[Geoserver-devel] Build failed in Hudson: geoserver-trunk-online #618
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/618/&gt;
[...truncated 47176 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/src/main/resources&gt;
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-postgis/8-SNAPSHOT/gt-jdbc-postgis-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/8-SNAPSHOT/gt-opengis-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/8-SNAPSHOT/gt-coverage-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/8-SNAPSHOT/gt-render-8-SNAPSHOT.jar
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/surefire-reports&gt;
T E S T S
Running org.geoserver.flow.NestedRequestSentinelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.042 sec
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-2,5,main] waiting
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-2,5,main] calling requestComplete
Thread[Thread-2,5,main] done
Thread[Thread-3,5,main] waiting
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.118 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-4,5,main] waiting
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] waiting
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.511 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/wps-core/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/wps-core&gt;
[INFO] Copying 10 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/wps-core/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wps/8-SNAPSHOT/net.opengis.wps-8-SNAPSHOT.pom
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-raster:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-raster:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-raster:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-geometry:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-geometry:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-geometry:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-feature:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-feature:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-feature:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-process-feature/8-SNAPSHOT/gt-process-feature-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wps/8-SNAPSHOT/net.opengis.wps-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wfs/8-SNAPSHOT/gt-xsd-wfs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wcs/8-SNAPSHOT/gt-xsd-wcs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-process-feature/8-SNAPSHOT/gt-process-feature-8-SNAPSHOT.jar
[INFO] Compiling 92 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/wps-core/target/classes&gt;
[INFO] Copying 12 resources
[INFO] Compiling 34 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/wps-core/target/test-classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/PolygonExtractionProcessTest.java&gt;:\[31,44\] execute(org.geotools.coverage.grid.GridCoverage2D,java.lang.Integer,java.lang.Boolean,com.vividsolutions.jts.geom.Geometry,java.util.Collection<java.lang.Number>,java.util.List<org.jaitools.numeric.Range>,org.opengis.util.ProgressListener) in org.geotools.process.raster.gs.PolygonExtractionProcess cannot be applied to (org.geotools.coverage.grid.GridCoverage2D,int,boolean,<nulltype>,<anonymous java.util.ArrayList<org.jaitools.numeric.Range>>,org.geotools.util.NullProgressListener)
[INFO] Total time: 12 minutes 10 seconds
[INFO] Finished at: Fri Sep 23 04:13:32 UTC 2011
[INFO] Final Memory: 74M/403M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/619/&gt;
[...truncated 46392 lines...]
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar&gt;
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.51 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
[INFO] Total time: 12 minutes 56 seconds
[INFO] Finished at: Fri Sep 23 10:59:20 UTC 2011
[INFO] Final Memory: 73M/327M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/620/&gt;
