[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wcs-1.0 #128
See <https://build.geoserver.org/job/2.14-cite-wcs-1.0/128/display/redirect&gt;
[...truncated 98.90 KB...]
compile:
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build&gt;
    [javac] <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build.xml&gt;:13: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
    [javac] Compiling 1 source file to <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build&gt;
warning: [options] bootstrap class path not set in conjunction with -source 1.6
Note: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/src/java/com/occamlab/te/realm/UserFilesRealm.java&gt; uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 warning
     [copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build/com/occamlab/te/realm&gt;
jar:
      [jar] Building jar: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/UserFilesRealm.jar&gt;
zip.manager.bin:
   [delete] Deleting directory <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/build&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/build&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/build/teamengine-2019.01.18&gt;
     [copy] Copying 2 files to <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/build/teamengine-2019.01.18&gt;
      [zip] Building zip: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2019.01.18-bin.zip&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ cite ---
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ cite ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.4:test (default-test) @ cite ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ cite ---
[INFO] Building jar: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/target/cite-1.0.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ cite ---
[INFO] Installing <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/target/cite-1.0.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/cite/1.0/cite-1.0.jar
[INFO] Installing <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/cite/1.0/cite-1.0.pom
[INFO] BUILD SUCCESS
[INFO] Total time: 17.333 s
[INFO] Finished at: 2019-01-18T17:14:39+00:00
[INFO] Final Memory: 26M/318M
+ ant clean
Buildfile: build.xml
clean:
BUILD SUCCESSFUL
Total time: 0 seconds
+ pushd ..
~/workspace/geoserver-cite ~/workspace/geoserver-cite/tools ~/workspace/geoserver-cite
++ pwd
+ FORMS=<https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/forms&gt;
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/forms&gt; wcs-1.0
wcs-1.0:
run-test:
     [exec] Jan 18, 2019 5:14:41 PM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl&gt;
     [exec] INFO: Validating <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl&gt;
     [exec] INFO: Validating <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/engine/scripts/wcs-1.0.0/ctl/wcs.xml&gt;
     [exec] Checking for <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/forms/wcs-1.0.0.xml&gt;
     [exec] Testing suite wcs1-0-0:main_wcs1-0-0...
     [exec] Testing wcs1-0-0:main (wcs-1.0.0)...
     [exec] Assertion: The WCS 1.0.0 implementation being tested behaves properly
     [exec] Jan 18, 2019 5:14:43 PM com.occamlab.te.TECore parse
     [exec] SEVERE: parse Error
     [exec] java.net.ConnectException: Connection refused (Connection refused)
     [exec] at java.net.PlainSocketImpl.socketConnect(Native Method)
     [exec] at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
     [exec] at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
     [exec] at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
     [exec] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
     [exec] at java.net.Socket.connect(Socket.java:589)
     [exec] at java.net.Socket.connect(Socket.java:538)
     [exec] at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
     [exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
     [exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
     [exec] at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
     [exec] at sun.net.www.http.HttpClient.New(HttpClient.java:339)
     [exec] at sun.net.www.http.HttpClient.New(HttpClient.java:357)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1501)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:498)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec]
     [exec] Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=; SystemID: <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/target/work/~2Fvar~2Fjenkins~2Fworkspace~2Fgeoserver-cite~2Ftools~2Fengine~2Fscripts~2Fwcs-1.0.0~2Fctl~2Fwcs.xml/wcs1-0-0$main.test;&gt; Line#: 204; Column#: -1
     [exec] Jan 18, 2019 5:14:43 PM com.occamlab.te.TECore executeTest
     [exec] SEVERE: SaxonApiException
     [exec] net.sf.saxon.s9api.SaxonApiException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:192)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] ... 6 more
     [exec] Caused by: java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] at java.net.URL.<init>(URL.java:593)
     [exec] at java.net.URL.<init>(URL.java:490)
     [exec] at java.net.URL.<init>(URL.java:439)
     [exec] at com.occamlab.te.TECore.build_request(TECore.java:1226)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1122)
     [exec] ... 56 more
     [exec]
     [exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] Test wcs1-0-0:main Failed
     [exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
     [copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wcs-1.0/ws/tools/users/geoserver/wcs-1.0.0&gt;
BUILD SUCCESSFUL
Total time: 3 seconds
+ ant wcs-1.0-log
+ grep Failed
     [exec] Test wcs1-0-0:main (wcs-1.0.0) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ./shutdown.sh
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 12920
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wcs-1.0/129/display/redirect&gt;
[...truncated 98.59 KB...]
compile:
1 warning
jar:
zip.manager.bin:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Total time: 17.766 s
[INFO] Finished at: 2019-01-18T18:13:35+00:00
[INFO] Final Memory: 23M/236M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Jan 18, 2019 6:13:36 PM com.occamlab.te.Generator generateXsl
     [exec] Jan 18, 2019 6:13:39 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Jan 18, 2019 6:13:39 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 15877
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wcs-1.0/130/display/redirect&gt;
