[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #443
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/443/changes&gt;
Changes:
[jdeolive] added community release descriptor for monitoring module
[jdeolive] updated monitoring module to reflect recent changes in wms module
[jdeolive] using geotools util class to serialize dates in csv output
[jdeolive] ensuring monitor loaded from config, rather than straight from dao, tweaked default request filters
[...truncated 9747 lines...]
4893/?
5404/?
5915/?
6489/?
7131/?
7711/?
8222/?
8869/?
9448/?
10021/?
10663/?
11313/?
11449/?
12044/?
12555/?
13155/?
13757/?
14358/?
14955/?
15466/?
15978/?
16226/?
16737/?
17248/?
17844/?
18355/?
18535/?
18564/?
19015/?
19606/?
20118/?
20703/?
21216/?
21728/?
22239/?
22751/?
23344/?
23943/?
24456/?
25051/?
25636/?
26148/?
26661/?
27250/?
27762/?
28347/?
28522/?
29110/?
29622/?
30133/?
30717/?
31299/?
31635/?
32209/?
32720/?
33215/?
33726/?
34238/?
34856/?
35367/?
35981/?
36581/?
37028/?
37631/?
38235/?
38746/?
39257/?
39865/?
40376/?
41066/?
41578/?
42187/?
42698/?
43210/?
43810/?
44413/?
45013/?
45526/?
46118/?
46630/?
47224/?
47736/?
48336/?
48847/?
49451/?
49963/?
50563/?
51161/?
51672/?
52150/?
52715/?
53227/?
53738/?
53834/?
53858/?
54428/?
54857/?
55366/?
55873/?
56379/?
56889/?
57395/?
57903/?
57934/?
58441/?
59370/?
61669/?
65152/?
66426/?
Downloading: http://repo.opengeo.org//org/hibernate/ejb3-persistence/1.0.1.GA/ejb3-persistence-1.0.1.GA.jar
[INFO] Unable to find resource 'org.hibernate:ejb3-persistence:jar:1.0.1.GA' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/hibernate/ejb3-persistence/1.0.1.GA/ejb3-persistence-1.0.1.GA.jar
[INFO] Unable to find resource 'org.hibernate:ejb3-persistence:jar:1.0.1.GA' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/hibernate/ejb3-persistence/1.0.1.GA/ejb3-persistence-1.0.1.GA.jar
[INFO] Unable to find resource 'org.hibernate:ejb3-persistence:jar:1.0.1.GA' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/hibernate/ejb3-persistence/1.0.1.GA/ejb3-persistence-1.0.1.GA.jar
577/?
1152/?
1766/?
2352/?
2862/?
3449/?
4011/?
4550/?
5123/?
5712/?
6309/?
6912/?
7465/?
8082/?
8640/?
9245/?
9492/?
10094/?
10714/?
11270/?
11839/?
12405/?
12970/?
13574/?
14127/?
14427/?
14981/?
15546/?
16155/?
16714/?
17276/?
17876/?
18450/?
18507/?
18543/?
19116/?
19668/?
20234/?
20866/?
21428/?
21989/?
22590/?
23101/?
23611/?
24050/?
24560/?
25116/?
25688/?
26322/?
26883/?
27507/?
28066/?
28576/?
28823/?
29333/?
29887/?
30521/?
31197/?
31880/?
32519/?
33113/?
33695/?
33991/?
34556/?
35170/?
35649/?
36259/?
36813/?
37392/?
37971/?
38581/?
38888/?
39533/?
40160/?
40673/?
41187/?
41692/?
42024/?
42528/?
43033/?
43538/?
44042/?
44548/?
45763/?
47622/?
50669/?
52847/?
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) com.maxmind:geoip:jar:1.2.3
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=com.maxmind -DartifactId=geoip -Dversion=1.2.3 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=com.maxmind -DartifactId=geoip -Dversion=1.2.3 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:monitoring:jar:2.1-SNAPSHOT
    2) com.maxmind:geoip:jar:1.2.3
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  opengeo (http://repo.opengeo.org/),
  osgeo (http://download.osgeo.org/webdav/geotools/),
[INFO] Total time: 3 minutes 10 seconds
[INFO] Finished at: Tue Sep 28 03:34:18 UTC 2010
[INFO] Final Memory: 84M/306M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-09-28-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/444/&gt;
