[Geoserver-devel] Build failed in Jenkins: 2.7-cite-wfs-1.0 #83
See <http://ares.opengeo.org/jenkins/job/2.7-cite-wfs-1.0/83/&gt;
[...truncated 4897 lines...]
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Can't instantiate parser wfs:GMLValidatingParser
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] ... 190 more
     [exec] Caused by: java.lang.Exception: Can't instantiate parser wfs:GMLValidatingParser
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1526)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:606)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] ... 205 more
     [exec] Caused by: java.lang.reflect.InvocationTargetException
     [exec] at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
     [exec] at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
     [exec] at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
     [exec] at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
     [exec] at com.occamlab.te.util.Misc.makeInstance(Misc.java:192)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1524)
     [exec] ... 213 more
     [exec] Caused by: java.lang.IllegalArgumentException: Connection timed out
     [exec] at com.galdosinc.glib.xml.jaxp.ValidatingDocumentBuilderFactory.setAttribute(ValidatingDocumentBuilderFactory.java:62)
     [exec] at com.occamlab.te.parsers.GMLValidatingParser.<init>(GMLValidatingParser.java:79)
     [exec] ... 219 more
     [exec]
     [exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Can't instantiate parser wfs:GMLValidatingParser
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-12 Failed
     [exec] Testing wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-13 (wfs-1.0.0/d41e1113_1)...
     [exec] Assertion: This test checks that the PropertyIsLessThan operator returns the correct feature for a number comparisson with the value greater than the expected value of the property.
     [exec] Timeout: killed the sub-process
     [exec] Result: 143
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.7-cite-wfs-1.0/ws/tools/users/geoserver/wfs-1.0.0&gt;
BUILD SUCCESSFUL
Total time: 15 minutes 0 seconds
+ ant wfs-1.0-log
+ grep Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d41e825_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d41e845_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d41e851_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d41e856_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d41e861_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-1 (wfs-1.0.0/d41e868_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-5 (wfs-1.0.0/d41e901_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-6 (wfs-1.0.0/d41e909_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-7 (wfs-1.0.0/d41e917_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-8 (wfs-1.0.0/d41e925_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-1 (wfs-1.0.0/d41e1080_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-10 (wfs-1.0.0/d41e1089_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-11 (wfs-1.0.0/d41e1097_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-12 (wfs-1.0.0/d41e1105_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.7-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.7-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 17018
  PID TTY STAT TIME COMMAND
17018 ? Sl 1:03 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/2.7-cite-wfs-1.0/ws/geoserver_data/2.7.x/citewfs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 17018
+ exit 1
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/2.7-cite-wfs-1.0/84/&gt;
