See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/603/changes>
Changes:
[groldan] GEOS-4366: make GWC direct WMS integration work with layergroups
[jdeolive] fixing typo in HeaderContribution referencing cssFilename in getJavaScript()
[groldan] get rid of gwc-wfs
[aaime] Adding the querylayer module to the community release profile
[aaime] Using GeoTools version of the GeometryCollector
[...truncated 4347 lines...]
[INFO] Copying xpp3_min-1.1.4c.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/release/target/dependency/xpp3_min-1.1.4c.jar>
[INFO] gt-api-2.8-SNAPSHOT.jar already exists in destination.
[INFO] [antrun:run {execution: default}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [35.570s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [0.262s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [2.183s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [0.154s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [0.402s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [0.311s]
[INFO] Core Platform Module .................................. SUCCESS [9.806s]
[INFO] Open Web Service Module ............................... SUCCESS [13.191s]
[INFO] Main Module ........................................... SUCCESS [29.888s]
[INFO] Web Coverage Service Module ........................... SUCCESS [3.513s]
[INFO] Web Coverage Service 1.0 Module ....................... SUCCESS [6.981s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [6.962s]
[INFO] Web Feature Service Module ............................ SUCCESS [11.856s]
[INFO] Web Map Service Module ................................ SUCCESS [16.807s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [9.788s]
[INFO] REST Support Module ................................... SUCCESS [4.559s]
[INFO] REST Configuration Service Module ..................... SUCCESS [9.820s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.151s]
[INFO] Core UI Module ........................................ SUCCESS [40.463s]
[INFO] WMS UI Module ......................................... SUCCESS [5.043s]
[INFO] GWC UI Module ......................................... SUCCESS [2.623s]
[INFO] WFS UI Module ......................................... SUCCESS [3.789s]
[INFO] Demoes Module ......................................... SUCCESS [5.644s]
[INFO] WCS UI Module ......................................... SUCCESS [4.112s]
[INFO] Security UI Module .................................... SUCCESS [5.699s]
[INFO] GeoServer Web Application ............................. SUCCESS [26.814s]
[INFO] Community Space ....................................... SUCCESS [2.133s]
[INFO] GeoServer CSS Styling ................................. SUCCESS [46.636s]
[INFO] Printing Module ....................................... SUCCESS [6.106s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [2.196s]
[INFO] GeoServer Monitoring Extension ........................ SUCCESS [9.415s]
[INFO] SpatiaLite DataStore Extension ........................ SUCCESS [1.931s]
[INFO] Hibernate Catalog/Configuration Module ................ SUCCESS [6.619s]
[INFO] GeoServer INSPIRE Extensions .......................... SUCCESS [3.988s]
[INFO] GeoServer Layer Querying filter functions ............. SUCCESS [2.466s]
[INFO] GeoServer Community Release Module .................... SUCCESS [2.013s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.845s]
[INFO] Application Schema Support ............................ SUCCESS [1.278s]
[INFO] Application Schema Integration Test ................... SUCCESS [5.336s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [1.864s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [5.917s]
[INFO] GeoSearch Index Module ................................ SUCCESS [5.005s]
[INFO] H2 DataStore Extension ................................ SUCCESS [2.417s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.429s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.150s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.401s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [5.950s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.334s]
[INFO] ImageMap Output Format ................................ SUCCESS [5.158s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.871s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [4.380s]
[INFO] Excel Output Format ................................... SUCCESS [2.854s]
[INFO] Validation Module ..................................... SUCCESS [1.717s]
[INFO] Chart external graphics support ....................... SUCCESS [0.650s]
[INFO] Feature Generalization Extension ...................... SUCCESS [1.722s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [0.415s]
[INFO] OWS request flow controller ........................... SUCCESS [3.428s]
[INFO] Web Processing Service parent ......................... SUCCESS [0.289s]
[INFO] Web Processing Service Module ......................... SUCCESS [29.807s]
[INFO] Web Processing Service GUI ............................ SUCCESS [4.997s]
[INFO] GeoServer Release Module .............................. SUCCESS [5.593s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 7 minutes 26 seconds
[INFO] Finished at: Thu Feb 10 03:40:48 UTC 2011
[INFO] Final Memory: 101M/362M
+ mvn assembly:attached
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Main Module
[INFO] Building GeoServer
[INFO] task-segment: [assembly:attached] (aggregator-style)
[INFO] snapshot org.geoserver:platform:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '890bec083a01304171d3f048009b36ddc012111d'; remote = 'a577cae6ff8225ad2c9aecf98e5e763e259dbc61' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '890bec083a01304171d3f048009b36ddc012111d'; remote = 'a577cae6ff8225ad2c9aecf98e5e763e259dbc61' - IGNORING
[INFO] snapshot org.geoserver:platform:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:ows:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3cc0718a5239dbda243f2ee62d2e9039b9024554'; remote = 'ed76327ff93aaf9c481d2570cfd04c5549b62bc7' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3cc0718a5239dbda243f2ee62d2e9039b9024554'; remote = 'ed76327ff93aaf9c481d2570cfd04c5549b62bc7' - IGNORING
[INFO] snapshot org.geoserver:ows:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:main:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'a11ac1e13da25c5ae863ece556815d8b333f1a8f'; remote = 'abe07e94f7433938846a405a918b8a093ddae536' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'a11ac1e13da25c5ae863ece556815d8b333f1a8f'; remote = 'abe07e94f7433938846a405a918b8a093ddae536' - IGNORING
[INFO] snapshot org.geoserver:main:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd059d2cb987db7535a83e33c992dbf26f8228b6d'; remote = '2585bcd9cc070e07152a3f9dda3f999797c960a3' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd059d2cb987db7535a83e33c992dbf26f8228b6d'; remote = '2585bcd9cc070e07152a3f9dda3f999797c960a3' - IGNORING
[INFO] snapshot org.geoserver:wcs:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wfs:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '30edf26077a1ec25ad45d51374310ab2bb3ca853'; remote = '86ac4d45589fea1d0292791326d04ddd4e230be1' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '30edf26077a1ec25ad45d51374310ab2bb3ca853'; remote = '86ac4d45589fea1d0292791326d04ddd4e230be1' - IGNORING
[INFO] snapshot org.geoserver:wfs:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wms:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '65007a8092b1d53166e1d1336ebfeda5c45964e8'; remote = '58d354ddaf23bb4651afdf51a057bc8b2d3d7fec' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '65007a8092b1d53166e1d1336ebfeda5c45964e8'; remote = '58d354ddaf23bb4651afdf51a057bc8b2d3d7fec' - IGNORING
[INFO] snapshot org.geoserver:wms:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:rest:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2df3282229725134aed732483bc69acf7d4a7981'; remote = '9e51bdaffb5c7a20b0e8844b44005ae26d540fe0' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2df3282229725134aed732483bc69acf7d4a7981'; remote = '9e51bdaffb5c7a20b0e8844b44005ae26d540fe0' - IGNORING
[INFO] snapshot org.geoserver:rest:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_0:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'dd9986c149bdcb3cbd86620008522e80d857e443'; remote = '1c54ce875f1d9afeea5657f31d339dfb86e40dc7' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'dd9986c149bdcb3cbd86620008522e80d857e443'; remote = '1c54ce875f1d9afeea5657f31d339dfb86e40dc7' - IGNORING
[INFO] snapshot org.geoserver:wcs1_0:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_1:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cf46d2d0f0d258307ddf70aa508920813787c3e0'; remote = '0b730123498b10966196fb6e30f76b4ff3a90b9d' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'cf46d2d0f0d258307ddf70aa508920813787c3e0'; remote = '0b730123498b10966196fb6e30f76b4ff3a90b9d' - IGNORING
[INFO] snapshot org.geoserver:wcs1_1:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-core:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '8354324455552762d9058dcb9abfb26016ec8304'; remote = '761f4f443aeb9fab09356a0aa7e9b3ee0a4fe335' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '8354324455552762d9058dcb9abfb26016ec8304'; remote = '761f4f443aeb9fab09356a0aa7e9b3ee0a4fe335' - IGNORING
[INFO] snapshot org.geoserver.web:web-core:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gwc:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd680222c6252413d48af32a2d0a13ac5d5002f94'; remote = '0212e87c9e7796ff7452db20473065f01823d307' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd680222c6252413d48af32a2d0a13ac5d5002f94'; remote = '0212e87c9e7796ff7452db20473065f01823d307' - IGNORING
[INFO] snapshot org.geoserver:gwc:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-demo:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '96dbc07bd4ee71c70ae28262efae5014c2f5a935'; remote = '1f45e940f6ea0b08ced5a121f6313de77ada6c41' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '96dbc07bd4ee71c70ae28262efae5014c2f5a935'; remote = '1f45e940f6ea0b08ced5a121f6313de77ada6c41' - IGNORING
[INFO] snapshot org.geoserver.web:web-demo:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wms:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:restconfig:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'b5ca8ecc67cc030bba84661bbe7152f7b07219d6'; remote = 'a28d1e22f06ed49d00272d539a8fee9c55e9fe36' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'b5ca8ecc67cc030bba84661bbe7152f7b07219d6'; remote = 'a28d1e22f06ed49d00272d539a8fee9c55e9fe36' - IGNORING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '5b6aeedcb3130488e32c730a75fb185e6a3f184e'; remote = 'f01bbda9a37944c5338fe592628ca5d2802c3fe1' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '5b6aeedcb3130488e32c730a75fb185e6a3f184e'; remote = 'f01bbda9a37944c5338fe592628ca5d2802c3fe1' - IGNORING
[INFO] snapshot org.geoserver.web:web-wms:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:restconfig:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-gwc:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '32626aca4369e367a9fa9c86eca48bc4a26b2df4'; remote = '37babbe9485a0a27fb34e2aabfab47f994c6fa2c' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '32626aca4369e367a9fa9c86eca48bc4a26b2df4'; remote = '37babbe9485a0a27fb34e2aabfab47f994c6fa2c' - IGNORING
[INFO] snapshot org.geoserver.web:web-gwc:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wfs:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd45540fbeb144b72a8521350482144b1d2eb317f'; remote = '90f8c0b970b5af8372af990dad3c96f0361012bd' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd45540fbeb144b72a8521350482144b1d2eb317f'; remote = '90f8c0b970b5af8372af990dad3c96f0361012bd' - IGNORING
[INFO] snapshot org.geoserver.web:web-wfs:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wcs:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'f74993c2d3897b08524e1e96b025b60583a02e4e'; remote = '67d03dbf5176f3c44d425d4bc8c4418166420afd' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'f74993c2d3897b08524e1e96b025b60583a02e4e'; remote = '67d03dbf5176f3c44d425d4bc8c4418166420afd' - IGNORING
[INFO] snapshot org.geoserver.web:web-wcs:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-security:2.2-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '867689d086f38af81266d4c8bcea8e72e9865dda'; remote = '34d863332595fd94031763f7404565ec907aa2a8' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '867689d086f38af81266d4c8bcea8e72e9865dda'; remote = '34d863332595fd94031763f7404565ec907aa2a8' - IGNORING
[INFO] snapshot org.geoserver.web:web-security:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] [assembly:attached {execution: default-cli}]
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-src.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-war.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-javadoc.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-bin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-doc.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-db2-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-feature-pregeneralized-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-imagemosaic-jdbc-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-jp2k-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-mysql-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-oracle-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-vpf-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-arcsde-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-pyramid-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-wfsv-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-gdal-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-h2-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-sqlserver-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-imagemap-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-ogr-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-excel-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-geosearch-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-charts-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-app-schema-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-control-flow-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/target/release/geoserver-2.2-SNAPSHOT-wps-plugin.zip>
[INFO] Total time: 2 minutes 17 seconds
[INFO] Finished at: Thu Feb 10 03:43:07 UTC 2011
[INFO] Final Memory: 34M/292M
+ cp target/release/geoserver-2.2-SNAPSHOT-war.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-02-10-war.zip
+ cp target/release/geoserver-2.2-SNAPSHOT-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-02-10-bin.zip
+ cp target/release/geoserver-2.2-SNAPSHOT-war.zip /var/www/html/geoserver/trunk/geoserver-trunk-latest-war.zip
+ cp target/release/geoserver-2.2-SNAPSHOT-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-latest-bin.zip
+ cd community
[INFO] Building Community Space
[ERROR] BUILD FAILURE
[INFO] Unable to find descriptor: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/ext-querylayer.xml> (No such file or directory)
[INFO] Total time: 1 second
[INFO] Finished at: Thu Feb 10 03:43:10 UTC 2011
[INFO] Final Memory: 10M/204M
+ [ ! -e /var/www/html/geoserver/trunk/ext-2011-02-10 ]
+ mkdir /var/www/html/geoserver/trunk/ext-2011-02-10
+ [ ! -e /var/www/html/geoserver/trunk/community-2011-02-10 ]
+ mkdir /var/www/html/geoserver/trunk/community-2011-02-10
+ cp target/release/geoserver-*-plugin.zip /var/www/html/geoserver/trunk/ext-2011-02-10
cp: cannot stat `target/release/geoserver-*-plugin.zip': No such file or directory
