[...truncated 9156 lines...]
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec] Caused by: net.sf.saxon.trans.XPathException: Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
[exec] java.lang.NullPointerException
[exec] at com.occamlab.te.saxon.TEJavaFunctionCall.iterate(TEJavaFunctionCall.java:148)
[exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
[exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
[exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
[exec] at net.sf.saxon.expr.LazyExpression.evaluateItem(LazyExpression.java:86)
[exec] at net.sf.saxon.value.SingletonClosure.asItem(SingletonClosure.java:75)
[exec] at net.sf.saxon.value.Value.asItem(Value.java:69)
[exec] at net.sf.saxon.expr.VariableReference.evaluateItem(VariableReference.java:421)
[exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
[exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
[exec] at net.sf.saxon.instruct.ElementCreator.processLeavingTail(ElementCreator.java:298)
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.ExpressionTool.lazyEvaluate(ExpressionTool.java:431)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:144)
[exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
[exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
[exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] ... 190 more
[exec] Caused by: java.lang.NullPointerException
[exec] at java.net.URLEncoder.encode(URLEncoder.java:205)
[exec] at java.net.URLEncoder.encode(URLEncoder.java:171)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[exec] at java.lang.reflect.Method.invoke(Method.java:606)
[exec] at com.occamlab.te.saxon.TEJavaFunctionCall.iterate(TEJavaFunctionCall.java:138)
[exec] ... 229 more
[exec]
[copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.8-cite-wms-1.1/ws/tools/users/geoserver/wms-1.1.1>
BUILD SUCCESSFUL
Total time: 21 seconds
+ ant wms-1.1-log
+ grep Failed
[exec] Test wms:wms_main (wms-1.1.1) Failed (Inherited Failure)
[exec] Test wms:basic_elements-param_rules-order_and_case-3 (wms-1.1.1/d247e766_1) Failed
[exec] Test wms:basic_elements-version-negotiation-2 (wms-1.1.1/d247e804_1) Failed
[exec] Test wms:basic_elements-version-negotiation-4 (wms-1.1.1/d247e811_1) Failed
[exec] Test wms:dims-declaring-1 (wms-1.1.1/d247e820_1) Failed
[exec] Test wms:dims-declaring-3 (wms-1.1.1/d247e828_1) Failed
[exec] Test wms:dims-declaring-4 (wms-1.1.1/d247e835_1) Failed
[exec] Test wms:profiles-queryable-1 (wms-1.1.1/d247e865_1) Failed
[exec] Test wms:profiles-queryable-2 (wms-1.1.1/d247e875_1) Failed
[exec] Test wms:profiles-queryable-3 (wms-1.1.1/d247e885_1) Failed
[exec] Test wms:wmsops-getcapabilities-output_formats-1 (wms-1.1.1/d247e895_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-request-1 (wms-1.1.1/d247e902_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-updatesequence-1 (wms-1.1.1/d247e912_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-version-1 (wms-1.1.1/d247e981_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-version-2 (wms-1.1.1/d247e988_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-version-3 (wms-1.1.1/d247e995_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-version-4 (wms-1.1.1/d247e1002_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-version-5 (wms-1.1.1/d247e1009_1) Failed
[exec] Test wms:wmsops-getcapabilities-params-version-6 (wms-1.1.1/d247e1016_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-1 (wms-1.1.1/d247e1024_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-2 (wms-1.1.1/d247e1031_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-capability_metadata-1 (wms-1.1.1/d247e1038_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-capability_metadata-2 (wms-1.1.1/d247e1047_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-general_metadata-1 (wms-1.1.1/d247e1055_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-general_metadata-2 (wms-1.1.1/d247e1064_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-bbox-1 (wms-1.1.1/d247e1073_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-1 (wms-1.1.1/d247e1080_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-2 (wms-1.1.1/d247e1087_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1 (wms-1.1.1/d247e1094_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2 (wms-1.1.1/d247e1101_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-1 (wms-1.1.1/d247e1108_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-2 (wms-1.1.1/d247e1116_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-srs-1 (wms-1.1.1/d247e1123_1) Failed
[exec] Test wms:wmsops-getcapabilities-response-layer_properties-style-1 (wms-1.1.1/d247e1130_1) Failed
[exec] Test wms:wmsops-getmap-params-exceptions-1 (wms-1.1.1/d247e1541_1) Failed
[exec] Test wms:wmsops-getmap-params-exceptions-2 (wms-1.1.1/d247e1550_1) Failed
[exec] Test wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d247e1706_1) Failed
[exec] Test wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d247e2131_1) Failed
[exec] Test wms:basic_elements-validate-exception (wms-1.1.1/d247e2137_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.8-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.8-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-09 19:32:09.966::INFO: Shutdown hook executing
Exception in thread "WeakCollectionCleaner" java.lang.NoClassDefFoundError: Could not initialize class org.apache.log4j.Logger
at org.geotools.util.logging.Log4JLoggerFactory.getImplementation(Log4JLoggerFactory.java:65)
at org.geotools.util.logging.Log4JLoggerFactory.getImplementation(Log4JLoggerFactory.java:33)
at org.geotools.util.logging.LoggerFactory.getLogger(LoggerFactory.java:79)
at org.geotools.util.logging.Logging.getLogger(Logging.java:200)
at org.geotools.util.logging.Logging.getLogger(Logging.java:177)
at org.geotools.util.WeakCollectionCleaner.run(WeakCollectionCleaner.java:104)
java.lang.NoClassDefFoundError: Could not initialize class org.geotools.referencing.factory.DeferredAuthorityFactory
at org.geoserver.GeoserverInitStartupListener.contextDestroyed(GeoserverInitStartupListener.java:267)
at org.mortbay.jetty.handler.ContextHandler.doStop(ContextHandler.java:574)
at org.mortbay.jetty.webapp.WebAppContext.doStop(WebAppContext.java:485)
at org.mortbay.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:64)
at org.mortbay.jetty.handler.HandlerCollection.doStop(HandlerCollection.java:169)
at org.mortbay.jetty.handler.HandlerWrapper.doStop(HandlerWrapper.java:142)
at org.mortbay.jetty.Server.doStop(Server.java:281)
at org.mortbay.jetty.Server$ShutdownHookThread.run(Server.java:559)
2015-11-09 19:32:09.150::INFO: Shutdown hook complete
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
[...truncated 9155 lines...]
[exec] ... 190 more
[exec] ... 229 more
[exec]
[exec] Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
[exec] Test wms:basic_elements-validate-exception Failed
[exec] Test wms:wms_main Failed (Inherited failure)
[exec] Suite wms:main_wms Failed
BUILD SUCCESSFUL
+ grep Failed
+ ant wms-1.1-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-10 20:19:30.698::INFO: Shutdown hook executing
2015-11-10 20:19:30.881::INFO: Shutdown hook complete
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
Total time: 19 seconds
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-11 21:04:05.664::INFO: Shutdown hook executing
2015-11-11 21:04:05.730::INFO: Shutdown hook complete
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-12 19:46:41.373::INFO: Shutdown hook executing
2015-11-12 19:46:41.542::INFO: Shutdown hook complete
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-13 19:20:05.975::INFO: Shutdown hook executing
2015-11-13 19:20:05.141::INFO: Shutdown hook complete
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-14 21:49:04.666::INFO: Shutdown hook executing
2015-11-14 21:49:04.750::INFO: Shutdown hook complete
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-15 20:26:51.544::INFO: Shutdown hook executing
2015-11-15 20:26:51.713::INFO: Shutdown hook complete
[...truncated 9157 lines...]
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
Total time: 20 seconds
+ grep Failed
+ ant wms-1.1-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-16 22:03:08.085::INFO: Shutdown hook executing
2015-11-16 22:03:08.251::INFO: Shutdown hook complete
[exec] ... 190 more
[exec] ... 229 more
[exec]
BUILD SUCCESSFUL
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
2015-11-17 19:19:45.042::INFO: Shutdown hook executing
2015-11-17 19:19:46.222::INFO: Shutdown hook complete
