See <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/43/>
[...truncated 1540 lines...]
[INFO] Executed tasks
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ cite ---
[debug] execute contextualize
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ cite ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.10:test (default-test) @ cite ---
[INFO] No tests to run.
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/surefire-reports>
T E S T S
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ cite ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/cite-1.0.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ cite ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/cite-1.0.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/cite/1.0/cite-1.0.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/cite/1.0/cite-1.0.pom
[INFO] BUILD SUCCESS
[INFO] Total time: 36.145s
[INFO] Finished at: Mon Nov 09 19:28:18 UTC 2015
[INFO] Final Memory: 25M/284M
+ ant clean
Buildfile: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/build.xml>
clean:
BUILD SUCCESSFUL
Total time: 0 seconds
+ pushd ..
~/workspace/geoserver-cite ~/workspace/geoserver-cite/tools ~/workspace/geoserver-cite
++ pwd
+ FORMS=<http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/forms>
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/forms> wcs-1.0
wcs-1.0:
run-test:
[exec] Nov 09, 2015 7:28:21 PM com.occamlab.te.Generator generateXsl
[exec] INFO: Validating <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl>
[exec] INFO: Validating <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl>
[exec] INFO: Validating <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/engine/scripts/wcs-1.0.0/ctl/wcs.xml>
[exec] Checking for <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/forms/wcs-1.0.0.xml>
[exec] Testing suite wcs1-0-0:main_wcs1-0-0...
[exec] Testing wcs1-0-0:main (wcs-1.0.0)...
[exec] Assertion: The WCS 1.0.0 implementation being tested behaves properly
[exec] java.io.FileNotFoundException: http://localhost:11010/geoserver/ows?service=wcs&version=1.0.0&request=GetCapabilities
[exec] Nov 09, 2015 7:28:29 PM com.occamlab.te.TECore parse
[exec] SEVERE: parse Error
[exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1624)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1501)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
[exec] at com.occamlab.te.TECore.request(TECore.java:1123)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[exec] at java.lang.reflect.Method.invoke(Method.java:606)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
[exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
[exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
[exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec]
[exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] Test wcs1-0-0:main Failed
[exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
[exec] Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=; SystemID: <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/target/work/~2Fvar~2Flib~2Fjenkins~2Fworkspace~2Fgeoserver-cite~2Ftools~2Fengine~2Fscripts~2Fwcs-1.0.0~2Fctl~2Fwcs.xml/wcs1-0-0$main.test;> Line#: 204; Column#: -1
[exec] Nov 09, 2015 7:28:29 PM com.occamlab.te.TECore executeTest
[exec] SEVERE: SaxonApiException
[exec] net.sf.saxon.s9api.SaxonApiException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:192)
[exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] ... 6 more
[exec] Caused by: java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] at java.net.URL.<init>(URL.java:585)
[exec] at java.net.URL.<init>(URL.java:482)
[exec] at java.net.URL.<init>(URL.java:431)
[exec] at com.occamlab.te.TECore.build_request(TECore.java:1226)
[exec] at com.occamlab.te.TECore.request(TECore.java:1122)
[exec] ... 56 more
[exec]
[copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/tools/users/geoserver/wcs-1.0.0>
BUILD SUCCESSFUL
Total time: 10 seconds
+ ant wcs-1.0-log
+ grep Failed
[exec] Test wcs1-0-0:main (wcs-1.0.0) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.8-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.8-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-09 19:28:33.372::INFO: Shutdown hook executing
Exception in thread "WeakCollectionCleaner" java.lang.NoClassDefFoundError: Could not initialize class org.apache.log4j.Logger
at org.geotools.util.logging.Log4JLoggerFactory.getImplementation(Log4JLoggerFactory.java:65)
at org.geotools.util.logging.Log4JLoggerFactory.getImplementation(Log4JLoggerFactory.java:33)
at org.geotools.util.logging.LoggerFactory.getLogger(LoggerFactory.java:79)
at org.geotools.util.logging.Logging.getLogger(Logging.java:200)
at org.geotools.util.logging.Logging.getLogger(Logging.java:177)
at org.geotools.util.WeakCollectionCleaner.run(WeakCollectionCleaner.java:104)
java.lang.NoClassDefFoundError: Could not initialize class org.geotools.referencing.factory.DeferredAuthorityFactory
at org.geoserver.GeoserverInitStartupListener.contextDestroyed(GeoserverInitStartupListener.java:267)
at org.mortbay.jetty.handler.ContextHandler.doStop(ContextHandler.java:574)
at org.mortbay.jetty.webapp.WebAppContext.doStop(WebAppContext.java:485)
at org.mortbay.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:64)
at org.mortbay.jetty.handler.HandlerCollection.doStop(HandlerCollection.java:169)
at org.mortbay.jetty.handler.HandlerWrapper.doStop(HandlerWrapper.java:142)
at org.mortbay.jetty.Server.doStop(Server.java:281)
at org.mortbay.jetty.Server$ShutdownHookThread.run(Server.java:559)
2015-11-09 19:28:33.542::INFO: Shutdown hook complete
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 7142
PID TTY STAT TIME COMMAND
7142 ? Sl 0:04 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/2.8-cite-wcs-1.0/ws/geoserver_data/2.8.x/citewcs-1.0> -Djava.awt.headless=true -Djetty.http.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 7142
+ exit 1
Build step 'Execute shell' marked build as failure
