[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #961
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/961/changes&gt;
Changes:
[jdeolive] GEOS-4924, GSIP 67 - workspace local settings
[aaime] [GEOS-4922] Authentication by unique key community module
[riniangreani] Add wfs version 1.1.0 to requests in data reference online tests so they work with wfs 2.0 support.
[...truncated 2379 lines...]
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire&gt;
[INFO] Copying 1 resource
[INFO] Copying 4 resources
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/inspire/target/inspire-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Simple Feature Service
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs&gt;
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Aggregating Data Store
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate&gt;
[INFO] Copying 3 resources
[INFO] snapshot org.geotools.unsupported:gt-feature-aggregate:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/src/test/java&gt;
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/release/src/main/resources&gt;
[INFO] snapshot org.geoserver.community:authkey:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:authkey:2.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/authkey/2.2-SNAPSHOT/authkey-2.2-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:authkey:pom:2.2-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/authkey/2.2-SNAPSHOT/authkey-2.2-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:authkey:pom:2.2-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[INFO] snapshot org.geoserver.community:spatialite:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:spatialite:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:8-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geoserver.community:teradata:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:teradata:2.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/authkey/2.2-SNAPSHOT/authkey-2.2-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:authkey:jar:2.2-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/authkey/2.2-SNAPSHOT/authkey-2.2-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:authkey:jar:2.2-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.community:authkey:jar:2.2-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=authkey -Dversion=2.2-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=authkey -Dversion=2.2-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:release:jar:2.2-SNAPSHOT
    2) org.geoserver.community:authkey:jar:2.2-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 4 seconds
[INFO] Finished at: Fri Jan 06 03:39:29 UTC 2012
[INFO] Final Memory: 96M/392M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-01-06-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/962/changes&gt;
Changes:
[aaime] Fixing version number
[riniangreani] Remove unnecessary dependency to gt-webservice.
[...truncated 1361 lines...]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/security/target/web-security-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target&gt;
[INFO] [antrun:run {execution: configClean}]
[INFO] Executing tasks
   [delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/resources&gt;
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 88 resources
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] [antrun:run {execution: configPackage}]
     [echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/../../../data/release&gt;
     [copy] Copying 438 files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data&gt;
     [copy] Copied 63 empty directories to 1 empty directory under <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp/data&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/web-app-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-test-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[1682 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/target/geoserver.war&gt;
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/target/community-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT-tests.jar
[INFO] Building Authentication by unique url key
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/resources&gt;
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilter.java&gt;:\[18,47\] package org.springframework.security.userdetails does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[12,35\] package org.springframework.security does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[13,35\] package org.springframework.security does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[14,43\] package org.springframework.security.context does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[15,45\] package org.springframework.security.providers does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[16,47\] package org.springframework.security.userdetails does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[17,47\] package org.springframework.security.userdetails does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[25,4\] cannot find symbol
symbol : class UserDetailsService
location: class org.geoserver.security.AuthenticationKeyManager
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[27,36\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/KeyAuthenticationToken.java&gt;:\[7,45\] package org.springframework.security.providers does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/KeyAuthenticationToken.java&gt;:\[8,47\] package org.springframework.security.userdetails does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/KeyAuthenticationToken.java&gt;:\[13,44\] cannot find symbol
symbol: class AbstractAuthenticationToken
public class KeyAuthenticationToken extends AbstractAuthenticationToken {
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/KeyAuthenticationToken.java&gt;:\[20,12\] cannot find symbol
location: class org.geoserver.security.KeyAuthenticationToken
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/KeyAuthenticationToken.java&gt;:\[22,46\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/PropertyAuthenticationKeyMapper.java&gt;:\[22,47\] package org.springframework.security.userdetails does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMangler.java&gt;:\[10,35\] package org.springframework.security does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMangler.java&gt;:\[11,43\] package org.springframework.security.context does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[34,22\] cannot find symbol
symbol : class BadCredentialsException
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[40,8\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[44,22\] cannot find symbol
symbol : class ProviderNotFoundException
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[47,12\] cannot find symbol
symbol : class Authentication
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyManager.java&gt;:\[48,12\] cannot find symbol
symbol : variable SecurityContextHolder
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/PropertyAuthenticationKeyMapper.java&gt;:\[103,21\] cannot find symbol
symbol : class User
location: class org.geoserver.security.PropertyAuthenticationKeyMapper
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/PropertyAuthenticationKeyMapper.java&gt;:\[105,25\] cannot find symbol
symbol : class User
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMangler.java&gt;:\[20,8\] cannot find symbol
location: class org.geoserver.security.AuthenticationKeyMangler
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMangler.java&gt;:\[20,40\] cannot find symbol
[INFO] Total time: 4 minutes 26 seconds
[INFO] Finished at: Sat Jan 07 03:37:19 UTC 2012
[INFO] Final Memory: 72M/416M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-01-07-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/963/changes&gt;
Changes:
[riniangreani] Fix dependency for web-service-test.
[...truncated 1387 lines...]
[INFO] Webapp assembled in[4672 msecs]
symbol : class User
symbol : class User
[INFO] Total time: 5 minutes 38 seconds
[INFO] Finished at: Sun Jan 08 03:38:07 UTC 2012
[INFO] Final Memory: 66M/425M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-01-08-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/964/&gt;
[...truncated 1360 lines...]
[INFO] Webapp assembled in[9843 msecs]
symbol : class User
symbol : class User
[INFO] Finished at: Mon Jan 09 03:37:24 UTC 2012
[INFO] Final Memory: 71M/400M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-01-09-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/965/changes&gt;
Changes:
[jdeolive] GEOS-4888, proper handling of accepts header for media type all, patch submitted by Steve Ikeoka
[...truncated 1274 lines...]
[INFO] Webapp assembled in[12025 msecs]
symbol : class User
symbol : class User
[INFO] Total time: 5 minutes 7 seconds
[INFO] Finished at: Tue Jan 10 03:38:24 UTC 2012
[INFO] Final Memory: 69M/412M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-01-10-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/966/changes&gt;
