See <https://build.geoserver.org/job/2.14-cite-wms-1.1/81/display/redirect>
[...truncated 2.44 MB...]
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Error invoking parser {http://www.occamlab.com/te/parsers\}XMLValidatingParser
[exec] java.net.ConnectException: Connection refused (Connection refused)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
[exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
[exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
[exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] ... 190 more
[exec] Caused by: java.lang.Exception: Error invoking parser {http://www.occamlab.com/te/parsers\}XMLValidatingParser
[exec] at com.occamlab.te.TECore.parse(TECore.java:1558)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
[exec] at com.occamlab.te.TECore.request(TECore.java:1123)
[exec] at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[exec] at java.lang.reflect.Method.invoke(Method.java:498)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
[exec] ... 209 more
[exec] Caused by: java.net.ConnectException: Connection refused (Connection refused)
[exec] at java.net.PlainSocketImpl.socketConnect(Native Method)
[exec] at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
[exec] at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
[exec] at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
[exec] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
[exec] at java.net.Socket.connect(Socket.java:589)
[exec] at java.net.Socket.connect(Socket.java:538)
[exec] at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
[exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
[exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
[exec] at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
[exec] at sun.net.www.http.HttpClient.New(HttpClient.java:339)
[exec] at sun.net.www.http.HttpClient.New(HttpClient.java:357)
[exec] at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
[exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
[exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
[exec] at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
[exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
[exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
[exec] at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:170)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1549)
[exec] ... 217 more
[exec]
[exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Error invoking parser {http://www.occamlab.com/te/parsers\}XMLValidatingParser
[exec] Test wms:basic_elements-validate-exception Failed
[exec] Test wms:wms_main Failed (Inherited failure)
[exec] Suite wms:main_wms Failed
[copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wms-1.1/ws/tools/users/geoserver/wms-1.1.1>
BUILD SUCCESSFUL
Total time: 15 seconds
+ ant wms-1.1-log
+ grep Failed
2018-12-05 00:31:12.821:INFO:oejsh.ContextHandler:ShutdownMonitor: Stopped o.e.j.w.WebAppContext@anonymised.com{/geoserver,<https://build.geoserver.org/job/2.14-cite-wms-1.1/ws/geoserver/geoserver-2.14-SNAPSHOT/webapps/geoserver/,UNAVAILABLE\}{/geoserver}>
[exec] Test wms:wms_main (wms-1.1.1) Failed (Inherited Failure)
[exec] Test wms:wmsops-getmap-params-format-2 (wms-1.1.1/d207e1622_1) Failed
[exec] Test wms:wmsops-getmap-params-format-3 (wms-1.1.1/d207e1635_1) Failed
[exec] Test wms:wmsops-getmap-params-format-4 (wms-1.1.1/d207e1647_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-1 (wms-1.1.1/d207e1659_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-2 (wms-1.1.1/d207e1673_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-3 (wms-1.1.1/d207e1689_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d207e1706_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-6 (wms-1.1.1/d207e1718_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-7 (wms-1.1.1/d207e1732_1) Failed
[exec] Test wms:wmsops-getmap-params-request-1 (wms-1.1.1/d207e1746_1) Failed
[exec] Test wms:wmsops-getmap-params-srs-1 (wms-1.1.1/d207e1760_1) Failed
[exec] Test wms:wmsops-getmap-params-srs-3 (wms-1.1.1/d207e1788_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-1 (wms-1.1.1/d207e1803_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-10 (wms-1.1.1/d207e1819_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-3 (wms-1.1.1/d207e1854_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-4 (wms-1.1.1/d207e1870_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-5 (wms-1.1.1/d207e1886_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-6 (wms-1.1.1/d207e1901_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-7 (wms-1.1.1/d207e1915_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-8 (wms-1.1.1/d207e1938_1) Failed
[exec] Test wms:wmsops-getmap-params-styles-9 (wms-1.1.1/d207e1959_1) Failed
[exec] Test wms:wmsops-getmap-params-transparent-1 (wms-1.1.1/d207e1980_1) Failed
[exec] Test wms:wmsops-getmap-params-transparent-2 (wms-1.1.1/d207e1994_1) Failed
[exec] Test wms:wmsops-getmap-params-transparent-3 (wms-1.1.1/d207e2009_1) Failed
[exec] Test wms:wmsops-getmap-params-version-1 (wms-1.1.1/d207e2023_1) Failed
[exec] Test wms:wmsops-getmap-params-width_height-1 (wms-1.1.1/d207e2037_1) Failed
[exec] Test wms:wmsops-getmap-params-width_height-2 (wms-1.1.1/d207e2056_1) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_1) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_2) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_3) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_4) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_5) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_6) Failed
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d207e2072_7) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_1) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_2) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_3) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_4) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_5) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_6) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_7) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_8) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_9) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_10) Failed
[exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_11) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_1) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_2) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_3) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_4) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_5) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_6) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_7) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_8) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_9) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_10) Failed
[exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_11) Failed
[exec] Test wms:wmsops-getmap-each-srs (wms-1.1.1/d207e2103_1) Failed
[exec] Test wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d207e2131_1) Failed
[exec] Test wms:basic_elements-validate-exception (wms-1.1.1/d207e2137_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 28414
PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
