[Geoserver-devel] Build failed in Jenkins: 2.4-cite-wfs-1.1 #5
See <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/5/&gt;
[...truncated 4436 lines...]
     [exec] Test wfs:delete-feature Passed
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24959_1)...
     [exec] Assertion:
     [exec] Deletes a feature by typename and gml:name.
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24968_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24977_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24986_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24995_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25004_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25014_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25023_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:filter-delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e25066_1)...
     [exec] Assertion:
     [exec] Deletes a feature by by a manual filter.
     [exec]
     [exec] Test wfs:filter-delete-feature Passed
     [exec] Test wfs:delete-test-data Passed
     [exec] Test wfs:run-Transaction-Cleanup Passed
     [exec] Test wfs:run-Transaction-POST Failed (Inherited failure)
     [exec] LockFeature using the POST method is implemented.
     [exec] Testing wfs:run-LockFeature-POST (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1)...
     [exec] Assertion: Run test group for LockFeature requests using the POST method
     [exec] Testing wfs:LockFeature-expiry (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29403_1)...
     [exec] Assertion: After a LockFeature request with an expiry attribute is submitted and the time expires, the lock is released.
     [exec] Unable to acquire lock on PrimitiveGeoFeature.8
     [exec] Test wfs:LockFeature-expiry Passed
     [exec] Testing wfs:LockFeature-some-features (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29408_1)...
     [exec] Assertion: In response to a LockFeature request that includes some locked and some unlocked feature identifiers and lockAction=SOME, the response is a 'WFS_LockFeatureResponse' element that lists the previously unlocked feature ids in the 'FeaturesLocked' element and the previously locked feature ids in the 'FeaturesNotLocked' element. The previously unlocked features are locked.
     [exec] Unable to acquire lock on PrimitiveGeoFeature.3
     [exec] Test wfs:LockFeature-some-features Passed
     [exec] Testing wfs:LockFeature-all-features (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29413_1)...
     [exec] Assertion: The response to a LockFeature request includes the identifiers of features that were locked.
     [exec] Test wfs:LockFeature-all-features Passed
     [exec] Testing wfs:LockFeature-identifiers-none (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29418_1)...
     [exec] Assertion: In response to a LockFeature request that contains a filter that doesn't match any features, the response is a 'WFS_LockFeatureResponse' document that contains a value for the lockId attribute but contains neither a 'FeaturesLocked' element nor a 'FeatureNotLocked' element.
     [exec] Test wfs:LockFeature-identifiers-none Passed
     [exec] Testing wfs:LockFeature-invalid-request (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29423_1)...
     [exec] Assertion: An invalid LockFeature request results in an exception.
     [exec] Test wfs:LockFeature-invalid-request Passed
     [exec] Target endpoint is http://localhost:11010/geoserver/wfs
     [exec] Testing wfs:wfs-1.1.0-LockFeature-tc1.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1)...
     [exec] Assertion:
     [exec] The response to a LockFeature request that specifies lockAction="ALL" must
     [exec] include a response that identifies all locked features. If any candidate
     [exec] features cannot be locked, then no feature shall be locked and an exception
     [exec] report is returned.
     [exec]
     [exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1/d41e29659_1)...
     [exec] Assertion: Validate an XML instance against a Schematron schema using the given phase.
     [exec] Test ctl:SchematronValidatingParser Passed
     [exec] Testing wfs:GetFeatureById-KVP (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1/d41e29696_1)...
     [exec] Assertion: Attempts to fetch a feature by identifier using the GetFeature/GET binding.
     [exec] Validation warning:
     [exec] SchemaLocation: schemaLocation value = ' http://localhost:11010/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=sf%3APrimitiveGeoFeature http://www.opengis.net/wfs http://localhost:11010/geoserver/schemas/wfs/1.1.0/wfs.xsd’ must have even number of URI's.
     [exec] 1 warning detected.
     [exec]
     [exec] Test wfs:GetFeatureById-KVP Passed
     [exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29453_1/d41e29762_1)...
     [exec] Assertion: Attempt to fetch a feature by name using the GetFeature/POST binding.
     [exec] Test wfs:GetFeatureByName Passed
     [exec] Test wfs:wfs-1.1.0-LockFeature-tc1.1 Passed
     [exec] Testing wfs:wfs-1.1.0-LockFeature-tc2.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29467_1)...
     [exec] Assertion:
     [exec] The response to a Transaction request that specifies an invalid LockId
     [exec] value must include an exception report.
     [exec]
     [exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29467_1/d41e29851_1)...
     [exec] Test wfs:wfs-1.1.0-LockFeature-tc2.1 Passed
     [exec] Testing wfs:wfs-1.1.0-LockFeature-tc3.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1)...
     [exec] Assertion:
     [exec] In response to a Transaction request that specifies releaseAction="SOME",
     [exec] only modified features in the lock set shall be unlocked.
     [exec]
     [exec] FAILURE: Expected 2 or more sf:Entit?G?n?rique instances to be locked (reported 0)
     [exec] FAILURE: Expected totalUpdated = 1 (reported total is )
     [exec] FAILURE: Expected totalDeleted = 1 (feature with gml:name="cite.gmlsf0-f502" should be UNLOCKED)
     [exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1/d41e30125_1)...
     [exec] FAILURE: Expected valid wfs:FeatureCollection in response.
     [exec] Test wfs:GetFeatureByName Failed
     [exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1/d41e30186_1)...
     [exec] Test wfs:wfs-1.1.0-LockFeature-tc3.1 Failed
     [exec] Test wfs:run-LockFeature-POST Failed (Inherited failure)
     [exec] GetFeatureWithLock using the POST method is implemented.
     [exec] Testing wfs:run-GetFeatureWithLock-POST (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1)...
     [exec] Assertion: Run test group for GetFeatureWithLock requests using the POST method
     [exec] Testing wfs:GetFeatureWithLock-Xlink (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30794_1)...
     [exec] Assertion: Execute WFS transaction with XlinkPropertyName and test for exception.
     [exec] sf:LinkedFeature does not exist
     [exec] Test wfs:GetFeatureWithLock-Xlink Passed
     [exec] Testing wfs:wfs-1.1.0-GetFeatureWithLock-tc1.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1/d41e31021_1)...
     [exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1/d41e31058_1)...
     [exec] Testing wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30824_1/d41e31126_1)...
     [exec] Test wfs:wfs-1.1.0-GetFeatureWithLock-tc1.1 Passed
     [exec] Testing wfs:wfs-1.1.0-GetFeatureWithLock-tc2.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30837_1)...
     [exec] Assertion:
     [exec] If locks on all matching features cannot be acquired, the response to a
     [exec] GetFeatureWithLock request must include an exception report.
     [exec]
     [exec] Testing ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31434_1/d41e30837_1/d41e31239_1)...
     [exec] Test wfs:wfs-1.1.0-GetFeatureWithLock-tc2.1 Passed
     [exec] Test wfs:run-GetFeatureWithLock-POST Passed
     [exec] Test wfs:transaction-main Failed (Inherited failure)
     [exec] Test wfs:readiness-tests Failed (Inherited failure)
     [exec] Test wfs:wfs-main Failed (Inherited failure)
     [exec] Suite ctl:wfs-1.1.0-compliance-suite Failed
     [exec] Timeout: killed the sub-process
     [exec] Result: 143
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/ws/tools/users/geoserver/wfs-1.1.0&gt;
BUILD SUCCESSFUL
Total time: 15 minutes 0 seconds
+ ant wfs-1.1-log
+ grep Failed
     [exec] Test wfs:wfs-main (wfs-1.1.0) Failed (Inherited Failure)
     [exec] Test wfs:readiness-tests (wfs-1.1.0/d41e34700_1) Failed (Inherited Failure)
     [exec] Test wfs:basic-main (wfs-1.1.0/d41e34700_1/d41e749_1) Failed (Inherited Failure)
     [exec] Test wfs:run-DescribeFeatureType-POST (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc11.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5156_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24749_1/d41e5156_1/d41e6003_1) Failed
     [exec] Test wfs:run-DescribeFeatureType-GET (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc12.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3863_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24759_1/d41e3863_1/d41e4693_1) Failed
     [exec] Test wfs:run-GetFeature-POST (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc15.3 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15565_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15565_1/d41e17814_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15565_1/d41e17824_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc29.4 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15684_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc35.4 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15715_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15715_1/d41e20515_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15715_1/d41e20525_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15715_1/d41e20536_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc35.7 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15730_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15730_1/d41e20814_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15730_1/d41e20824_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15730_1/d41e20835_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc36.4 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15751_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15751_1/d41e21226_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15751_1/d41e21236_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15751_1/d41e21247_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc43.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15876_1) Failed
     [exec] Test wfs:run-GetFeature-POST-logicalops (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15958_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc100.2 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15958_1/d41e8360_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc100.3 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15958_1/d41e8365_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc102.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15958_1/d41e8386_1) Failed
     [exec] Test wfs:run-GetFeature-POST-spatialops (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15966_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc200.2 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15966_1/d41e9470_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc201.2 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15966_1/d41e9508_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc204.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15966_1/d41e9544_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc205.3 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15966_1/d41e9573_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc206.2 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15966_1/d41e9586_1) Failed
     [exec] Test wfs:run-GetFeature-GET (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24784_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc46.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24784_1/d41e6185_1) Failed (Inherited Failure)
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24784_1/d41e6185_1/d41e7486_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24784_1/d41e6185_1/d41e7496_1) Failed
     [exec] Test ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24784_1/d41e6185_1/d41e7507_1) Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc48.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24784_1/d41e6201_1) Failed
     [exec] Test wfs:transaction-main (wfs-1.1.0/d41e34700_1/d41e760_1) Failed (Inherited Failure)
     [exec] Test wfs:run-Transaction-POST (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-Transaction-tc1.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26066_1) Failed (Inherited Failure)
     [exec] Test ctl:SchematronValidatingParser (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26066_1/d41e26386_1) Failed
     [exec] Test wfs:wfs-1.1.0-Transaction-tc7.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26118_1) Failed
     [exec] Test wfs:wfs-1.1.0-Transaction-tc13.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26166_1) Failed (Inherited Failure)
     [exec] Test wfs:GetFeatureById-KVP (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26166_1/d41e28841_1) Failed
     [exec] Test wfs:GetFeatureById-KVP (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26166_1/d41e28851_1) Failed
     [exec] Test wfs:GetFeatureById-KVP (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26166_1/d41e28860_1) Failed
     [exec] Test wfs:run-LockFeature-POST (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1) Failed (Inherited Failure)
     [exec] Test wfs:wfs-1.1.0-LockFeature-tc3.1 (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1) Failed
     [exec] Test wfs:GetFeatureByName (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31421_1/d41e29472_1/d41e30125_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.4-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.4-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/6/&gt;
[...truncated 4392 lines...]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24858_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24867_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24876_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24885_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24894_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24904_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24913_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24922_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24931_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24940_1)...
     [exec] Assertion:
     [exec]
     [exec] Testing wfs:delete-feature (wfs-1.1.0/d41e34700_1/d41e760_1/d41e31404_1/d41e26192_1/d41e24831_1/d41e24949_1)...
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Test wfs:run-Transaction-POST Passed
     [exec] Assertion:
     [exec]
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Test wfs:wfs-1.1.0-LockFeature-tc3.1 Passed
     [exec] Test wfs:run-LockFeature-POST Passed
     [exec] Assertion:
     [exec]
     [exec] Assertion:
     [exec]
     [exec] Test wfs:transaction-main Passed
     [exec] Result: 143
BUILD SUCCESSFUL
+ ant wfs-1.1-log
+ grep Failed
     [exec] Test wfs:wfs-1.1.0-Basic-GetFeature-tc6.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24772_1/d41e15483_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/7/&gt;
