See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/632/>
[...truncated 24517 lines...]
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows src/test/resources/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="InvalidParameterValue" locator="service">
<ows:ExceptionText>No service: ( ows )</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
06 Oct 04:22:13 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No service: ( ows )
at org.geoserver.ows.Dispatcher.service(Dispatcher.java:410)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:218)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1217)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1236)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1177)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:593)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:576)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:561)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:846)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:810)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestMandatoryRequestParameter(CapabilitiesSystemTest.java:211)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor225.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
org.geoserver.platform.ServiceException: WMS capabilities document is current (updateSequence = 3)
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:62)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:324)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:68)
at sun.reflect.GeneratedMethodAccessor239.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy15.getCapabilities(Unknown Source)
at sun.reflect.GeneratedMethodAccessor238.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:246)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
</ServiceException>
</ServiceExceptionReport>
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current sever updateSequence
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:263)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.436 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
06 Oct 04:22:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/./target/mock3575103944245661405data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.259 sec
Results :
Failed tests:
testTimeDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeCurrent(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeList(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeElevation(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeCurrent(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeList(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
Tests run: 351, Failures: 21, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 5 minutes 22 seconds
[INFO] Finished at: Thu Oct 06 04:22:14 UTC 2011
[INFO] Final Memory: 55M/407M
