[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #779
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/779/changes&gt;
Changes:
[jdeolive] GEOS-3842, updating default driver version to 4.0 now that java 1.6 is the default
[jmacchi] Tests for SpatialiteOutputFormat.
[aaime] [GEOS-4682] Upgrade WPS to JAITools 1.2.0
[aaime] Fix build
[aaime] [GEOS-4686] Secured coverage wrappers will dispose the readers making fruther reads impossible
[...truncated 2157 lines...]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/extension-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2&gt;
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/src/main/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Python Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python&gt;
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from osgeo
[INFO] [antrun:run {execution: generate-sources}]
[INFO] Executing tasks
checkout:
     [echo] Pulling master from git://github.com/jdeolive/geoscript-py.git (ignore fatal warning)
     [exec] fatal: destination path 'geoscript' already exists and is not an empty directory.
     [exec] Result: 128
     [exec] From git://github.com/jdeolive/geoscript-py
     [exec] * branch master -> FETCH_HEAD
     [exec] Already up-to-date.
     [exec] Already on 'master'
     [exec] Your branch is ahead of 'origin/master' by 38 commits.
[INFO] Executed tasks
[INFO] [antrun:run {execution: generate-resources}]
[INFO] Copying 3 resources
[INFO] Copying 78 resources
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/classes&gt;
[INFO] Copying 8 resources
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-test-sources.jar
[INFO] Building SpatiaLite output format
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite&gt;
[INFO] Copying 1 resource
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:8-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://snapshots.repository.codehaus.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository codehaus (http://snapshots.repository.codehaus.org/)
Downloading: http://repo.opengeo.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.pom
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:pom:1.0' in repository central (http://repo1.maven.org/maven2)
Downloading: http://snapshots.repository.codehaus.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository codehaus (http://snapshots.repository.codehaus.org/)
Downloading: http://repo.opengeo.org//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/xerial/spatialite-native-libs/1.0/spatialite-native-libs-1.0.jar
[INFO] Unable to find resource 'org.xerial:spatialite-native-libs:jar:1.0' in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.xerial:spatialite-native-libs:jar:1.0
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.xerial -DartifactId=spatialite-native-libs -Dversion=1.0 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.xerial -DartifactId=spatialite-native-libs -Dversion=1.0 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:spatialite:jar:2.2-SNAPSHOT
    2) org.xerial:spatialite-native-libs:jar:1.0
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  codehaus (http://snapshots.repository.codehaus.org/),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 1 second
[INFO] Finished at: Fri Jul 22 03:38:01 UTC 2011
[INFO] Final Memory: 87M/403M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-07-22-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Hi Jose,
Looks like some of your recent changes broke the nightly build. The changes being:
  • the introduction of the dependency on spatialite-native-libs. Its not in the online maven repositories yet
  • In one of your SpatiaLiteOutputFormat classes the package declaration was off (i imagine you moved the class without deleting the original?)
Anyways, i committed some small fixes for that but also disabled the module from the nightly build. ONce we sort out how to get the native libs in maven repo we can re-enable it.
-Justin
On Thu, Jul 21, 2011 at 9:38 PM, Hudson <monitor@anonymised.com> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/779/changes>
Changes:
[aaime] Fix build
[…truncated 2157 lines…]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/extension-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT-tests.jar
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2>
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/src/main/resources>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar>
[WARNING] the “build.repository” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the “build.path” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the “build.revision” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the “build.mixedRevisions” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the “build.committedRevision” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the “build.status” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the “build.specialStatus” property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-test-sources.jar
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python>
checkout:
[exec] fatal: destination path ‘geoscript’ already exists and is not an empty directory.
[exec] Result: 128
[exec] * branch master → FETCH_HEAD
[exec] Already on ‘master’
[exec] Your branch is ahead of ‘origin/master’ by 38 commits.
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/classes>
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar>
checkout:
[exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar>
checkout:
[exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-test-sources.jar
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/spatialite>
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:pom:1.0’ in repository codehaus (http://snapshots.repository.codehaus.org/)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:pom:1.0’ in repository opengeo (http://repo.opengeo.org/)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:pom:1.0’ in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:pom:1.0’ in repository maven-restlet (http://maven.restlet.org)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:pom:1.0’ in repository central (http://repo1.maven.org/maven2)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:jar:1.0’ in repository codehaus (http://snapshots.repository.codehaus.org/)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:jar:1.0’ in repository opengeo (http://repo.opengeo.org/)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:jar:1.0’ in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:jar:1.0’ in repository maven-restlet (http://maven.restlet.org)
[INFO] Unable to find resource ‘org.xerial:spatialite-native-libs:jar:1.0’ in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
Missing:
  1. org.xerial:spatialite-native-libs:jar:1.0
Path to dependency:
  1. org.geoserver.community:spatialite:jar:2.2-SNAPSHOT
  2. org.xerial:spatialite-native-libs:jar:1.0
for artifact:
  • cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-07-22-bin.zip
    cp: cannot stat `target/release/geoserver*-bin.zip’: No such file or directory
10 Tips for Better Web Security
Learn 10 ways to better secure your business today. Topics covered include:
Web security, SSL, hacker attacks & Denial of Service (DoS), private keys,
security Microsoft Exchange, secure Instant Messaging, and much more.
http://www.accelacomm.com/jaw/sfnl/114/51426210/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/780/changes&gt;
