[Geoserver-devel] Build failed in Jenkins: 2.8-cite-wcs-1.0 #23
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/23/&gt;
[...truncated 1396 lines...]
war:
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/teamengine.war&gt;
jar.realm:
compile:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build&gt;
    [javac] <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build.xml&gt;:13: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
    [javac] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build&gt;
warning: [options] bootstrap class path not set in conjunction with -source 1.6
Note: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/src/java/com/occamlab/te/realm/UserFilesRealm.java&gt; uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 warning
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/build/com/occamlab/te/realm&gt;
jar:
      [jar] Building jar: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/setup/UserFilesRealm/UserFilesRealm.jar&gt;
zip.manager.bin:
   [delete] Deleting directory <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build&gt;
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build&gt;
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.23&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.23&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.23-bin.zip&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ cite ---
[debug] execute contextualize
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ cite ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.10:test (default-test) @ cite ---
[INFO] No tests to run.
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/surefire-reports&gt;
T E S T S
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ cite ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/cite-1.0.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ cite ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/cite-1.0.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/cite/1.0/cite-1.0.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/cite/1.0/cite-1.0.pom
[INFO] BUILD SUCCESS
[INFO] Total time: 30.249s
[INFO] Finished at: Fri Oct 23 19:39:56 UTC 2015
[INFO] Final Memory: 22M/283M
+ ant clean
Buildfile: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/build.xml&gt;
clean:
BUILD SUCCESSFUL
Total time: 0 seconds
+ pushd ..
~/workspace/geoserver-cite ~/workspace/geoserver-cite/tools ~/workspace/geoserver-cite
++ pwd
+ FORMS=<http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/forms&gt;
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/forms&gt; wcs-1.0
wcs-1.0:
run-test:
     [exec] Oct 23, 2015 7:39:59 PM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl&gt;
     [exec] INFO: Validating <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl&gt;
     [exec] INFO: Validating <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/scripts/wcs-1.0.0/ctl/wcs.xml&gt;
     [exec] Checking for <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/forms/wcs-1.0.0.xml&gt;
     [exec] Testing suite wcs1-0-0:main_wcs1-0-0...
     [exec] Testing wcs1-0-0:main (wcs-1.0.0)...
     [exec] Assertion: The WCS 1.0.0 implementation being tested behaves properly
     [exec] Oct 23, 2015 7:40:07 PM com.occamlab.te.TECore parse
     [exec] SEVERE: parse Error
     [exec] java.io.FileNotFoundException: http://localhost:11010/geoserver/ows?service=wcs&version=1.0.0&request=GetCapabilities
     [exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE= at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1624)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1501)
     [exec]
     [exec] Test wcs1-0-0:main Failed
     [exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:606)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec]
     [exec] Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=; SystemID: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/work/~2Fvar~2Flib~2Fjenkins~2Fworkspace~2Fgeoserver-cite~2Ftools~2Fengine~2Fscripts~2Fwcs-1.0.0~2Fctl~2Fwcs.xml/wcs1-0-0$main.test;&gt; Line#: 204; Column#: -1
     [exec] Oct 23, 2015 7:40:07 PM com.occamlab.te.TECore executeTest
     [exec] SEVERE: SaxonApiException
     [exec] net.sf.saxon.s9api.SaxonApiException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:192)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] ... 6 more
     [exec] Caused by: java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec] at java.net.URL.<init>(URL.java:585)
     [exec] at java.net.URL.<init>(URL.java:482)
     [exec] at java.net.URL.<init>(URL.java:431)
     [exec] at com.occamlab.te.TECore.build_request(TECore.java:1226)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1122)
     [exec] ... 56 more
     [exec]
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/users/geoserver/wcs-1.0.0&gt;
BUILD SUCCESSFUL
Total time: 10 seconds
+ ant wcs-1.0-log
+ grep Failed
     [exec] Test wcs1-0-0:main (wcs-1.0.0) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.8-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.8-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 10903
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/24/&gt;
[...truncated 1385 lines...]
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.24&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.24&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.24-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 33.031s
[INFO] Finished at: Sat Oct 24 23:25:55 UTC 2015
[INFO] Final Memory: 24M/278M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 24, 2015 11:25:58 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 24, 2015 11:26:07 PM com.occamlab.te.TECore parse
     [exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1624)
     [exec]
     [exec] Oct 24, 2015 11:26:07 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
Total time: 11 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 16158
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/25/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.25&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.25&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.25-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 31.831s
[INFO] Finished at: Sun Oct 25 19:19:50 UTC 2015
[INFO] Final Memory: 24M/284M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 25, 2015 7:19:53 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 25, 2015 7:19:54 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 25, 2015 7:20:01 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Oct 25, 2015 7:20:01 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
Total time: 9 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 31445
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/26/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.26&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.26&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.26-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 29.704s
[INFO] Finished at: Mon Oct 26 19:28:07 UTC 2015
[INFO] Final Memory: 21M/262M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 26, 2015 7:28:10 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 26, 2015 7:28:18 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Oct 26, 2015 7:28:18 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.0-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 19903
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/27/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.27&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.27&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.27-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 34.368s
[INFO] Finished at: Tue Oct 27 20:53:23 UTC 2015
[INFO] Final Memory: 21M/259M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 27, 2015 8:53:26 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 27, 2015 8:53:27 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 27, 2015 8:53:34 PM com.occamlab.te.TECore parse
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)Suite wcs1-0-0:main_wcs1-0-0 Failed
     [exec]
     [exec]
     [exec] Oct 27, 2015 8:53:34 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 22310
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/28/&gt;
[...truncated 1386 lines...]
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.28&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.28&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.28-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 32.954s
[INFO] Finished at: Wed Oct 28 22:11:04 UTC 2015
[INFO] Final Memory: 23M/179M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 28, 2015 10:11:07 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 28, 2015 10:11:15 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Oct 28, 2015 10:11:15 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 28801
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/29/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.29&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.29&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.29-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 32.098s
[INFO] Finished at: Thu Oct 29 19:16:38 UTC 2015
[INFO] Final Memory: 21M/260M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 29, 2015 7:16:41 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 29, 2015 7:16:49 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Oct 29, 2015 7:16:49 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 22418
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/30/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.30&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.30&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.30-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 33.948s
[INFO] Finished at: Fri Oct 30 19:16:30 UTC 2015
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 30, 2015 7:16:34 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 30, 2015 7:16:41 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Oct 30, 2015 7:16:41 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 10418
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/31/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.31&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.10.31&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.10.31-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 32.733s
[INFO] Finished at: Sat Oct 31 19:16:33 UTC 2015
[INFO] Final Memory: 25M/277M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Oct 31, 2015 7:16:36 PM com.occamlab.te.Generator generateXsl
     [exec] Oct 31, 2015 7:16:43 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Oct 31, 2015 7:16:43 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 11350
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/32/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.01&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.01&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.01-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 33.529s
[INFO] Finished at: Sun Nov 01 19:16:33 UTC 2015
[INFO] Final Memory: 25M/283M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 01, 2015 7:16:37 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 01, 2015 7:16:44 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Nov 01, 2015 7:16:44 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 23465
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/33/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.02&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.02&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.02-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 32.458s
[INFO] Finished at: Mon Nov 02 20:00:30 UTC 2015
[INFO] Final Memory: 21M/179M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 02, 2015 8:00:34 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 02, 2015 8:00:41 PM com.occamlab.te.TECore parse Test wcs1-0-0:main Failed
     [exec]
     [exec] Suite wcs1-0-0:main_wcs1-0-0 Failedjava.io.FileNotFoundException: http://localhost:11010/geoserver/ows?service=wcs&version=1.0.0&request=GetCapabilities
     [exec]
     [exec]
     [exec] Nov 02, 2015 8:00:41 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 20559
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/34/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.03&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.03&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.03-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 30.124s
[INFO] Finished at: Tue Nov 03 21:18:46 UTC 2015
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 03, 2015 9:18:50 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 03, 2015 9:18:57 PM com.occamlab.te.TECore parse
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
     [exec]
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)Suite wcs1-0-0:main_wcs1-0-0 Failed
     [exec]
     [exec]
     [exec] Nov 03, 2015 9:18:57 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 6188
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/35/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.04&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.04&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.04-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 31.212s
[INFO] Finished at: Wed Nov 04 19:43:37 UTC 2015
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 04, 2015 7:43:40 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 04, 2015 7:43:47 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Nov 04, 2015 7:43:47 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 30722
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/36/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.05&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.05&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.05-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 31.906s
[INFO] Finished at: Thu Nov 05 19:16:29 UTC 2015
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 05, 2015 7:16:32 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 05, 2015 7:16:40 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Nov 05, 2015 7:16:40 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 16793
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/37/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.06&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.06&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.06-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 33.203s
[INFO] Finished at: Fri Nov 06 20:46:17 UTC 2015
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 06, 2015 8:46:20 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 06, 2015 8:46:28 PM com.occamlab.te.TECore parse
     [exec] java.io.FileNotFoundException: http://localhost:11010/geoserver/ows?service=wcs&version=1.0.0&request=GetCapabilitiesjava.io.FileNotFoundException: http://localhost:11010/geoserver/ows?service=wcs&version=1.0.0&request=GetCapabilities
     [exec]
     [exec]
     [exec] Nov 06, 2015 8:46:28 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 23339
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/38/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.07&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.07&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.07-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 34.396s
[INFO] Finished at: Sat Nov 07 22:16:47 UTC 2015
[INFO] Final Memory: 24M/279M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 07, 2015 10:16:50 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 07, 2015 10:16:57 PM com.occamlab.te.TECore parse Test wcs1-0-0:main Failed
     [exec]
     [exec]
     [exec] Nov 07, 2015 10:16:57 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.0-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 7961
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/39/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.08&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.08&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.08-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 35.258s
[INFO] Finished at: Sun Nov 08 19:16:32 UTC 2015
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 08, 2015 7:16:35 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 08, 2015 7:16:43 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Nov 08, 2015 7:16:43 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.0-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 12183
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/40/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
    [mkdir] Created dir: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.09&gt;
     [copy] Copying 2 files to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/build/teamengine-2015.11.09&gt;
      [zip] Building zip: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/zips/teamengine-manager-2015.11.09-bin.zip&gt;
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 33.064s
[INFO] Finished at: Mon Nov 09 15:38:31 UTC 2015
[INFO] Final Memory: 23M/180M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 09, 2015 3:38:37 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 09, 2015 3:38:45 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=; SystemID: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/work/~2Fvar~2Flib~2Fjenkins~2Fworkspace~2Fgeoserver-cite~2Ftools~2Fengine~2Fscripts~2Fwcs-1.0.0~2Fctl~2Fwcs.xml/wcs1-0-0$main.test;&gt; Line#: 204; Column#: -1
     [exec]
     [exec] Nov 09, 2015 3:38:45 PM com.occamlab.te.TECore executeTest Test wcs1-0-0:main Failed
     [exec]
     [exec] SEVERE: SaxonApiExceptionSuite wcs1-0-0:main_wcs1-0-0 Failed
     [exec]
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
Total time: 13 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 10017
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/41/&gt;
war:
jar.realm:
compile:
1 warning
jar:
zip.manager.bin:
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO] Total time: 34.548s
[INFO] Finished at: Mon Nov 09 18:08:34 UTC 2015
[INFO] Final Memory: 19M/165M
+ ant clean
clean:
BUILD SUCCESSFUL
+ pushd ..
++ pwd
+ popd
wcs-1.0:
run-test:
     [exec] Nov 09, 2015 6:08:38 PM com.occamlab.te.Generator generateXsl
     [exec] Nov 09, 2015 6:08:45 PM com.occamlab.te.TECore parse
     [exec]
     [exec] Nov 09, 2015 6:08:45 PM com.occamlab.te.TECore executeTest
     [exec] ... 6 more
     [exec] ... 56 more
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 28358
+ '[' 1 == 0 ']'
+ exit 1
See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/42/&gt;
