See <http://ares.boundlessgeo.com/jenkins/job/2.8-cite-wcs-1.0/251/>
[...truncated 2030 lines...]
[exec] VAR_WCS_COVERAGE_1_RESPONSE_CRS: EPSG:4326
[exec] VAR_WCS_FORMAT_1: GeoTIFF
[exec] VAR_WCS_COVERAGE_1_POSITION_FIRST: -19.999999999999996 40.000000000019995
[exec] VAR_WCS_COVERAGE_1_POSITION_SECOND: 19.99999999998401 90.0
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 (wcs-1.0.0/d41e1942_1)...
[exec] Assertion: When a GetCoverage request is made with an invalid RESPONSE_CRS, the server returns service exception.
[exec] VAR_WCS_TEMP_CRS: EPSG:4326
[exec] VAR_WCS_COVERAGE_1_CRS: EPSG:4326
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 (wcs-1.0.0/d41e1959_1)...
[exec] Assertion: When a GetCoverage request is made without version, the server returns service exception.
[exec] VAR_WCS_COVERAGE_1_CRS: You_got_this_because_you_did_not_have_crs_included_in_your_first_domainSet_in_your_first_Coverage
[exec] VAR_WCS_COVERAGE_1_BBOX: ,
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 (wcs-1.0.0/d41e1972_1)...
[exec] Assertion: When a GetCoverage request is made with an invalid version, the server returns service exception.
[exec] VAR_WCS_COVERAGE_1_BBOX: -19.999999999999996,40.000000000019995,19.99999999998401,90.0
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 (wcs-1.0.0/d41e1988_1)...
[exec] Assertion: When a GetCoverage request is made with a version=1.0.0, the server should return the requested content (if other condition satisfied).
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 (wcs-1.0.0/d41e2008_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 (wcs-1.0.0/d41e2029_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 (wcs-1.0.0/d41e2051_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 (wcs-1.0.0/d41e2072_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 (wcs-1.0.0/d41e2093_1)...
[exec] Assertion: When a GetCoverage request is made with a version an invalid version, the server returns service exception.
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d41e2114_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats (wcs-1.0.0/d41e2326_1)...
[exec] Assertion: A valid getCoverage response is returned for each of the supportedFormats.
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads (wcs-1.0.0/d41e2339_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d41e2355_1)...
[exec] Assertion: When a GetCoverage request is made with a BBOX partly contained in the defined Bounding BOX, the server returns content.
[exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP: -21.999999999999996,38.000000000019995,18.99999999998401,89
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d41e2375_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d41e2396_1)...
[exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_FIRST: -21.999999999999996 38.000000000019995
[exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_SECOND: 18.99999999998401 89
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d41e2416_1)...
[exec] Assertion: When a GetCoverage request is made with a BBOX inside the defined Bounding BOX, the server returns content.
[exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE: -18.999999999999996,41.000000000019995,18.99999999998401,89
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d41e2436_1)...
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d41e2457_1)...
[exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_FIRST: -18.999999999999996 41.000000000019995
[exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_SECOND: 18.99999999998401 89
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml Failed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden (wcs-1.0.0/d41e2476_1)...
[exec] Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses resolution parameters to request a coverage that is not at the native resolution returns an exception.
[exec] VAR_WCS_TEMP_RPCRS:
[exec] VAR_WCS_TEMP_INTERPLATION_METHOD: nearest neighbor
[exec] VAR_WCS_INTERPLATION_METHOD: nearest neighbor
[exec] INTERPLATION_METHOD_COUNT: 3
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden (wcs-1.0.0/d41e2494_1)...
[exec] Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses height and width parameters to request a coverage that is not at the native resolution returns an exception.
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions (wcs-1.0.0/d41e2512_1)...
[exec] Assertion: A coverage request using RESX, RESY, RESZ and INTERPOLATION=none raises an exception.
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs (wcs-1.0.0/d41e2531_1)...
[exec] Assertion: A coverage request using RESPONSE_CRS and INTERPOLATION=none raises an exception.
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs Passed
[exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method (wcs-1.0.0/d41e2549_1)...
[exec] Assertion: For each of the advertised interpolation methods, the server returns content.
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method Failed
[exec] Test wcs1-0-0:main Failed (Inherited failure)
[exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
[copy] Copying 1 file to <http://ares.boundlessgeo.com/jenkins/job/2.8-cite-wcs-1.0/ws/tools/users/geoserver/wcs-1.0.0>
BUILD SUCCESSFUL
Total time: 19 seconds
+ ant wcs-1.0-log
+ grep Failed
[exec] Test wcs1-0-0:main (wcs-1.0.0) Failed (Inherited Failure)
[exec] Test wcs1-0-0:basic_service_elements-general_http_request_rules-6 (wcs-1.0.0/d41e596_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-exception-get-kvp-1 (wcs-1.0.0/d41e1415_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-exception-post-kvp-1 (wcs-1.0.0/d41e1451_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-get-kvp-1 (wcs-1.0.0/d41e1599_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-post-kvp-1 (wcs-1.0.0/d41e1619_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-domainsubset-post-xml-rectifiedgrid (wcs-1.0.0/d41e1668_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-post-xml-2 (wcs-1.0.0/d41e1684_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-get-kvp-4 (wcs-1.0.0/d41e1744_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-kvp-4 (wcs-1.0.0/d41e1784_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-xml-4 (wcs-1.0.0/d41e1825_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-2 (wcs-1.0.0/d41e1844_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-2 (wcs-1.0.0/d41e1880_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 (wcs-1.0.0/d41e1920_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 (wcs-1.0.0/d41e1988_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 (wcs-1.0.0/d41e2051_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d41e2114_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d41e2355_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d41e2375_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d41e2396_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d41e2416_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d41e2436_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d41e2457_1) Failed
[exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method (wcs-1.0.0/d41e2549_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.8-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.8-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ ./shutdown.sh
+ sleep 2
2016-06-01 19:32:18.780::INFO: Shutdown hook executing
2016-06-01 19:32:18.782:/geoserver:INFO: Destroying Spring FrameworkServlet 'dispatcher'
2016-06-01 19:32:18.783:/geoserver:INFO: Closing Spring root WebApplicationContext
2016-06-01 19:32:19.328::INFO: Shutdown hook complete
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 5347
PID TTY STAT TIME COMMAND
5347 ? Sl 0:53 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.boundlessgeo.com/jenkins/job/2.8-cite-wcs-1.0/ws/geoserver_data/2.8.x/citewcs-1.0> -Djava.awt.headless=true -Djetty.http.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 5347
+ exit 1
Build step 'Execute shell' marked build as failure
