[Geoserver-devel] Build failed in Hudson: geoserver-trunk-online #705
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/705/&gt;
Started by timer
[src] $ /opt/apache-maven-2.2.1/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,owsRemoteTests clean install
FATAL: command execution failed
java.io.IOException: Cannot run program "/opt/apache-maven-2.2.1/bin/mvn" (in directory "<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/&quot;\)>: java.io.IOException: error=12, Cannot allocate memory
  at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
  at hudson.Proc$LocalProc.<init>(Proc.java:192)
  at hudson.Proc$LocalProc.<init>(Proc.java:164)
  at hudson.Launcher$LocalLauncher.launch(Launcher.java:638)
  at hudson.Launcher$ProcStarter.start(Launcher.java:273)
  at hudson.Launcher$ProcStarter.join(Launcher.java:280)
  at hudson.tasks.Maven.perform(Maven.java:253)
  at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
  at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:601)
  at hudson.model.Build$RunnerImpl.build(Build.java:174)
  at hudson.model.Build$RunnerImpl.doRun(Build.java:138)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:416)
  at hudson.model.Run.run(Run.java:1257)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:129)
Caused by: java.io.IOException: java.io.IOException: error=12, Cannot allocate memory
  at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
  at java.lang.ProcessImpl.start(ProcessImpl.java:65)
  at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
  ... 15 more
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/706/&gt;
