[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wfs-1.0 #69
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/69/display/redirect&gt;
[...truncated 238.42 KB...]
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] ... 190 more
     [exec] Caused by: java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities
     [exec] at java.net.URL.<init>(URL.java:593)
     [exec] at java.net.URL.<init>(URL.java:490)
     [exec] at java.net.URL.<init>(URL.java:439)
     [exec] at com.occamlab.te.TECore.build_request(TECore.java:1226)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1122)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:498)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] ... 205 more
     [exec]
     [exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-8 Failed
     [exec] Test wfs:main Failed (Inherited failure)
     [exec] Suite wfs:main_wfs Failed
     [copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/users/geoserver/wfs-1.0.0&gt;
BUILD SUCCESSFUL
Total time: 8 seconds
+ grep Failed
+ ant wfs-1.0-log
     [exec] Test wfs:main (wfs-1.0.0) Failed (Inherited Failure)
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d41e825_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-2 (wfs-1.0.0/d41e830_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-3 (wfs-1.0.0/d41e835_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-4 (wfs-1.0.0/d41e840_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d41e845_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d41e851_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d41e856_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d41e861_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 12851
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/70/display/redirect&gt;
