See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/500/>
[...truncated 12341 lines...]
May 29, 2011 4:03:33 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.103 sec
Running org.vfny.geoserver.util.SLDValidatorTest
May 29, 2011 4:03:33 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock1013983499959399233data>
May 29, 2011 4:03:33 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5177'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5175'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5174'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5176'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock209484105226530987data>
cvc-complex-type.2.4.a: Invalid content starting with element 'Font'. One of '{"http://www.opengis.net/sld":Stroke\}' is expected.
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-511f'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-511d'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-511c'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-511e'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.378 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock7491884709798481669data>
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-50c7'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-50c5'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-50c6'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-50c4'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock340248683070381171data>
May 29, 2011 4:03:34 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-506e'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-506c'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-506d'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-506b'
May 29, 2011 4:03:34 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock8990023415673013821data>
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5015'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5013'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5014'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-5012'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock667911443590287209data>
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-4fbc'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-4fba'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-4fbb'
INFO: Disposing datastore 'DataStoreInfoImpl--10879080:13039eb7de4:-4fb9'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.586 sec
Results :
Tests in error:
testPropertyEqualsFirstArgumentNotPropertyName(org.geoserver.feature.ReprojectingFilterVisitorTest)
Tests run: 271, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/target/surefire-reports> for the individual test results.
[INFO] Total time: 2 minutes 5 seconds
[INFO] Finished at: Sun May 29 04:03:34 UTC 2011
[INFO] Final Memory: 53M/210M
