[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wms-1.1 #85
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/85/display/redirect&gt;
[...truncated 751.17 KB...]
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
     [exec] java.lang.NullPointerException
     [exec] at com.occamlab.te.saxon.TEJavaFunctionCall.iterate(TEJavaFunctionCall.java:148)
     [exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
     [exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
     [exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
     [exec] at net.sf.saxon.expr.LazyExpression.evaluateItem(LazyExpression.java:86)
     [exec] at net.sf.saxon.value.SingletonClosure.asItem(SingletonClosure.java:75)
     [exec] at net.sf.saxon.value.Value.asItem(Value.java:69)
     [exec] at net.sf.saxon.expr.VariableReference.evaluateItem(VariableReference.java:421)
     [exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
     [exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
     [exec] at net.sf.saxon.instruct.ElementCreator.processLeavingTail(ElementCreator.java:298)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.ExpressionTool.lazyEvaluate(ExpressionTool.java:431)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:144)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
     [exec] ... 190 more
     [exec] Caused by: java.lang.NullPointerException
     [exec] at java.net.URLEncoder.encode(URLEncoder.java:204)
     [exec] at java.net.URLEncoder.encode(URLEncoder.java:170)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:498)
     [exec] at com.occamlab.te.saxon.TEJavaFunctionCall.iterate(TEJavaFunctionCall.java:138)
     [exec] ... 229 more
     [exec]
     [exec] Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
     [exec] Test wms:basic_elements-validate-exception Failed
     [exec] Test wms:wms_main Failed (Inherited failure)
     [exec] Suite wms:main_wms Failed
     [copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wms-1.1/ws/tools/users/geoserver/wms-1.1.1&gt;
BUILD SUCCESSFUL
Total time: 7 seconds
+ ant wms-1.1-log
+ grep Failed
     [exec] Test wms:wms_main (wms-1.1.1) Failed (Inherited Failure)
     [exec] Test wms:basic_elements-param_rules-order_and_case-3 (wms-1.1.1/d247e766_1) Failed
     [exec] Test wms:basic_elements-version-negotiation-2 (wms-1.1.1/d247e804_1) Failed
     [exec] Test wms:basic_elements-version-negotiation-4 (wms-1.1.1/d247e811_1) Failed
     [exec] Test wms:dims-declaring-1 (wms-1.1.1/d247e820_1) Failed
     [exec] Test wms:dims-declaring-3 (wms-1.1.1/d247e828_1) Failed
     [exec] Test wms:dims-declaring-4 (wms-1.1.1/d247e835_1) Failed
     [exec] Test wms:profiles-queryable-1 (wms-1.1.1/d247e865_1) Failed
     [exec] Test wms:profiles-queryable-2 (wms-1.1.1/d247e875_1) Failed
     [exec] Test wms:profiles-queryable-3 (wms-1.1.1/d247e885_1) Failed
     [exec] Test wms:wmsops-getcapabilities-output_formats-1 (wms-1.1.1/d247e895_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-request-1 (wms-1.1.1/d247e902_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-updatesequence-1 (wms-1.1.1/d247e912_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-1 (wms-1.1.1/d247e981_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-2 (wms-1.1.1/d247e988_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-3 (wms-1.1.1/d247e995_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-4 (wms-1.1.1/d247e1002_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-5 (wms-1.1.1/d247e1009_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-6 (wms-1.1.1/d247e1016_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-1 (wms-1.1.1/d247e1024_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-2 (wms-1.1.1/d247e1031_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-capability_metadata-1 (wms-1.1.1/d247e1038_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-capability_metadata-2 (wms-1.1.1/d247e1047_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-general_metadata-1 (wms-1.1.1/d247e1055_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-general_metadata-2 (wms-1.1.1/d247e1064_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-bbox-1 (wms-1.1.1/d247e1073_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-1 (wms-1.1.1/d247e1080_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-2 (wms-1.1.1/d247e1087_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1 (wms-1.1.1/d247e1094_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2 (wms-1.1.1/d247e1101_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-1 (wms-1.1.1/d247e1108_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-2 (wms-1.1.1/d247e1116_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-srs-1 (wms-1.1.1/d247e1123_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-style-1 (wms-1.1.1/d247e1130_1) Failed
     [exec] Test wms:wmsops-getmap-params-exceptions-1 (wms-1.1.1/d247e1541_1) Failed
     [exec] Test wms:wmsops-getmap-params-exceptions-2 (wms-1.1.1/d247e1550_1) Failed
     [exec] Test wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d247e1706_1) Failed
     [exec] Test wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d247e2131_1) Failed
     [exec] Test wms:basic_elements-validate-exception (wms-1.1.1/d247e2137_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 10605
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/86/display/redirect&gt;
[...truncated 881.17 KB...]
Dec 10, 2018 12:31:19 AM org.geoserver.GeoserverInitStartupListener contextDestroyed
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.XorConstCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibShearRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ShearRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MagnitudeSquaredCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibAddConstRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AddConstCRIF
INFO: Unregistering JAI factory class it.geosolutions.jaiext.rlookup.RangeLookupRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibAndRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AndCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.StreamRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ColorConvertCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibXorRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.XorCRIF
INFO: Unregistering JAI factory class it.geosolutions.jaiext.classifier.RasterClassifierCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibAbsoluteRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AbsoluteCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibSubtractFromConstRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.SubtractFromConstCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibCompositeRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.CompositeCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.BMPRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.TIFFRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibBoxFilterRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.BoxFilterRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibBandSelectRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.BandSelectCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibDFTRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.DFTCRIF
INFO: Unregistering JAI factory class it.geosolutions.jaiext.buffer.BufferRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibErodeRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ErodeRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibMultiplyConstRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MultiplyConstCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibUnsharpMaskRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.UnsharpMaskRIF
INFO: Unregistering JAI factory class it.geosolutions.jaiext.vectorbin.VectorBinarizeRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibMinFilterRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MinFilterRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibExpRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ExpCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ColorQuantizerRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.OverlayCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibAndConstRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AndConstCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.FileLoadRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibSubsampleAverageRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.SubsampleAverageCRIF
INFO: Unregistering JAI factory class it.geosolutions.jaiext.scale.Scale2CRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibThresholdRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ThresholdCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MatchCDFCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MultiplyComplexCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibScaleRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ScaleCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibDivideRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.DivideCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibClampRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ClampCRIF
INFO: Unregistering JAI factory class org.jaitools.media.jai.contour.ContourRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibAffineRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AffineCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AWTImageRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MagnitudeCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibLookupRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.LookupCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibSubsampleBinaryToGrayRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.SubsampleBinaryToGrayCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibNotRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.NotCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibIDCTRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.IDCTCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibDivideIntoConstRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.DivideIntoConstCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.ImageFunctionRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibMedianFilterRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MedianFilterRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibFilteredSubsampleRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.FilteredSubsampleRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibMinRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.MinCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.WarpRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibWarpRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.PeriodicShiftCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.FPXRIF
INFO: Unregistering JAI factory class com.sun.media.jai.mlib.MlibTransposeRIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.TransposeCRIF
INFO: Unregistering JAI factory class com.sun.media.jai.imageioimpl.ImageReadCIF
INFO: Unregistering JAI factory class com.sun.media.jai.opimage.AddConstToCollectionCIF
INFO: Unregistering JAI factory class com.sun.media.jai.imageioimpl.ImageWriteCIF
INFO: Unregistering JAI factory class com.sun.media.jai.tilecodec.RawTileDecoderFactory
INFO: Unregistering JAI factory class com.sun.media.jai.tilecodec.JPEGTileDecoderFactory
INFO: Unregistering JAI factory class com.sun.media.jai.tilecodec.GZIPTileDecoderFactory
INFO: Unregistering JAI factory class com.sun.media.jai.tilecodec.RawTileEncoderFactory
INFO: Unregistering JAI factory class com.sun.media.jai.tilecodec.JPEGTileEncoderFactory
INFO: Unregistering JAI factory class com.sun.media.jai.tilecodec.GZIPTileEncoderFactory
INFO: Cleaned up javabean caches
BUILD SUCCESSFUL
Total time: 19 seconds
+ ant wms-1.1-log
+ grep Failed
2018-12-10 00:31:20.947:INFO:oejsh.ContextHandler:ShutdownMonitor: Stopped o.e.j.w.WebAppContext@anonymised.com{/geoserver,<https://build.geoserver.org/job/2.14-cite-wms-1.1/ws/geoserver/geoserver-2.14-SNAPSHOT/webapps/geoserver/,UNAVAILABLE\}{/geoserver}>
     [exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_8) Failed
     [exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_9) Failed
     [exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_10) Failed
     [exec] Test wms:wmsops-getmap-each-style (wms-1.1.1/d207e2083_11) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_1) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_2) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_3) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_4) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_5) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_6) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_7) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_8) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_9) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_10) Failed
     [exec] Test wms:wmsops-getmap-each-layer (wms-1.1.1/d207e2093_11) Failed
     [exec] Test wms:wmsops-getmap-each-srs (wms-1.1.1/d207e2103_1) Failed
     [exec] Test wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d207e2131_1) Failed
     [exec] Test wms:basic_elements-validate-exception (wms-1.1.1/d207e2137_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 30381
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/87/display/redirect&gt;
