See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/657/changes>
Changes:
[groldan] implement GetFeatureInfo
[groldan] take layer styles into account to truncate using ParameterFilters
[jdeolive] allowing for multiple db configurations to fall back on
[...truncated 1786 lines...]
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-2.8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/dependency/gt-api-2.8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT-tests.jar
[INFO] Building GeoServer CSS Styling
[INFO] artifact org.scala-tools:maven-scala-plugin: checking for updates from scala-tools.org
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target>
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/java>
[INFO] Copying 9 resources
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala>
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/test/scala>
[INFO] [scala:compile {execution: scala-compile-first}]
[INFO] Checking for multiple versions of scala
[INFO] includes = [**/*.scala,**/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/src/main/scala>:\-1: info: compiling
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/classes> at 1301542527262
[INFO] prepare-compile in 0 s
[INFO] compile in 11 s
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 0 resource
[INFO] [scala:testCompile {execution: scala-test-compile}]
[INFO] excludes =
[WARNING] No source files found.
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-2.8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/dependency/gt-api-2.8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/css/2.2-SNAPSHOT/css-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/css/2.2-SNAPSHOT/css-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/css/2.2-SNAPSHOT/css-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/css/target/css-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/css/2.2-SNAPSHOT/css-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Printing Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing>
[INFO] Copying 5 resources
[INFO] Copying 2 resources
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.pom
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-2.8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/dependency/gt-api-2.8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/printing/target/printing-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Embedded FTP server
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp>
[INFO] Copying 1 resource
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/src/test/java>
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-2.8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/dependency/gt-api-2.8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.2-SNAPSHOT/ftp-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.2-SNAPSHOT/ftp-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.2-SNAPSHOT/ftp-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/ftp/target/ftp-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/ftp/2.2-SNAPSHOT/ftp-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Monitoring Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring>
[INFO] Copying 7 resources
[INFO] Copying 19 resources
[INFO] Compiling 63 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/src/main/java/org/geoserver/monitor/hib/MonitoringDataSource.java>:\[54,18\] cannot find symbol
symbol : constructor SQLException(java.lang.Exception)
[INFO] Total time: 3 minutes 51 seconds
[INFO] Finished at: Thu Mar 31 03:35:52 UTC 2011
[INFO] Final Memory: 89M/320M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-03-31-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
