See <https://build.geoserver.org/job/2.14-cite-wcs-1.1/121/display/redirect>
[...truncated 108.91 KB...]
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 == 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ '[' 0 == 0 ']'
+ echo 'GeoServer did not startup properly'
+ exit 1
Build step 'Execute shell' marked build as failure
