[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #776
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/776/changes&gt;
Changes:
[bencaradocdavies] GEOT-3680: ComplexType definitions in GML 3.2 subpackages are empty
[bmmpxf] Adding link to external GeoServer INSPIRE tutorial.
[jmacchi] Spatialite application context file and documentation.
[jmacchi] Remove unnecessary files. Latest spatialite output format version.
[...truncated 2069 lines...]
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/extension-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2&gt;
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/src/main/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Python Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python&gt;
[INFO] [antrun:run {execution: generate-sources}]
[INFO] Executing tasks
checkout:
     [echo] Pulling master from git://github.com/jdeolive/geoscript-py.git (ignore fatal warning)
     [exec] fatal: destination path 'geoscript' already exists and is not an empty directory.
     [exec] Result: 128
     [exec] From git://github.com/jdeolive/geoscript-py
     [exec] * branch master -> FETCH_HEAD
     [exec] Already up-to-date.
     [exec] Already on 'master'
     [exec] Your branch is ahead of 'origin/master' by 38 commits.
[INFO] Executed tasks
[INFO] [antrun:run {execution: generate-resources}]
[INFO] Copying 3 resources
[INFO] Copying 78 resources
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/classes&gt;
[INFO] Copying 8 resources
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-test-sources.jar
[INFO] Building SpatiaLite output format
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite&gt;
[INFO] Copying 1 resource
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:8-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://snapshots.repository.codehaus.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository codehaus (http://snapshots.repository.codehaus.org/)
Downloading: http://repo.opengeo.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository central (http://repo1.maven.org/maven2)
Downloading: http://snapshots.repository.codehaus.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository codehaus (http://snapshots.repository.codehaus.org/)
Downloading: http://repo.opengeo.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.xerial:spatialite-native-libs:jar:1.0
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.xerial -DartifactId=spatialite-native-libs -Dversion=1.0 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.xerial -DartifactId=spatialite-native-libs -Dversion=1.0 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:spatialite:jar:2.2-SNAPSHOT
    2) org.xerial:spatialite-native-libs:jar:1.0
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  codehaus (http://snapshots.repository.codehaus.org/),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 7 minutes 3 seconds
[INFO] Finished at: Tue Jul 19 03:45:19 UTC 2011
[INFO] Final Memory: 82M/411M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-07-19-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/777/changes&gt;
Changes:
[bmmpxf] Teradata: adding note about needing a key/index/identity for editing.
[dany111] GEOS-4663: Committing forgotten classes
[...truncated 2142 lines...]
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from osgeo
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 4 minutes 46 seconds
[INFO] Finished at: Wed Jul 20 03:36:30 UTC 2011
[INFO] Final Memory: 87M/409M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-07-20-bin.zip
