.model.IModel;
[INFO] method model cannot override final member
[INFO] override def model(a: Any): IModel = new Model(a.asInstanceOf[Serializable])
[INFO] ^
[ERROR] one error found
[ERROR] BUILD ERROR
[INFO] wrap: org.apache.commons.exec.ExecuteException: Process exited with an error: 1(Exit value: 1)
[INFO] Total time: 3 minutes 9 seconds
[INFO] Finished at: Fri Jun 18 13:32:42 EDT 2010
[INFO] Final Memory: 60M/154M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2010-06-18-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/334/>
[...truncated 1486 lines...]
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.OperatingSystemProfileActivator@anonymised.com
[INFO] Webapp assembled in[2034 msecs]
[INFO] excludes =
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1276932863547
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 3 minutes 16 seconds
[INFO] Finished at: Sat Jun 19 03:34:39 EDT 2010
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2010-06-19-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/335/changes>
Changes:
[aaime] Adding support for bounding box data in both process inputs and outputs
[...truncated 735 lines...]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] [jar:jar]
config:
[INFO] Webapp assembled in[1742 msecs]
[INFO] excludes =
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1276968925954
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 2 minutes 51 seconds
[INFO] Finished at: Sat Jun 19 13:35:36 EDT 2010
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/336/>
[...truncated 1487 lines...]
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.JdkPrefixProfileActivator@anonymised.com
[INFO] Webapp assembled in[1473 msecs]
[INFO] excludes =
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1277019253338
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Finished at: Sun Jun 20 03:34:24 EDT 2010
[INFO] Final Memory: 60M/159M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2010-06-20-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/337/changes>
Changes:
[groldan] GEOS-3993
[...truncated 1425 lines...]
[INFO] Webapp assembled in[1544 msecs]
[INFO] excludes =
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1277105651486
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 2 minutes 54 seconds
[INFO] Finished at: Mon Jun 21 03:34:23 EDT 2010
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2010-06-21-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/338/changes>
Changes:
[aaime] [GEOS-4021] Expose dpi setting to generate high resolution images suitable for printing
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.FileProfileActivator@anonymised.com
[INFO] Webapp assembled in[1680 msecs]
[INFO] excludes =
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1277193101060
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 3 minutes 7 seconds
[INFO] Finished at: Tue Jun 22 03:51:56 EDT 2010
[INFO] Final Memory: 61M/164M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2010-06-22-bin.zip
