[Geoserver-devel] Build failed in Hudson: geoserver-trunk-online #762
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/762/&gt;
[...truncated 29666 lines...]
org.geoserver.platform.ServiceException: WMS capabilities document is current (updateSequence = 3)
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:62)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:324)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:68)
  at sun.reflect.GeneratedMethodAccessor154.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy14.getCapabilities(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor153.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:763)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:273)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1223)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1242)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1177)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:593)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:576)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:561)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:846)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:810)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:267)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor261.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
</ServiceException>
</ServiceExceptionReport>
13 Feb 04:08:14 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current sever updateSequence
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:284)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.225 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
13 Feb 04:08:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/./target/mock493989804966711360data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.468 sec
Results :
Tests run: 382, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/8-SNAPSHOT/gt-opengis-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.fes/8-SNAPSHOT/net.opengis.fes-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms&gt; (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/wms/target/wms-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/gwc/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/gwc&gt; (directory)
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] snapshot org.geowebcache:gwc-core:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-core:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-georss:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-georss:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-kml:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-kml:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-rest:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-rest:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-tms:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-tms:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-ve:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-ve:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wms:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wms:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.3-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/gwc/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/gwc/src/main/java/org/geoserver/gwc/layer/CatalogConfiguration.java&gt;:\[57,7\] org.geoserver.gwc.layer.CatalogConfiguration is not abstract and does not override abstract method addLayer(org.geowebcache.layer.TileLayer) in org.geowebcache.config.Configuration
[INFO] Total time: 6 minutes 59 seconds
[INFO] Finished at: Mon Feb 13 04:08:22 UTC 2012
[INFO] Final Memory: 59M/371M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/763/&gt;
