[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #465
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/465/changes&gt;
Changes:
[jdeolive] GEOS-4147, adding restconfig docs about reload operation
[jdeolive] updated proxy module to wicket 1.4
[jdeolive] upgrading to wicket 1.4
[...truncated 1113 lines...]
2/104K
4/104K
5/104K
7/104K
8/104K
9/104K
11/104K
12/104K
14/104K
15/104K
16/104K
18/104K
19/104K
21/104K
22/104K
24/104K
25/104K
26/104K
28/104K
29/104K
31/104K
32/104K
33/104K
35/104K
36/104K
38/104K
39/104K
41/104K
42/104K
43/104K
45/104K
46/104K
48/104K
49/104K
50/104K
52/104K
53/104K
55/104K
56/104K
57/104K
59/104K
60/104K
62/104K
63/104K
65/104K
66/104K
67/104K
69/104K
70/104K
72/104K
73/104K
74/104K
76/104K
77/104K
79/104K
80/104K
82/104K
83/104K
84/104K
86/104K
87/104K
89/104K
90/104K
91/104K
93/104K
94/104K
96/104K
97/104K
98/104K
100/104K
101/104K
103/104K
104/104K
104K downloaded (maven-scala-plugin-2.14.2.jar)
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/java&gt;
[INFO] Copying 9 resources
Downloading: http://scala-tools.org/repo-releases/org/apache/maven/shared/maven-invoker/2.0.11/maven-invoker-2.0.11.pom
[INFO] Unable to find resource 'org.apache.maven.shared:maven-invoker:pom:2.0.11' in repository scala-tools.org (http://scala-tools.org/repo-releases)
Downloading: http://repository.jboss.org/maven2/org/apache/maven/shared/maven-invoker/2.0.11/maven-invoker-2.0.11.pom
[INFO] Unable to find resource 'org.apache.maven.shared:maven-invoker:pom:2.0.11' in repository jboss.releases (http://repository.jboss.org/maven2)
Downloading: http://repo1.maven.org/maven2/org/apache/maven/shared/maven-invoker/2.0.11/maven-invoker-2.0.11.pom
821/?
2417/?
4771/?
5074/?
Downloading: http://scala-tools.org/repo-releases/org/apache/maven/shared/maven-shared-components/12/maven-shared-components-12.pom
[INFO] Unable to find resource 'org.apache.maven.shared:maven-shared-components:pom:12' in repository scala-tools.org (http://scala-tools.org/repo-releases)
Downloading: http://repository.jboss.org/maven2/org/apache/maven/shared/maven-shared-components/12/maven-shared-components-12.pom
[INFO] Unable to find resource 'org.apache.maven.shared:maven-shared-components:pom:12' in repository jboss.releases (http://repository.jboss.org/maven2)
Downloading: http://repo1.maven.org/maven2/org/apache/maven/shared/maven-shared-components/12/maven-shared-components-12.pom
799/?
3163/?
6543/?
9051/?
9337/?
Downloading: http://scala-tools.org/repo-releases/org/apache/maven/maven-parent/13/maven-parent-13.pom
[INFO] Unable to find resource 'org.apache.maven:maven-parent:pom:13' in repository scala-tools.org (http://scala-tools.org/repo-releases)
Downloading: http://repository.jboss.org/maven2/org/apache/maven/maven-parent/13/maven-parent-13.pom
[INFO] Unable to find resource 'org.apache.maven:maven-parent:pom:13' in repository jboss.releases (http://repository.jboss.org/maven2)
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-parent/13/maven-parent-13.pom
773/?
1989/?
6085/?
6450/?
10546/?
10858/?
14084/?
16242/?
19239/?
22634/?
Downloading: http://scala-tools.org/repo-releases/org/apache/maven/shared/maven-invoker/2.0.11/maven-invoker-2.0.11.jar
[INFO] Unable to find resource 'org.apache.maven.shared:maven-invoker:jar:2.0.11' in repository scala-tools.org (http://scala-tools.org/repo-releases)
Downloading: http://repository.jboss.org/maven2/org/apache/maven/shared/maven-invoker/2.0.11/maven-invoker-2.0.11.jar
[INFO] Unable to find resource 'org.apache.maven.shared:maven-invoker:jar:2.0.11' in repository jboss.releases (http://repository.jboss.org/maven2)
Downloading: http://repo1.maven.org/maven2/org/apache/maven/shared/maven-invoker/2.0.11/maven-invoker-2.0.11.jar
717/?
1251/?
1763/?
2274/?
2785/?
3297/?
3808/?
4296/?
4807/?
5408/?
5971/?
6489/?
7000/?
7511/?
8024/?
8600/?
9170/?
9682/?
10194/?
10705/?
11271/?
11851/?
12363/?
12990/?
13539/?
14052/?
14618/?
15191/?
15702/?
16213/?
16724/?
17236/?
17674/?
18186/?
18695/?
19209/?
19718/?
20228/?
20804/?
21369/?
21942/?
22453/?
22963/?
23532/?
24326/?
24837/?
25348/?
25924/?
28467/?
28909/?
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala&gt;
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/test/scala&gt;
[INFO] [scala:compile {execution: scala-compile-first}]
[INFO] Checking for multiple versions of scala
[INFO] includes = [**/*.scala,**/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala&gt;:\-1: info: compiling
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes&gt; at 1287113753379
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:74: error: trait IValidator takes type parameters
[INFO] class CssValidator extends IValidator {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:75: error: trait IValidatable takes type parameters
[INFO] override def validate(text: IValidatable) = {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:104: error: trait IModel takes type parameters
[INFO] class UpdatingTextArea(id: String, m: IModel) extends TextArea(id, m) {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:104: error: too many arguments for constructor Object: ()java.lang.Object
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:121: error: trait IModel takes type parameters
[INFO] class StylePanel(id: String, model: IModel, map: OpenLayersMapPanel) extends Panel(id, model) {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:136: error: trait IModel takes type parameters
[INFO] val sldModel: IModel =
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:141: error: type mismatch;
[INFO] found : java.lang.String
[INFO] required: Nothing
[INFO] """.trim)
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:153: error: value add is not a member of CssDemoPage.this.UpdatingTextArea
[INFO] textArea.add(new CssValidator)
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:154: error: overloaded method value add with alternatives:
[INFO] (org.apache.wicket.markup.html.form.validation.IFormValidator)Unit <and>
[INFO] (<repeated...>[org.apache.wicket.Component])org.apache.wicket.MarkupContainer <and>
[INFO] (<repeated...>[org.apache.wicket.behavior.IBehavior])org.apache.wicket.Component
[INFO] cannot be applied to (CssDemoPage.this.UpdatingTextArea)
[INFO] styleEditor.add(textArea)
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:156: error: class Form takes type parameters
[INFO] override def onSubmit(target: AjaxRequestTarget, form: Form) = {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:188: error: trait IModel takes type parameters
[INFO] class DataPanel(id: String, model: IModel) extends Panel(id, model) {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:282: error: trait IChoiceRenderer takes type parameters
[INFO] new IChoiceRenderer {
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala&gt;:314: error: trait IChoiceRenderer takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/SummaryTable.scala&gt;:81: error: trait IModel takes type parameters
[INFO] override def newModel(a: Any): IModel = new Model(a.asInstanceOf[Serializable])
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/SummaryTable.scala&gt;:117: error: trait IModel takes type parameters
[INFO] value: IModel,
[INFO] ^
[ERROR] 15 errors found
[ERROR] BUILD ERROR
[INFO] wrap: org.apache.commons.exec.ExecuteException: Process exited with an error: 1(Exit value: 1)
[INFO] Total time: 2 minutes 16 seconds
[INFO] Finished at: Fri Oct 15 03:35:59 UTC 2010
[INFO] Final Memory: 78M/309M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-15-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Hi David,
In the upgrade to wicket 1.4 i forgot some of the community modules that we actually include in the nightly builds. css being one of them. As it written in scala I am not really confident in my ability to fix it. If you could port the module it would be much appreciated.
-Justin
On Thu, Oct 14, 2010 at 9:35 PM, Hudson <monitor@anonymised.com> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/465/changes>
Changes:
[…truncated 1113 lines…]
2/104K
4/104K
5/104K
7/104K
8/104K
9/104K
11/104K
12/104K
14/104K
15/104K
16/104K
18/104K
19/104K
21/104K
22/104K
24/104K
25/104K
26/104K
28/104K
29/104K
31/104K
32/104K
33/104K
35/104K
36/104K
38/104K
39/104K
41/104K
42/104K
43/104K
45/104K
46/104K
48/104K
49/104K
50/104K
52/104K
53/104K
55/104K
56/104K
57/104K
59/104K
60/104K
62/104K
63/104K
65/104K
66/104K
67/104K
69/104K
70/104K
72/104K
73/104K
74/104K
76/104K
77/104K
79/104K
80/104K
82/104K
83/104K
84/104K
86/104K
87/104K
89/104K
90/104K
91/104K
93/104K
94/104K
96/104K
97/104K
98/104K
100/104K
101/104K
103/104K
104/104K
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target>
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/java>
[INFO] Unable to find resource ‘org.apache.maven.shared:maven-invoker:pom:2.0.11’ in repository scala-tools.org (http://scala-tools.org/repo-releases)
[INFO] Unable to find resource ‘org.apache.maven.shared:maven-invoker:pom:2.0.11’ in repository jboss.releases (http://repository.jboss.org/maven2)
821/?
2417/?
4771/?
5074/?
[INFO] Unable to find resource ‘org.apache.maven.shared:maven-shared-components:pom:12’ in repository scala-tools.org (http://scala-tools.org/repo-releases)
[INFO] Unable to find resource ‘org.apache.maven.shared:maven-shared-components:pom:12’ in repository jboss.releases (http://repository.jboss.org/maven2)
799/?
3163/?
6543/?
9051/?
9337/?
[INFO] Unable to find resource ‘org.apache.maven:maven-parent:pom:13’ in repository scala-tools.org (http://scala-tools.org/repo-releases)
[INFO] Unable to find resource ‘org.apache.maven:maven-parent:pom:13’ in repository jboss.releases (http://repository.jboss.org/maven2)
773/?
1989/?
6085/?
6450/?
10546/?
10858/?
14084/?
16242/?
19239/?
22634/?
[INFO] Unable to find resource ‘org.apache.maven.shared:maven-invoker:jar:2.0.11’ in repository scala-tools.org (http://scala-tools.org/repo-releases)
[INFO] Unable to find resource ‘org.apache.maven.shared:maven-invoker:jar:2.0.11’ in repository jboss.releases (http://repository.jboss.org/maven2)
717/?
1251/?
1763/?
2274/?
2785/?
3297/?
3808/?
4296/?
4807/?
5408/?
5971/?
6489/?
7000/?
7511/?
8024/?
8600/?
9170/?
9682/?
10194/?
10705/?
11271/?
11851/?
12363/?
12990/?
13539/?
14052/?
14618/?
15191/?
15702/?
16213/?
16724/?
17236/?
17674/?
18186/?
18695/?
19209/?
19718/?
20228/?
20804/?
21369/?
21942/?
22453/?
22963/?
23532/?
24326/?
24837/?
25348/?
25924/?
28467/?
28909/?
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala>
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/test/scala>
[INFO] includes = [/*.scala,/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala>:-1: info: compiling
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1287113753379
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:74: error: trait IValidator takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:75: error: trait IValidatable takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:104: error: trait IModel takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:104: error: too many arguments for constructor Object: ()java.lang.Object
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:121: error: trait IModel takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:136: error: trait IModel takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:141: error: type mismatch;
[INFO] “”".trim)
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:153: error: value add is not a member of CssDemoPage.this.UpdatingTextArea
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:154: error: overloaded method value add with alternatives:
[INFO] (<repeated…>[org.apache.wicket.Component])org.apache.wicket.MarkupContainer
[INFO] (<repeated…>[org.apache.wicket.behavior.IBehavior])org.apache.wicket.Component
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:156: error: class Form takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:188: error: trait IModel takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:282: error: trait IChoiceRenderer takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/CssDemoPage.scala>:314: error: trait IChoiceRenderer takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/SummaryTable.scala>:81: error: trait IModel takes type parameters
[INFO] ^
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala/org/geoserver/community/css/web/SummaryTable.scala>:117: error: trait IModel takes type parameters
[INFO] ^
[ERROR] BUILD ERROR
  • cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-15-bin.zip
    cp: cannot stat `target/release/geoserver*-bin.zip’: No such file or directory
Download new Adobe(R) Flash(R) Builder™ 4
The new Adobe(R) Flex(R) 4 and Flash(R) Builder™ 4 (formerly
Flex(R) Builder™) enable the development of rich applications that run
across multiple browsers and platforms. Download your free trials today!
http://p.sf.net/sfu/adobe-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/466/changes&gt;
Changes:
[jdeolive] documenting how to add shapefiles that already exist on the server
[jdeolive] GEOS-3999, handling alternate upload types for datastores
[groldan] GEOS-4182: avoid legend graphic response ambiguity by implementing Response.canHandle
[...truncated 864 lines...]
[INFO] Copying 8 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/src/main/resources&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target&gt;
[INFO] Copying 10 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target&gt;
[INFO] Copying 20 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/src/main/resources&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target&gt;
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/resources&gt;
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/classes&gt;
[INFO] Copying 78 resources
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-tests.jar&gt;
[INFO] snapshot org.geoserver.maven:config:2.1-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/../../../data/release&gt;
     [copy] Copying 437 files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data&gt;
     [copy] Copied 63 empty directories to 1 empty directory under <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[1694 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver.war&gt;
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer CSS Styling
[INFO] artifact org.scala-tools:maven-scala-plugin: checking for updates from scala-tools.org
[INFO] excludes =
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes&gt; at 1287200157708
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] """.trim)
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 1 minute 58 seconds
[INFO] Finished at: Sat Oct 16 03:36:03 UTC 2010
[INFO] Final Memory: 78M/312M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-16-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/467/&gt;
[...truncated 854 lines...]
clean:
config:
[INFO] Webapp assembled in[1024 msecs]
[INFO] excludes =
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes&gt; at 1287286500436
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] """.trim)
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 1 minute 53 seconds
[INFO] Finished at: Sun Oct 17 03:35:06 UTC 2010
[INFO] Final Memory: 78M/313M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-17-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/468/&gt;
clean:
config:
[INFO] Webapp assembled in[1014 msecs]
[INFO] excludes =
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes&gt; at 1287372893426
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] """.trim)
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[ERROR] BUILD ERROR
[INFO] Total time: 1 minute 52 seconds
[INFO] Finished at: Mon Oct 18 03:35:01 UTC 2010
[INFO] Final Memory: 77M/304M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-18-bin.zip
Okay, I’ll update the CSS module when I have some time. You may want to disable it in nightlies for now to reduce the noise if you haven’t already.
David Winslow
OpenGeo - http://opengeo.org/
On Fri, Oct 15, 2010 at 9:49 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi David,
-Justin
Changes:
2/104K
4/104K
5/104K
7/104K
8/104K
9/104K
11/104K
12/104K
14/104K
15/104K
16/104K
18/104K
19/104K
21/104K
22/104K
24/104K
25/104K
26/104K
28/104K
29/104K
31/104K
32/104K
33/104K
35/104K
36/104K
38/104K
39/104K
41/104K
42/104K
43/104K
45/104K
46/104K
48/104K
49/104K
50/104K
52/104K
53/104K
55/104K
56/104K
57/104K
59/104K
60/104K
62/104K
63/104K
65/104K
66/104K
67/104K
69/104K
70/104K
72/104K
73/104K
74/104K
76/104K
77/104K
79/104K
80/104K
82/104K
83/104K
84/104K
86/104K
87/104K
89/104K
90/104K
91/104K
93/104K
94/104K
96/104K
97/104K
98/104K
100/104K
101/104K
103/104K
104/104K
821/?
2417/?
4771/?
5074/?
799/?
3163/?
6543/?
9051/?
9337/?
773/?
1989/?
6085/?
6450/?
10546/?
10858/?
14084/?
16242/?
19239/?
22634/?
717/?
1251/?
1763/?
2274/?
2785/?
3297/?
3808/?
4296/?
4807/?
5408/?
5971/?
6489/?
7000/?
7511/?
8024/?
8600/?
9170/?
9682/?
10194/?
10705/?
11271/?
11851/?
12363/?
12990/?
13539/?
14052/?
14618/?
15191/?
15702/?
16213/?
16724/?
17236/?
17674/?
18186/?
18695/?
19209/?
19718/?
20228/?
20804/?
21369/?
21942/?
22453/?
22963/?
23532/?
24326/?
24837/?
25348/?
25924/?
28467/?
28909/?
[INFO] excludes =
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] “”".trim)
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[ERROR] BUILD ERROR
Justin Deoliveira
Ok, i have gone ahead and disabled it (and its artifact descriptor) for now to restore the nightly build.
On Mon, Oct 18, 2010 at 10:28 AM, David Winslow <dwinslow@anonymised.com> wrote:
David Winslow
Hi David,
-Justin
Changes:
2/104K
4/104K
5/104K
7/104K
8/104K
9/104K
11/104K
12/104K
14/104K
15/104K
16/104K
18/104K
19/104K
21/104K
22/104K
24/104K
25/104K
26/104K
28/104K
29/104K
31/104K
32/104K
33/104K
35/104K
36/104K
38/104K
39/104K
41/104K
42/104K
43/104K
45/104K
46/104K
48/104K
49/104K
50/104K
52/104K
53/104K
55/104K
56/104K
57/104K
59/104K
60/104K
62/104K
63/104K
65/104K
66/104K
67/104K
69/104K
70/104K
72/104K
73/104K
74/104K
76/104K
77/104K
79/104K
80/104K
82/104K
83/104K
84/104K
86/104K
87/104K
89/104K
90/104K
91/104K
93/104K
94/104K
96/104K
97/104K
98/104K
100/104K
101/104K
103/104K
104/104K
821/?
2417/?
4771/?
5074/?
799/?
3163/?
6543/?
9051/?
9337/?
773/?
1989/?
6085/?
6450/?
10546/?
10858/?
14084/?
16242/?
19239/?
22634/?
717/?
1251/?
1763/?
2274/?
2785/?
3297/?
3808/?
4296/?
4807/?
5408/?
5971/?
6489/?
7000/?
7511/?
8024/?
8600/?
9170/?
9682/?
10194/?
10705/?
11271/?
11851/?
12363/?
12990/?
13539/?
14052/?
14618/?
15191/?
15702/?
16213/?
16724/?
17236/?
17674/?
18186/?
18695/?
19209/?
19718/?
20228/?
20804/?
21369/?
21942/?
22453/?
22963/?
23532/?
24326/?
24837/?
25348/?
25924/?
28467/?
28909/?
[INFO] excludes =
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] “”".trim)
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[INFO] ^
[ERROR] BUILD ERROR
Justin Deoliveira
Justin Deoliveira
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/469/changes&gt;
Changes:
[jdeolive] temporarily disabling css module until its ported to wicket 1.4
[...truncated 979 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target&gt;
[INFO] Copying 18 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridAnalysis:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridAnalysis:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '750dd2c8500ddd601b56db01f06525b7a8e490dc'; remote = '2f32cde523988d8fe2fd4e0cf315d56c0a717d7c' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '750dd2c8500ddd601b56db01f06525b7a8e490dc'; remote = '2f32cde523988d8fe2fd4e0cf315d56c0a717d7c' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridAnalysis/0.6-SNAPSHOT/sextante_gridAnalysis-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante:lib:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante:lib:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '17700994acc169a6b6c2eddc893b51a864e86b7d'; remote = '66a36e5ef9059a4c6b4483f8305117d93b6dc24d' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '17700994acc169a6b6c2eddc893b51a864e86b7d'; remote = '66a36e5ef9059a4c6b4483f8305117d93b6dc24d' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/0.6-SNAPSHOT/lib-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante:sextante:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante:sextante:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '8b59cd348927c0b6880f89664d918621bd0019c1'; remote = 'd0a4ebd8470af834a18ee4f3d9643c65ec4ca942' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '8b59cd348927c0b6880f89664d918621bd0019c1'; remote = 'd0a4ebd8470af834a18ee4f3d9643c65ec4ca942' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '52868339fc40b2528316a1b860a44cb618285e42'; remote = 'fc9fbbfcec5f80ad4501b88e3652be145798ca98' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '52868339fc40b2528316a1b860a44cb618285e42'; remote = 'fc9fbbfcec5f80ad4501b88e3652be145798ca98' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:libMath:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:libMath:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '80066aa1ea3463a7603ab7f1b65c4e85a2447525'; remote = 'cbdd7621ccf0713b83727eac237174cc1172d19d' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '80066aa1ea3463a7603ab7f1b65c4e85a2447525'; remote = 'cbdd7621ccf0713b83727eac237174cc1172d19d' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libMath/0.6-SNAPSHOT/libMath-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:libDocEngines:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:libDocEngines:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '6f33fce4eaa182c207b7645ea97817801c81f788'; remote = 'd4577fb57b5f467f89ebdb717cd077a05c4de35e' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '6f33fce4eaa182c207b7645ea97817801c81f788'; remote = 'd4577fb57b5f467f89ebdb717cd077a05c4de35e' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libDocEngines/0.6-SNAPSHOT/libDocEngines-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridCalculus:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridCalculus:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '787e278bd609d6b2bb9c2b69716df24064afc255'; remote = '287a8019d684469fcc171d9f1cce8d9df66119b0' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '787e278bd609d6b2bb9c2b69716df24064afc255'; remote = '287a8019d684469fcc171d9f1cce8d9df66119b0' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCalculus/0.6-SNAPSHOT/sextante_gridCalculus-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gui:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gui:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '75bd0015ec5c3423614caad969df460a604fcedd'; remote = 'c115ef0a3f45adadefce0d9afee8754415bff6c0' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '75bd0015ec5c3423614caad969df460a604fcedd'; remote = 'c115ef0a3f45adadefce0d9afee8754415bff6c0' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gui/0.6-SNAPSHOT/sextante_gui-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_wps:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_wps:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2e88732b6a5d07fc4555110a5f078b987dfeac71'; remote = '5150a7e59e642801bda4d91c50779c1fa25e51ad' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2e88732b6a5d07fc4555110a5f078b987dfeac71'; remote = '5150a7e59e642801bda4d91c50779c1fa25e51ad' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_wps/0.6-SNAPSHOT/sextante_wps-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridCategorical:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridCategorical:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2af87b9fb8f21fe08dbcbdcaabac8582de0663e7'; remote = '36a662e1b0a05fe92d7eb16d37e20c7125871fd8' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2af87b9fb8f21fe08dbcbdcaabac8582de0663e7'; remote = '36a662e1b0a05fe92d7eb16d37e20c7125871fd8' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCategorical/0.6-SNAPSHOT/sextante_gridCategorical-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridStatistics:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridStatistics:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd2f497f0671ca22fb6eb18a858eb2040db943987'; remote = 'e8699f6b4ec48c91ba1846cca13ad8d369dcc27a' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd2f497f0671ca22fb6eb18a858eb2040db943987'; remote = 'e8699f6b4ec48c91ba1846cca13ad8d369dcc27a' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridStatistics/0.6-SNAPSHOT/sextante_gridStatistics-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridTools:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridTools:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0cac63948c11a4f83a002bb24b217ee2a789d5a6'; remote = '52809e0d146b0e260c5094fabad775c4d6503659' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0cac63948c11a4f83a002bb24b217ee2a789d5a6'; remote = '52809e0d146b0e260c5094fabad775c4d6503659' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridTools/0.6-SNAPSHOT/sextante_gridTools-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_hydrology:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_hydrology:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd59cd639e6d3227a3083c832f13268ad7cdb456f'; remote = '7f76b5429b3592ef8b6ddde313aca5634731565a' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd59cd639e6d3227a3083c832f13268ad7cdb456f'; remote = '7f76b5429b3592ef8b6ddde313aca5634731565a' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_hydrology/0.6-SNAPSHOT/sextante_hydrology-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_morphometry:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_morphometry:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cf858d7742af19560a8a73a0509135874ae3ab52'; remote = '9fff2efbb9495e1f626d92ecc00bac67c3e8e2f7' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cf858d7742af19560a8a73a0509135874ae3ab52'; remote = '9fff2efbb9495e1f626d92ecc00bac67c3e8e2f7' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_morphometry/0.6-SNAPSHOT/sextante_morphometry-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_lighting:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_lighting:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0a003277ce5eafc32ae379db90ccebbd50cba53d'; remote = '7862dc1a3bf4c2d4b8d1b085cb5463d80c6751b7' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0a003277ce5eafc32ae379db90ccebbd50cba53d'; remote = '7862dc1a3bf4c2d4b8d1b085cb5463d80c6751b7' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_lighting/0.6-SNAPSHOT/sextante_lighting-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_locate:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_locate:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '806ef7dc7707b8615d3f8f7f3b16e487a5e33690'; remote = '529b205f46c973f125985a20c8af98b325ee3693' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '806ef7dc7707b8615d3f8f7f3b16e487a5e33690'; remote = '529b205f46c973f125985a20c8af98b325ee3693' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_locate/0.6-SNAPSHOT/sextante_locate-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_pointAnalysis:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_pointAnalysis:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '74b30ceec3a382c013ce23d85e7a1fcf4928dd9c'; remote = '8c0d795e5210cc607d0f705640aa472c64e0ead4' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '74b30ceec3a382c013ce23d85e7a1fcf4928dd9c'; remote = '8c0d795e5210cc607d0f705640aa472c64e0ead4' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_pointAnalysis/0.6-SNAPSHOT/sextante_pointAnalysis-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_profiles:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_profiles:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cce019ba690c8296362cb6588f2fe68ada707b39'; remote = '24729f63a587777100f94a85578aeedd718406e2' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cce019ba690c8296362cb6588f2fe68ada707b39'; remote = '24729f63a587777100f94a85578aeedd718406e2' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_profiles/0.6-SNAPSHOT/sextante_profiles-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_rasterize:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_rasterize:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cd341cf34e44e0db21d24a266e92b77ada454375'; remote = '3514c3c32e89ffbb6b6e2575984aad880ac3f4ec' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cd341cf34e44e0db21d24a266e92b77ada454375'; remote = '3514c3c32e89ffbb6b6e2575984aad880ac3f4ec' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_rasterize/0.6-SNAPSHOT/sextante_rasterize-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_tables:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_tables:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '83912a190ab74b3cd7f3f08862a2b81db6d876ed'; remote = '3894378c1c89d578e9cb703c4dae18267324438f' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '83912a190ab74b3cd7f3f08862a2b81db6d876ed'; remote = '3894378c1c89d578e9cb703c4dae18267324438f' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_tables/0.6-SNAPSHOT/sextante_tables-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_topology:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_topology:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '59aeafe2a89d7baba20b63849afa990c8f978156'; remote = '8bec1fffdeb0d4a341fba8dd34005e41b2174163' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '59aeafe2a89d7baba20b63849afa990c8f978156'; remote = '8bec1fffdeb0d4a341fba8dd34005e41b2174163' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_topology/0.6-SNAPSHOT/sextante_topology-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_vectorTools:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_vectorTools:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0ec9324f43ef14cd57cfd06f15a654b802cce3c0'; remote = '1e797a717819b5742cb39618071f4dda4b52c41c' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0ec9324f43ef14cd57cfd06f15a654b802cce3c0'; remote = '1e797a717819b5742cb39618071f4dda4b52c41c' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorTools/0.6-SNAPSHOT/sextante_vectorTools-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_vectorize:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_vectorize:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '35ade3e324fe1a66ed52b54a179e2927ce47e58c'; remote = 'b953d4cfe262d85f017e906534a508b7666a1da4' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '35ade3e324fe1a66ed52b54a179e2927ce47e58c'; remote = 'b953d4cfe262d85f017e906534a508b7666a1da4' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorize/0.6-SNAPSHOT/sextante_vectorize-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_vegetationIndices:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_vegetationIndices:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '7d36ad53041e0375290a75dcd659bdb51cdae7df'; remote = '01f6c00ca17143ef6b989d5e816043c397f90e61' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '7d36ad53041e0375290a75dcd659bdb51cdae7df'; remote = '01f6c00ca17143ef6b989d5e816043c397f90e61' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vegetationIndices/0.6-SNAPSHOT/sextante_vegetationIndices-0.6-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridAnalysis/0.6-SNAPSHOT/sextante_gridAnalysis-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libMath/0.6-SNAPSHOT/libMath-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libDocEngines/0.6-SNAPSHOT/libDocEngines-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCalculus/0.6-SNAPSHOT/sextante_gridCalculus-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gui/0.6-SNAPSHOT/sextante_gui-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_wps/0.6-SNAPSHOT/sextante_wps-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCategorical/0.6-SNAPSHOT/sextante_gridCategorical-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridStatistics/0.6-SNAPSHOT/sextante_gridStatistics-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridTools/0.6-SNAPSHOT/sextante_gridTools-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_hydrology/0.6-SNAPSHOT/sextante_hydrology-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_morphometry/0.6-SNAPSHOT/sextante_morphometry-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_lighting/0.6-SNAPSHOT/sextante_lighting-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_locate/0.6-SNAPSHOT/sextante_locate-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_pointAnalysis/0.6-SNAPSHOT/sextante_pointAnalysis-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_profiles/0.6-SNAPSHOT/sextante_profiles-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_rasterize/0.6-SNAPSHOT/sextante_rasterize-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_tables/0.6-SNAPSHOT/sextante_tables-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_topology/0.6-SNAPSHOT/sextante_topology-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorTools/0.6-SNAPSHOT/sextante_vectorTools-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorize/0.6-SNAPSHOT/sextante_vectorize-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vegetationIndices/0.6-SNAPSHOT/sextante_vegetationIndices-0.6-SNAPSHOT.jar
[INFO] Compiling 115 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[56,16\] cannot find symbol
symbol : method setModel(org.apache.wicket.model.PropertyModel)
location: class org.geoserver.web.wps.ComplexInputPanel
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[57,47\] cannot find symbol
symbol : method getModel()
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[64,32\] cannot find symbol
symbol : method getModelObject()
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[75,48\] cannot find symbol
location: class org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[108,58\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[143,59\] cannot find symbol
symbol : method getModelObjectAsString()
location: class org.apache.wicket.markup.html.form.DropDownChoice
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/ComplexInputPanel.java&gt;:\[204,56\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/WPSRequestBuilder.java&gt;:\[73,62\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/WPSRequestBuilder.java&gt;:\[83,46\] cannot find symbol
symbol : method setModel(org.apache.wicket.model.Model)
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/RequestBuilderPanel.java&gt;:\[185,64\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/RequestBuilderPanel.java&gt;:\[198,54\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/BoundingBoxInputPanel.java&gt;:\[40,16\] cannot find symbol
location: class org.geoserver.web.wps.BoundingBoxInputPanel
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/BoundingBoxInputPanel.java&gt;:\[41,47\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/BoundingBoxInputPanel.java&gt;:\[45,32\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/BoundingBoxInputPanel.java&gt;:\[76,58\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/web/wps/BoundingBoxInputPanel.java&gt;:\[107,59\] cannot find symbol
[INFO] Finished at: Tue Oct 19 03:35:11 UTC 2010
[INFO] Final Memory: 70M/309M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-19-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/470/changes&gt;
