See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/387/>
[...truncated 15992 lines...]
[INFO] Copying 84 resources
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/surefire-reports>
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
07 Feb 04:08:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/./target/mock3954363529782523119data>
Feb 7, 2011 4:08:12 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
07 Feb 04:08:12 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
07 Feb 04:08:12 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources> contained no layers.
07 Feb 04:08:12 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources>: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources/geowebcache\.xml>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.392 sec
Running org.geoserver.filters.GZIPResponseStreamTest
07 Feb 04:08:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/./target/mock1686428504219508531data>
07 Feb 04:08:15 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
07 Feb 04:08:15 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources> contained no layers.
07 Feb 04:08:15 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources>: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources/geowebcache\.xml>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.047 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.filters.BufferedRequestStreamTest
07 Feb 04:08:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/./target/mock8816912446117661926data>
07 Feb 04:08:17 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
07 Feb 04:08:17 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources> contained no layers.
07 Feb 04:08:17 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources>: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/null/../resources/geowebcache\.xml>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.544 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] snapshot org.geoserver.maven:config:2.2-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT-test-sources.jar>
[INFO] [config:config {execution: configPackage}]
config:
[echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/minimal>
[copy] Copying 25 files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/src/main/webapp/data>
[copy] Copied 14 empty directories to 8 empty directories under <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/src/main/webapp/data>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/web-app-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-test-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[440 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/web/app/target/geoserver.war>
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/community/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/community>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/community/target/community-2.2-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/community/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/community/target/community-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/target/extension-2.2-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/target/extension-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT-tests.jar
[INFO] Building Application Schema Support
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/app-schema>
[INFO] snapshot org.geotools:gt-app-schema:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema:2.8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:app-schema:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:app-schema:2.8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:2.8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-webservice:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-webservice:2.8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-webservice/2.8-SNAPSHOT/gt-webservice-2.8-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-webservice:pom:2.8-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-webservice/2.8-SNAPSHOT/gt-webservice-2.8-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-webservice:pom:2.8-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geotools/gt-webservice/2.8-SNAPSHOT/gt-webservice-2.8-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-webservice:jar:2.8-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-webservice/2.8-SNAPSHOT/gt-webservice-2.8-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-webservice:jar:2.8-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools:gt-webservice:jar:2.8-SNAPSHOT
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geotools -DartifactId=gt-webservice -Dversion=2.8-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt-webservice -Dversion=2.8-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver.extension:app-schema:pom:2.2-SNAPSHOT
2) org.geotools:gt-webservice:jar:2.8-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
opengeo (http://repo.opengeo.org/),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org)
[INFO] Total time: 7 minutes 5 seconds
[INFO] Finished at: Mon Feb 07 04:08:29 UTC 2011
[INFO] Final Memory: 73M/316M
