[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #380
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/380/&gt;
[...truncated 952 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[982 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver.war&gt;
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer CSS Styling
[INFO] artifact org.scala-tools:maven-scala-plugin: checking for updates from scala-tools.org
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/java&gt;
[INFO] Copying 9 resources
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala&gt;
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/test/scala&gt;
[INFO] [scala:compile {execution: scala-compile-first}]
[INFO] Checking for multiple versions of scala
[INFO] includes = [**/*.scala,**/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala&gt;:\-1: info: compiling
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes&gt; at 1280720125661
[INFO] prepare-compile in 0 s
[INFO] compile in 17 s
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 28 resources
[INFO] [scala:testCompile {execution: scala-test-compile}]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/test/scala&gt;:\-1: info: compiling
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/test-classes&gt; at 1280720143227
[INFO] compile in 18 s
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/css/2.1-SNAPSHOT/css-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/css/2.1-SNAPSHOT/css-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/css/2.1-SNAPSHOT/css-2.1-SNAPSHOT-sources.jar
[INFO] Building Printing Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target&gt;
[INFO] Copying 5 resources
[INFO] Copying 2 resources
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
[WARNING] repository metadata for: 'snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT' could not be retrieved from repository: osgeo due to an error: Authorization failed: Access denied to: http://download.osgeo.org/webdav/geotools/org/mapfish/print/print-lib/1.2-SNAPSHOT/maven-metadata.xml
[INFO] Repository 'osgeo' will be blacklisted
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.pom
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Embedded FTP server
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target&gt;
[INFO] Copying 1 resource
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/src/test/java&gt;
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target&gt;
[INFO] Copying 18 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from osgeo
[WARNING] repository metadata for: 'snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT' could not be retrieved from repository: osgeo due to an error: Authorization failed: Access denied to: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/2.7-SNAPSHOT/maven-metadata.xml
[INFO] snapshot es.unex.sextante.lib:sextante_vectorTools:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante:lib:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante:sextante:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:libDocEngines:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:libMath:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gui:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_wps:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridCalculus:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 110 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/classes&gt;
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/wps-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/wps-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/wps-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/wps-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/wps-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/wps-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/src/main/resources&gt;
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorTools/0.6-SNAPSHOT/sextante_vectorTools-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libDocEngines/0.6-SNAPSHOT/libDocEngines-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libMath/0.6-SNAPSHOT/libMath-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gui/0.6-SNAPSHOT/sextante_gui-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_wps/0.6-SNAPSHOT/sextante_wps-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCalculus/0.6-SNAPSHOT/sextante_gridCalculus-0.6-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Authorization failed: Access denied to: http://download.osgeo.org/webdav/geotools/es/unex/sextante/lib/sextante_vectorTools/0.6-SNAPSHOT/sextante_vectorTools-0.6-SNAPSHOT.jar
  es.unex.sextante.lib:sextante_vectorTools:jar:0.6-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  opengeo (http://repo.opengeo.org/),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org)
Path to dependency:
  1) org.geoserver.community:release:jar:2.1-SNAPSHOT
  2) org.geoserver.community:wps:jar:2.1-SNAPSHOT
  3) es.unex.sextante.lib:sextante_vectorTools:jar:0.6-SNAPSHOT
[INFO] Total time: 2 minutes 46 seconds
[INFO] Finished at: Mon Aug 02 03:36:18 UTC 2010
[INFO] Final Memory: 81M/304M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-08-02-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/381/changes&gt;
