See <http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.1/203/>
[...truncated 2023 lines...]
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.callTest(TECore.java:586)
[exec] at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[exec] at java.lang.reflect.Method.invoke(Method.java:606)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
[exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
[exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
[exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
[exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
[exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec]
[copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.1/ws/tools/users/geoserver/wms-1.1.1>
BUILD SUCCESSFUL
Total time: 5 minutes 49 seconds
+ ant wms-1.1-log
+ grep Failed
[exec] Test wms:wms_main (wms-1.1.1) Failed (Inherited Failure)
[exec] Test wms:wmsops-getcapabilities-response-2 (wms-1.1.1/d247e1031_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.6-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.6-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 25393
PID TTY STAT TIME COMMAND
25393 ? Sl 1:08 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.1/ws/geoserver_data/2.6.x/citewms-1.1> -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 25393
+ exit 1
Build step 'Execute shell' marked build as failure
