See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/480/changes>
Changes:
[aaime] [GEOS-4203] DescribeFeatureType should be working even when the namespace is not specified
[dwinslow] Re-enable CSS module now that it is compiling again
[aaime] [GEOS-4199] Improve shapefile output traceability and flexibility
[...truncated 1080 lines...]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target>
[INFO] Copying 5 resources
[INFO] Copying 2 resources
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.pom
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/classes>
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Embedded FTP server
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target>
[INFO] Copying 1 resource
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/src/test/java>
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.1-SNAPSHOT/ftp-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target>
[INFO] Copying 18 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/resources>
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridAnalysis:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridAnalysis:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '750dd2c8500ddd601b56db01f06525b7a8e490dc'; remote = '2f32cde523988d8fe2fd4e0cf315d56c0a717d7c' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '750dd2c8500ddd601b56db01f06525b7a8e490dc'; remote = '2f32cde523988d8fe2fd4e0cf315d56c0a717d7c' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridAnalysis/0.6-SNAPSHOT/sextante_gridAnalysis-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante:lib:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante:lib:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '17700994acc169a6b6c2eddc893b51a864e86b7d'; remote = '66a36e5ef9059a4c6b4483f8305117d93b6dc24d' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '17700994acc169a6b6c2eddc893b51a864e86b7d'; remote = '66a36e5ef9059a4c6b4483f8305117d93b6dc24d' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/0.6-SNAPSHOT/lib-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante:sextante:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante:sextante:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '8b59cd348927c0b6880f89664d918621bd0019c1'; remote = 'd0a4ebd8470af834a18ee4f3d9643c65ec4ca942' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '8b59cd348927c0b6880f89664d918621bd0019c1'; remote = 'd0a4ebd8470af834a18ee4f3d9643c65ec4ca942' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '52868339fc40b2528316a1b860a44cb618285e42'; remote = 'fc9fbbfcec5f80ad4501b88e3652be145798ca98' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '52868339fc40b2528316a1b860a44cb618285e42'; remote = 'fc9fbbfcec5f80ad4501b88e3652be145798ca98' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:libMath:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:libMath:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '80066aa1ea3463a7603ab7f1b65c4e85a2447525'; remote = 'cbdd7621ccf0713b83727eac237174cc1172d19d' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '80066aa1ea3463a7603ab7f1b65c4e85a2447525'; remote = 'cbdd7621ccf0713b83727eac237174cc1172d19d' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libMath/0.6-SNAPSHOT/libMath-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:libDocEngines:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:libDocEngines:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '6f33fce4eaa182c207b7645ea97817801c81f788'; remote = 'd4577fb57b5f467f89ebdb717cd077a05c4de35e' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '6f33fce4eaa182c207b7645ea97817801c81f788'; remote = 'd4577fb57b5f467f89ebdb717cd077a05c4de35e' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libDocEngines/0.6-SNAPSHOT/libDocEngines-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridCalculus:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridCalculus:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '787e278bd609d6b2bb9c2b69716df24064afc255'; remote = '287a8019d684469fcc171d9f1cce8d9df66119b0' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '787e278bd609d6b2bb9c2b69716df24064afc255'; remote = '287a8019d684469fcc171d9f1cce8d9df66119b0' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCalculus/0.6-SNAPSHOT/sextante_gridCalculus-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gui:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gui:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '75bd0015ec5c3423614caad969df460a604fcedd'; remote = 'c115ef0a3f45adadefce0d9afee8754415bff6c0' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '75bd0015ec5c3423614caad969df460a604fcedd'; remote = 'c115ef0a3f45adadefce0d9afee8754415bff6c0' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gui/0.6-SNAPSHOT/sextante_gui-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_wps:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_wps:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2e88732b6a5d07fc4555110a5f078b987dfeac71'; remote = '5150a7e59e642801bda4d91c50779c1fa25e51ad' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2e88732b6a5d07fc4555110a5f078b987dfeac71'; remote = '5150a7e59e642801bda4d91c50779c1fa25e51ad' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_wps/0.6-SNAPSHOT/sextante_wps-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridCategorical:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridCategorical:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2af87b9fb8f21fe08dbcbdcaabac8582de0663e7'; remote = '36a662e1b0a05fe92d7eb16d37e20c7125871fd8' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2af87b9fb8f21fe08dbcbdcaabac8582de0663e7'; remote = '36a662e1b0a05fe92d7eb16d37e20c7125871fd8' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCategorical/0.6-SNAPSHOT/sextante_gridCategorical-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridStatistics:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridStatistics:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd2f497f0671ca22fb6eb18a858eb2040db943987'; remote = 'e8699f6b4ec48c91ba1846cca13ad8d369dcc27a' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd2f497f0671ca22fb6eb18a858eb2040db943987'; remote = 'e8699f6b4ec48c91ba1846cca13ad8d369dcc27a' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridStatistics/0.6-SNAPSHOT/sextante_gridStatistics-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_gridTools:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_gridTools:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0cac63948c11a4f83a002bb24b217ee2a789d5a6'; remote = '52809e0d146b0e260c5094fabad775c4d6503659' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0cac63948c11a4f83a002bb24b217ee2a789d5a6'; remote = '52809e0d146b0e260c5094fabad775c4d6503659' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridTools/0.6-SNAPSHOT/sextante_gridTools-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_hydrology:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_hydrology:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd59cd639e6d3227a3083c832f13268ad7cdb456f'; remote = '7f76b5429b3592ef8b6ddde313aca5634731565a' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd59cd639e6d3227a3083c832f13268ad7cdb456f'; remote = '7f76b5429b3592ef8b6ddde313aca5634731565a' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_hydrology/0.6-SNAPSHOT/sextante_hydrology-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_morphometry:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_morphometry:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cf858d7742af19560a8a73a0509135874ae3ab52'; remote = '9fff2efbb9495e1f626d92ecc00bac67c3e8e2f7' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cf858d7742af19560a8a73a0509135874ae3ab52'; remote = '9fff2efbb9495e1f626d92ecc00bac67c3e8e2f7' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_morphometry/0.6-SNAPSHOT/sextante_morphometry-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_lighting:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_lighting:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0a003277ce5eafc32ae379db90ccebbd50cba53d'; remote = '7862dc1a3bf4c2d4b8d1b085cb5463d80c6751b7' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0a003277ce5eafc32ae379db90ccebbd50cba53d'; remote = '7862dc1a3bf4c2d4b8d1b085cb5463d80c6751b7' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_lighting/0.6-SNAPSHOT/sextante_lighting-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_locate:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_locate:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '806ef7dc7707b8615d3f8f7f3b16e487a5e33690'; remote = '529b205f46c973f125985a20c8af98b325ee3693' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '806ef7dc7707b8615d3f8f7f3b16e487a5e33690'; remote = '529b205f46c973f125985a20c8af98b325ee3693' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_locate/0.6-SNAPSHOT/sextante_locate-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_pointAnalysis:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_pointAnalysis:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '74b30ceec3a382c013ce23d85e7a1fcf4928dd9c'; remote = '8c0d795e5210cc607d0f705640aa472c64e0ead4' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '74b30ceec3a382c013ce23d85e7a1fcf4928dd9c'; remote = '8c0d795e5210cc607d0f705640aa472c64e0ead4' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_pointAnalysis/0.6-SNAPSHOT/sextante_pointAnalysis-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_profiles:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_profiles:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cce019ba690c8296362cb6588f2fe68ada707b39'; remote = '24729f63a587777100f94a85578aeedd718406e2' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cce019ba690c8296362cb6588f2fe68ada707b39'; remote = '24729f63a587777100f94a85578aeedd718406e2' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_profiles/0.6-SNAPSHOT/sextante_profiles-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_rasterize:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_rasterize:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cd341cf34e44e0db21d24a266e92b77ada454375'; remote = '3514c3c32e89ffbb6b6e2575984aad880ac3f4ec' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cd341cf34e44e0db21d24a266e92b77ada454375'; remote = '3514c3c32e89ffbb6b6e2575984aad880ac3f4ec' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_rasterize/0.6-SNAPSHOT/sextante_rasterize-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_tables:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_tables:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '83912a190ab74b3cd7f3f08862a2b81db6d876ed'; remote = '3894378c1c89d578e9cb703c4dae18267324438f' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '83912a190ab74b3cd7f3f08862a2b81db6d876ed'; remote = '3894378c1c89d578e9cb703c4dae18267324438f' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_tables/0.6-SNAPSHOT/sextante_tables-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_topology:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_topology:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '59aeafe2a89d7baba20b63849afa990c8f978156'; remote = '8bec1fffdeb0d4a341fba8dd34005e41b2174163' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '59aeafe2a89d7baba20b63849afa990c8f978156'; remote = '8bec1fffdeb0d4a341fba8dd34005e41b2174163' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_topology/0.6-SNAPSHOT/sextante_topology-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_vectorTools:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_vectorTools:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0ec9324f43ef14cd57cfd06f15a654b802cce3c0'; remote = '1e797a717819b5742cb39618071f4dda4b52c41c' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0ec9324f43ef14cd57cfd06f15a654b802cce3c0'; remote = '1e797a717819b5742cb39618071f4dda4b52c41c' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorTools/0.6-SNAPSHOT/sextante_vectorTools-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_vectorize:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_vectorize:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '35ade3e324fe1a66ed52b54a179e2927ce47e58c'; remote = 'b953d4cfe262d85f017e906534a508b7666a1da4' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '35ade3e324fe1a66ed52b54a179e2927ce47e58c'; remote = 'b953d4cfe262d85f017e906534a508b7666a1da4' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorize/0.6-SNAPSHOT/sextante_vectorize-0.6-SNAPSHOT.pom
[INFO] snapshot es.unex.sextante.lib:sextante_vegetationIndices:0.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot es.unex.sextante.lib:sextante_vegetationIndices:0.6-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '7d36ad53041e0375290a75dcd659bdb51cdae7df'; remote = '01f6c00ca17143ef6b989d5e816043c397f90e61' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '7d36ad53041e0375290a75dcd659bdb51cdae7df'; remote = '01f6c00ca17143ef6b989d5e816043c397f90e61' - IGNORING
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vegetationIndices/0.6-SNAPSHOT/sextante_vegetationIndices-0.6-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridAnalysis/0.6-SNAPSHOT/sextante_gridAnalysis-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante/0.6-SNAPSHOT/sextante-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libMath/0.6-SNAPSHOT/libMath-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/libDocEngines/0.6-SNAPSHOT/libDocEngines-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCalculus/0.6-SNAPSHOT/sextante_gridCalculus-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gui/0.6-SNAPSHOT/sextante_gui-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_wps/0.6-SNAPSHOT/sextante_wps-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridCategorical/0.6-SNAPSHOT/sextante_gridCategorical-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridStatistics/0.6-SNAPSHOT/sextante_gridStatistics-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_gridTools/0.6-SNAPSHOT/sextante_gridTools-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_hydrology/0.6-SNAPSHOT/sextante_hydrology-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_morphometry/0.6-SNAPSHOT/sextante_morphometry-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_lighting/0.6-SNAPSHOT/sextante_lighting-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_locate/0.6-SNAPSHOT/sextante_locate-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_pointAnalysis/0.6-SNAPSHOT/sextante_pointAnalysis-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_profiles/0.6-SNAPSHOT/sextante_profiles-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_rasterize/0.6-SNAPSHOT/sextante_rasterize-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_tables/0.6-SNAPSHOT/sextante_tables-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_topology/0.6-SNAPSHOT/sextante_topology-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorTools/0.6-SNAPSHOT/sextante_vectorTools-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vectorize/0.6-SNAPSHOT/sextante_vectorize-0.6-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//es/unex/sextante/lib/sextante_vegetationIndices/0.6-SNAPSHOT/sextante_vegetationIndices-0.6-SNAPSHOT.jar
[INFO] Compiling 115 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/wps/src/main/java/org/geoserver/wps/ppio/ShapeZipPPIO.java>:\[48,10\] cannot find symbol
symbol : method write(java.util.List<org.geotools.data.simple.SimpleFeatureCollection>,java.nio.charset.Charset,java.io.OutputStream)
location: class org.geoserver.wfs.response.ShapeZipOutputFormat
[INFO] Total time: 2 minutes 23 seconds
[INFO] Finished at: Thu Oct 28 03:35:46 UTC 2010
[INFO] Final Memory: 82M/312M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-10-28-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
