[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #695
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/695/changes&gt;
Changes:
[victortey] GEOS-4488: ClassCastException when issue a resultType=hits query
[jdeolive] added teradata query band filter, and application application qb default in datastore edit panel
[jdeolive] making DefautlDataStoreEditPanel subclassable
[jdeolive] adding a custom datastore edit panel
[simboss] fixed JAI install
[riniangreani] rename the profile activation for app-schema community
[riniangreani] Adding new community test module in app-schema: webservice-test.
[riniangreani] Preparing for adding app-schema/webservice-test community module.
[...truncated 2317 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target/spatialite-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Hibernate Catalog/Configuration Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig&gt;
[INFO] Copying 0 resource
[INFO] Copying 6 resources
[INFO] Compiling 21 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/classes&gt;
[INFO] Compiling 5 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/dbconfig/2.2-SNAPSHOT/dbconfig-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/dbconfig/2.2-SNAPSHOT/dbconfig-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/dbconfig/2.2-SNAPSHOT/dbconfig-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/dbconfig-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/dbconfig/2.2-SNAPSHOT/dbconfig-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer INSPIRE Extensions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire&gt;
[INFO] Copying 1 resource
[INFO] Copying 4 resources
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Simple Feature Service
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs&gt;
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Teradata DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/src/main/java/org/geoserver/teradata/TeradataQueryBandFilter.java&gt;:\[15,41\] package com.sun.tools.hat.internal.server does not exist
[INFO] Total time: 3 minutes 19 seconds
[INFO] Finished at: Wed May 04 03:35:04 UTC 2011
[INFO] Final Memory: 94M/407M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-05-04-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/696/changes&gt;
Changes:
[aaime] Adding gt-grid in the wps release packaging
[...truncated 2281 lines...]
[INFO] Total time: 3 minutes 25 seconds
[INFO] Finished at: Thu May 05 03:36:53 UTC 2011
[INFO] Final Memory: 94M/391M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-05-05-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/697/changes&gt;
