See <http://ares.opengeo.org/jenkins/job/2.5-cite-wcs-1.1/44/>
[...truncated 17083 lines...]
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:625)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.callTest(TECore.java:586)
[exec] at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[exec] at java.lang.reflect.Method.invoke(Method.java:597)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
[exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
[exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
[exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
[exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
[exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public java.lang.Object com.occamlab.te.TECore.callFunction(net.sf.saxon.expr.XPathContext,java.lang.String,java.lang.String,net.sf.saxon.om.NodeInfo) throws java.lang.Exception}: Exception in extension function net.sf.saxon.s9api.SaxonApiException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.ConnectException: Connection refused
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
[exec] at net.sf.saxon.expr.Expression.evaluateItem(Expression.java:352)
[exec] at net.sf.saxon.expr.Expression.process(Expression.java:461)
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] ... 145 more
[exec] Caused by: net.sf.saxon.s9api.SaxonApiException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.ConnectException: Connection refused
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:192)
[exec] at com.occamlab.te.TECore.executeXSLFunction(TECore.java:681)
[exec] at com.occamlab.te.TECore.callFunction(TECore.java:709)
[exec] at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
[exec] ... 160 more
[exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.ConnectException: Connection refused
[exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
[exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
[exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
[exec] ... 169 more
[exec] Caused by: java.net.ConnectException: Connection refused
[exec] at java.net.PlainSocketImpl.socketConnect(Native Method)
[exec] at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
[exec] at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
[exec] at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
[exec] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
[exec] at java.net.Socket.connect(Socket.java:529)
[exec] at java.net.Socket.connect(Socket.java:478)
[exec] at sun.net.NetworkClient.doConnect(NetworkClient.java:163)
[exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:394)
[exec] at sun.net.www.http.HttpClient.openServer(HttpClient.java:529)
[exec] at sun.net.www.http.HttpClient.<init>(HttpClient.java:233)
[exec] at sun.net.www.http.HttpClient.New(HttpClient.java:306)
[exec] at sun.net.www.http.HttpClient.New(HttpClient.java:323)
[exec] at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:975)
[exec] at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:916)
[exec] at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:841)
[exec] at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1019)
[exec] at com.occamlab.te.TECore.build_request(TECore.java:1372)
[exec] at com.occamlab.te.TECore.request(TECore.java:1122)
[exec] at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
[exec] ... 181 more
[copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.5-cite-wcs-1.1/ws/tools/users/geoserver/wcs-1.1.1>
BUILD SUCCESSFUL
Total time: 2 minutes 45 seconds
+ ant wcs-1.1-log
+ grep Failed
[exec] Test wcs:Main (wcs-1.1.1) Failed (Inherited Failure)
[exec] Test wcs:GetCoverage-main (wcs-1.1.1/d41e339_1) Failed (Inherited Failure)
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_One_Key (wcs-1.1.1/d41e339_1/d41e11483_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Some_Keys (wcs-1.1.1/d41e339_1/d41e11529_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Some_Keys (wcs-1.1.1/d41e339_1/d41e11553_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_All_Keys (wcs-1.1.1/d41e339_1/d41e11599_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_All_Keys (wcs-1.1.1/d41e339_1/d41e11623_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_No_Key (wcs-1.1.1/d41e339_1/d41e11669_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_No_Key (wcs-1.1.1/d41e339_1/d41e11693_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Bogus_Key (wcs-1.1.1/d41e339_1/d41e11739_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Bogus_Key (wcs-1.1.1/d41e339_1/d41e11763_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Field_Identifier_And_InterpolationMethod (wcs-1.1.1/d41e339_1/d41e11966_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Identifiers (wcs-1.1.1/d41e339_1/d41e12012_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Keys (wcs-1.1.1/d41e339_1/d41e12058_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier (wcs-1.1.1/d41e339_1/d41e12104_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key (wcs-1.1.1/d41e339_1/d41e12150_1) Failed
[exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket (wcs-1.1.1/d41e339_1/d41e12196_1) Failed
[exec] Test wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12242_1) Failed
[exec] Test wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12266_1) Failed
[exec] Test wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12312_1) Failed
[exec] Test wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12336_1) Failed
[exec] Test wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12382_1) Failed
[exec] Test wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12406_1) Failed
[exec] Test wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12452_1) Failed
[exec] Test wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12476_1) Failed
[exec] Test wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12522_1) Failed
[exec] Test wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12547_1) Failed
[exec] Test wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12593_1) Failed
[exec] Test wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12617_1) Failed
[exec] Test wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12663_1) Failed
[exec] Test wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12687_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.5-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.5-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 10289
PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
