[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wcs-1.0 #121
See <https://build.geoserver.org/job/2.14-cite-wcs-1.0/121/display/redirect&gt;
[...truncated 68.81 KB...]
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ '[' 1 == 1 ']'
+ echo 'GeoServer did not shutdown properly'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wcs-1.0/122/display/redirect&gt;
[...truncated 1.19 MB...]
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec]
     [exec] java.net.ConnectException: Connection refused (Connection refused)
     [exec] VAR_WCS_TEMP_CRS:
     [exec] VAR_WCS_TEMP_RPCRS:
     [exec] VAR_WCS_COVERAGE_1_CRS: You_got_this_because_you_did_not_have_crs_included_in_your_first_domainSet_in_your_first_Coverage
     [exec] VAR_WCS_COVERAGE_1_RESPONSE_CRS:
     [exec] VAR_WCS_FORMAT_1:
     [exec] VAR_WCS_COVERAGE_1_BBOX: ,
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method (wcs-1.0.0/d1e2549_1)...
     [exec] Assertion: For each of the advertised interpolation methods, the server returns content.
     [exec] Jan 15, 2019 12:31:11 AM com.occamlab.te.TECore parse
     [exec] SEVERE: parse Error
     [exec] at java.net.PlainSocketImpl.socketConnect(Native Method)
     [exec] at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
     [exec] at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
     [exec] at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
     [exec] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
     [exec] at java.net.Socket.connect(Socket.java:589)
     [exec] at java.net.Socket.connect(Socket.java:538)
     [exec] at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
     [exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
     [exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
     [exec] at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
     [exec] at sun.net.www.http.HttpClient.New(HttpClient.java:339)
     [exec] at sun.net.www.http.HttpClient.New(HttpClient.java:357)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1501)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:498)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] at com.occamlab.te.TECore.callTest(TECore.java:586)
     [exec] at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
     [exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
     [exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
     [exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
     [exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
     [exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
     [exec] at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:625)
     [exec]
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method Passed
     [exec] Test wcs1-0-0:main Failed (Inherited failure)
     [exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
     [copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/users/geoserver/wcs-1.0.0&gt;
2019-01-15 00:31:11.388:INFO:oejsh.ContextHandler:ShutdownMonitor: Stopped o.e.j.w.WebAppContext@anonymised.com{/geoserver,<https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/geoserver/geoserver-2.14-SNAPSHOT/webapps/geoserver/,UNAVAILABLE\}{/geoserver}>
BUILD SUCCESSFUL
Total time: 17 seconds
+ grep Failed
+ ant wcs-1.0-log
     [exec] Test wcs1-0-0:main (wcs-1.0.0) Failed (Inherited Failure)
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-exception-post-kvp-1 (wcs-1.0.0/d1e1451_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-exception-post-kvp-2 (wcs-1.0.0/d1e1472_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-format-get-kvp-2 (wcs-1.0.0/d1e1490_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-format-get-kvp-3 (wcs-1.0.0/d1e1506_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-format-post-kvp-2 (wcs-1.0.0/d1e1524_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-format-post-kvp-3 (wcs-1.0.0/d1e1543_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-format-post-xml-2 (wcs-1.0.0/d1e1562_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-format-post-xml-3 (wcs-1.0.0/d1e1581_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-get-kvp-1 (wcs-1.0.0/d1e1599_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-post-kvp-1 (wcs-1.0.0/d1e1619_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-get-kvp-2 (wcs-1.0.0/d1e1640_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-get-xml-2 (wcs-1.0.0/d1e1654_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-post-xml-2 (wcs-1.0.0/d1e1684_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-post-xml-3 (wcs-1.0.0/d1e1706_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-get-kvp-3 (wcs-1.0.0/d1e1725_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-get-kvp-4 (wcs-1.0.0/d1e1744_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-kvp-3 (wcs-1.0.0/d1e1765_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-kvp-4 (wcs-1.0.0/d1e1784_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-xml-3 (wcs-1.0.0/d1e1805_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-xml-4 (wcs-1.0.0/d1e1825_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-2 (wcs-1.0.0/d1e1844_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-3 (wcs-1.0.0/d1e1862_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-2 (wcs-1.0.0/d1e1880_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-3 (wcs-1.0.0/d1e1901_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 (wcs-1.0.0/d1e1920_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 (wcs-1.0.0/d1e1942_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 (wcs-1.0.0/d1e1959_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 (wcs-1.0.0/d1e1972_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 (wcs-1.0.0/d1e1988_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 (wcs-1.0.0/d1e2008_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 (wcs-1.0.0/d1e2029_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 (wcs-1.0.0/d1e2051_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 (wcs-1.0.0/d1e2072_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 (wcs-1.0.0/d1e2093_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d1e2114_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d1e2355_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d1e2375_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d1e2396_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d1e2416_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d1e2436_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d1e2457_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 31565
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wcs-1.0/123/display/redirect&gt;
