[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wfs-1.0 #85
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/85/display/redirect&gt;
[...truncated 50.16 KB...]
configFileBuilder:
compile:
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/setup/ConfigFileBuilder/build&gt;
    [javac] <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/setup/ConfigFileBuilder/build.xml&gt;:11: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
    [javac] Compiling 3 source files to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/setup/ConfigFileBuilder/build&gt;
warning: [options] bootstrap class path not set in conjunction with -source 1.6
1 warning
config.xml:
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes/com&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes/com/occamlab&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes/com/occamlab/te&gt;
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes/com/occamlab/te/web&gt;
[xmlvalidate] 1 file(s) have been successfully validated.
context.xml:
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/META-INF&gt;
webapp.manager:
    [mkdir] Created dir: <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/lib&gt;
     [copy] Copying 37 files to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine&gt;
init.version.stamp:
putValueInTokens:
build:
     [copy] Copying 24 files to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes&gt;
     [copy] Copying 30 files to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/lib&gt;
jar.components:
jar.component:
compile:
    [javac] <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/components/cite1/build.xml&gt;:15: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
jar:
webapp.components:
webapp.component:
     [copy] Copying 10 files to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/classes&gt;
     [copy] Copying 8 files to <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/webapps/teamengine/WEB-INF/lib&gt;
build.scripts:
build.script:
xinclude:
zip:
all:
build.script:
build.script:
build.script:
build.script:
build.script:
xinclude:
zip:
all:
build.script:
build.script:
data:
webapp.scripts:
webapp.script:
webapp.script:
webapp.script:
webapp.script:
webapp.script:
webapp.script:
webapp.script:
webapp.script:
webapps:
war:
[INFO] BUILD FAILURE
[INFO] Total time: 21.252 s
[INFO] Finished at: 2018-12-08T00:30:52+00:00
[INFO] Final Memory: 23M/294M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (compile) on project cite: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/build.xml&gt;:497: The following error occurred while executing this line:
[ERROR] <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/build.xml&gt;:356: Problem reading <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/setup/teamengine.war&gt;
[ERROR] around Ant part ...<ant dir="<https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine&quot;/&gt;\.\.\.&gt; @ 4:66 in <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/target/antrun/build-main.xml&gt;: archive is not a ZIP archive
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
+ ant clean
Buildfile: build.xml
clean:
BUILD SUCCESSFUL
Total time: 0 seconds
+ pushd ..
~/workspace/geoserver-cite ~/workspace/geoserver-cite/tools ~/workspace/geoserver-cite
++ pwd
+ FORMS=<https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/forms&gt;
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/forms&gt; wfs-1.0
wfs-1.0:
run-test:
     [exec] Dec 08, 2018 12:30:55 AM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl&gt;
     [exec] INFO: Validating <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl&gt;
     [exec] INFO: Validating <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/tools/engine/scripts/wfs-1.0.0/ctl/wfs.xml&gt;
     [exec] Testing suite wfs:main_wfs...
     [exec] Testing wfs:main (wfs-1.0.0)...
     [exec] Assertion: This WFS is valid
     [exec] Checking for <https://build.geoserver.org/job/2.14-cite-wfs-1.0/ws/forms/wfs-1.0.0.xml&gt;
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-1 (wfs-1.0.0/d41e680_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made without the outputFormat specified, the result document must be an GML XML Schema document.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-1 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-2 (wfs-1.0.0/d41e688_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with the outputFormat XMLSCHEMA, the result document must be an GML XML schema document.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-2 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-3 (wfs-1.0.0/d41e696_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with an unsupported outputFormat 'DUMMYFORMAT', the result document must be an ogc:ServiceExceptionReport document.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-3 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-4 (wfs-1.0.0/d41e704_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made without a TypeName, the result document must be an GML XML schema document that describes all feature types served by the WFS.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-4 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-5 (wfs-1.0.0/d41e712_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with a single TypeName, the result document must be an GML XML schema document that describes the specified feature type.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-5 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-6 (wfs-1.0.0/d41e721_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with a multiple TypeNames in the same namespace, the result document must be an GML XML schema document that describes the specified feature types.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-6 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-7 (wfs-1.0.0/d41e729_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with a multiple TypeNames in different namespaces, the result document must be an GML XML schema document that describes the specified feature types.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-7 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-8 (wfs-1.0.0/d41e737_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with a single TypeName that does not exist, the result document must be an ogc:ServiceExceptionReport.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-8 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-get-9 (wfs-1.0.0/d41e745_1)...
     [exec] Assertion: When a wfs:DescribeFeatureType request is made with multiple TypeNames with one that does not exist, the result document must be an ogc:ServiceExceptionReport.
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-9 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-1 (wfs-1.0.0/d41e753_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-1 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-2 (wfs-1.0.0/d41e761_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-2 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-3 (wfs-1.0.0/d41e770_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-3 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-4 (wfs-1.0.0/d41e778_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-4 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-5 (wfs-1.0.0/d41e786_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-5 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-6 (wfs-1.0.0/d41e794_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-6 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-7 (wfs-1.0.0/d41e802_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-7 Failed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-8 (wfs-1.0.0/d41e810_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-8 Passed
     [exec] Testing wfs:test1.0.0-basic-describefeaturetype-post-9 (wfs-1.0.0/d41e819_1)...
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-9 Passed
     [exec] Testing wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d41e825_1)...
     [exec] Assertion: When a wfs:GetCapabilities request is made for a version number that the server supports, the result document must be a wfs:WFS_Capabilities with the version number equal to the version number in the request.
./run.sh: line 120: 23801 Killed ant -Dcite.headless=true -Dcite.headless.formroot=$FORMS $PROFILE
+ ant wfs-1.0-log
+ grep Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-4 (wfs-1.0.0/d41e704_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-5 (wfs-1.0.0/d41e712_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-6 (wfs-1.0.0/d41e721_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-7 (wfs-1.0.0/d41e729_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-4 (wfs-1.0.0/d41e778_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-5 (wfs-1.0.0/d41e786_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-6 (wfs-1.0.0/d41e794_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-7 (wfs-1.0.0/d41e802_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
./run.sh: line 134: pushd: geoserver/geoserver-2.14-SNAPSHOT/bin: No such file or directory
+ popd
./run.sh: line 136: popd: directory stack empty
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 23207
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/86/display/redirect&gt;
