See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/75/changes>
Changes:
[francesco.izzi] Move community/web-security module to extension
[...truncated 2310 lines...]
[INFO] [resources:testResources]
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/src/test/java>
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.FileProfileActivator@anonymised.com
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.0-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.0-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.0-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.0-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0-SNAPSHOT/feature-pregeneralized-2.0-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.0-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0-SNAPSHOT/feature-pregeneralized-2.0-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.0-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0-SNAPSHOT/feature-pregeneralized-2.0-SNAPSHOT-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target>
[INFO] [resources:resources]
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/src/test/java>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0-SNAPSHOT/imagemosaic-jdbc-2.0-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0-SNAPSHOT/imagemosaic-jdbc-2.0-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0-SNAPSHOT/imagemosaic-jdbc-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoServer Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/release/target>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/release/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/release/src/main/resources>
[INFO] snapshot org.geotools:gt-gml:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gml:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-db2:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-mysql:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-vpf:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagepyramid:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.extension:web-security:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.extension:web-security:2.0-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/extension/web-security/2.0-SNAPSHOT/web-security-2.0-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.extension:web-security:pom:2.0-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/extension/web-security/2.0-SNAPSHOT/web-security-2.0-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.extension:web-security:pom:2.0-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/extension/web-security/2.0-SNAPSHOT/web-security-2.0-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.extension:web-security:jar:2.0-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/extension/web-security/2.0-SNAPSHOT/web-security-2.0-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.extension:web-security:jar:2.0-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.extension:web-security:jar:2.0-SNAPSHOT
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoserver.extension -DartifactId=web-security -Dversion=2.0-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geoserver.extension -DartifactId=web-security -Dversion=2.0-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver:release:jar:2.0-SNAPSHOT
2) org.geoserver.extension:web-security:jar:2.0-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
opengeo (http://repo.opengeo.org/),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org)
[INFO] Total time: 6 minutes 20 seconds
[INFO] Finished at: Mon Sep 28 03:39:02 EDT 2009
[INFO] Final Memory: 62M/153M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2009-09-28-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
