See <http://build.geoserver.org/job/2.14-cite-wcs-1.1/250/display/redirect>
Started by upstream project "2.14-cite-all" build number 253
originally caused by:
Started by timer
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/2.14-cite-wcs-1.1/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/2.14-cite-wcs-1.1/lastSuccessful
at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
at java.nio.file.Files.deleteIfExists(Files.java:1165)
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1936)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/2.14-cite-wcs-1.1/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/2.14-cite-wcs-1.1/lastStable
at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-0c5893424321f222a (linux-fleet) in workspace <http://build.geoserver.org/job/2.14-cite-wcs-1.1/ws/>
[geoserver-cite] $ /bin/sh -xe /tmp/jenkins18430909406102534022.sh
+ ./run.sh wcs-1.1 2.14.x
/tmp/jenkins18430909406102534022.sh: 2: /tmp/jenkins18430909406102534022.sh: ./run.sh: not found
Build step 'Execute shell' marked build as failure
