See <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/290/>
[...truncated 9576 lines...]
[exec] Test wfs:delete-feature Passed
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24894_1)...
[exec] Assertion:
[exec] Deletes a feature by typename and gml:name.
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24904_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24913_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24922_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24931_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24940_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24949_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24959_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24968_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24977_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24986_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24995_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25004_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25014_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25023_1)...
[exec] Assertion:
[exec]
[exec] Testing wfs:filter-delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25066_1)...
[exec] Assertion:
[exec] Deletes a feature by by a manual filter.
[exec]
[exec] Test wfs:filter-delete-feature Passed
[exec] Test wfs:delete-test-data Passed
[exec] Test wfs:run-Transaction-Cleanup Passed
[exec] Test wfs:run-Transaction-POST Passed
[exec] LockFeature using the POST method is implemented.
[exec] Testing wfs:run-LockFeature-POST (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1)...
[exec] Assertion: Run test group for LockFeature requests using the POST method
[exec] Testing wfs:LockFeature-expiry (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29403_1)...
[exec] Assertion: After a LockFeature request with an expiry attribute is submitted and the time expires, the lock is released.
[exec] Unable to acquire lock on PrimitiveGeoFeature.8
[exec] Test wfs:LockFeature-expiry Passed
[exec] Testing wfs:LockFeature-some-features (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29408_1)...
[exec] Assertion: In response to a LockFeature request that includes some locked and some unlocked feature identifiers and lockAction=SOME, the response is a 'WFS_LockFeatureResponse' element that lists the previously unlocked feature ids in the 'FeaturesLocked' element and the previously locked feature ids in the 'FeaturesNotLocked' element. The previously unlocked features are locked.
[exec] Unable to acquire lock on PrimitiveGeoFeature.3
[exec] Test wfs:LockFeature-some-features Passed
[exec] Testing wfs:LockFeature-all-features (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29413_1)...
[exec] Assertion: The response to a LockFeature request includes the identifiers of features that were locked.
[exec] Test wfs:LockFeature-all-features Passed
[exec] Testing wfs:LockFeature-identifiers-none (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29418_1)...
[exec] Assertion: In response to a LockFeature request that contains a filter that doesn't match any features, the response is a 'WFS_LockFeatureResponse' document that contains a value for the lockId attribute but contains neither a 'FeaturesLocked' element nor a 'FeatureNotLocked' element.
[exec] Test wfs:LockFeature-identifiers-none Passed
[exec] Testing wfs:LockFeature-invalid-request (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29423_1)...
[exec] Assertion: An invalid LockFeature request results in an exception.
[exec] Test wfs:LockFeature-invalid-request Passed
[exec] Target endpoint is http://localhost:11010/geoserver/wfs
[exec] Testing wfs:wfs-1.1.0-LockFeature-tc1.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1)...
[exec] Assertion:
[exec] The response to a LockFeature request that specifies lockAction="ALL" must
[exec] include a response that identifies all locked features. If any candidate
[exec] features cannot be locked, then no feature shall be locked and an exception
[exec] report is returned.
[exec]
[exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1/d41e29659_1)...
[exec] Assertion: Validate an XML instance against a Schematron schema using the given phase.
[exec] Test ctl:SchematronValidatingParser Passed
[exec] Testing wfs:GetFeatureById-KVP (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1/d41e29696_1)...
[exec] Assertion: Attempts to fetch a feature by identifier using the GetFeature/GET binding.
[exec] Validation warning:
[exec] SchemaLocation: schemaLocation value = ' http://localhost:11010/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=sf%3APrimitiveGeoFeature http://www.opengis.net/wfs http://localhost:11010/geoserver/schemas/wfs/1.1.0/wfs.xsd’ must have even number of URI's.
[exec] 1 warning detected.
[exec]
[exec] Test wfs:GetFeatureById-KVP Passed
[exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1/d41e29762_1)...
[exec] Assertion: Attempt to fetch a feature by name using the GetFeature/POST binding.
[exec] Test wfs:GetFeatureByName Passed
[exec] Test wfs:wfs-1.1.0-LockFeature-tc1.1 Passed
[exec] Testing wfs:wfs-1.1.0-LockFeature-tc2.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29467_1)...
[exec] Assertion:
[exec] The response to a Transaction request that specifies an invalid LockId
[exec] value must include an exception report.
[exec]
[exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29467_1/d41e29851_1)...
[exec] Test wfs:wfs-1.1.0-LockFeature-tc2.1 Passed
[exec] Testing wfs:wfs-1.1.0-LockFeature-tc3.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1)...
[exec] Assertion:
[exec] In response to a Transaction request that specifies releaseAction="SOME",
[exec] only modified features in the lock set shall be unlocked.
[exec]
[exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1/d41e30125_1)...
[exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1/d41e30186_1)...
[exec] Test wfs:wfs-1.1.0-LockFeature-tc3.1 Passed
[exec] Test wfs:run-LockFeature-POST Passed
[exec] GetFeatureWithLock using the POST method is implemented.
[exec] Testing wfs:run-GetFeatureWithLock-POST (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1)...
[exec] Assertion: Run test group for GetFeatureWithLock requests using the POST method
[exec] Testing wfs:GetFeatureWithLock-Xlink (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30794_1)...
[exec] Assertion: Execute WFS transaction with XlinkPropertyName and test for exception.
[exec] sf:LinkedFeature does not exist
[exec] Test wfs:GetFeatureWithLock-Xlink Passed
[exec] Testing wfs:wfs-1.1.0-GetFeatureWithLock-tc1.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1)...
[exec] Assertion:
[exec]
[exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1/d41e31021_1)...
[exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1/d41e31058_1)...
[exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1/d41e31126_1)...
[exec] Test wfs:wfs-1.1.0-GetFeatureWithLock-tc1.1 Passed
[exec] Testing wfs:wfs-1.1.0-GetFeatureWithLock-tc2.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30837_1)...
[exec] Assertion:
[exec] If locks on all matching features cannot be acquired, the response to a
[exec] GetFeatureWithLock request must include an exception report.
[exec]
[exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30837_1/d41e31239_1)...
[exec] Test wfs:wfs-1.1.0-GetFeatureWithLock-tc2.1 Passed
[exec] Test wfs:run-GetFeatureWithLock-POST Passed
[exec] Test wfs:transaction-main Passed
[exec] Test wfs:readiness-tests Failed (Inherited failure)
[exec] Test wfs:wfs-main Failed (Inherited failure)
[exec] Suite ctl:wfs-1.1.0-compliance-suite Failed
[exec] Timeout: killed the sub-process
[exec] Result: 143
[copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/ws/tools/users/geoserver/wfs-1.1.0>
BUILD SUCCESSFUL
Total time: 15 minutes 0 seconds
+ ant wfs-1.1-log
+ grep Failed
[exec] Test wfs:wfs-main (wfs-1.1.0) Failed (Inherited Failure)
[exec] Test wfs:readiness-tests (wfs-1.1.0/d41e34700_1) Failed (Inherited Failure)
[exec] Test wfs:basic-main (wfs-1.1.0/d41e34700_1/d41e749_1) Failed (Inherited Failure)
[exec] Test wfs:run-DescribeFeatureType-POST (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1) Failed (Inherited Failure)
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc3.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5112_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc3.2 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5117_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc3.3 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5123_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc3.4 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5128_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc6.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5138_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc7.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5143_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc9.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5150_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc11.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5156_1) Failed
[exec] Test wfs:run-DescribeFeatureType-GET (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1) Failed (Inherited Failure)
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc1.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3820_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc4.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3825_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc5.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3846_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc8.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3851_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc10.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3858_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc12.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3863_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.4-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.4-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 22932
PID TTY STAT TIME COMMAND
22932 ? Sl 1:33 /usr/lib/jvm/java-6-sun-i586/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/ws/geoserver_data/2.4.x/citewfs-1.1> -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 22932
+ exit 1
Build step 'Execute shell' marked build as failure
