[Geoserver-devel] Build failed in Jenkins: cite-wcs-1.0 #181
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/181/&gt;
[...truncated 2504 lines...]
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.callTest(TECore.java:586)
     [exec] at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
     [exec] at java.lang.reflect.Method.invoke(Method.java:597)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
     [exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
     [exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
     [exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
     [exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
     [exec] at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:625)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] net.sf.saxon.trans.XPathException: org.xml.sax.SAXParseException: Content is not allowed in prolog.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d41e2114_1)...
     [exec] Assertion: When a GetCoverage request is made with a version=1.0.0, the server should return the requested content (if other condition satisfied).
     [exec] VAR_WCS_TEMP_CRS: EPSG:4326
     [exec] VAR_WCS_COVERAGE_1_CRS: EPSG:4326
     [exec] VAR_WCS_FORMAT_1: GeoTIFF
     [exec] VAR_WCS_COVERAGE_1_POSITION_FIRST: -19.999999999999996 40.000000000019995
     [exec] VAR_WCS_COVERAGE_1_POSITION_SECOND: 19.99999999998401 90.0
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats (wcs-1.0.0/d41e2326_1)...
     [exec] Assertion: A valid getCoverage response is returned for each of the supportedFormats.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads (wcs-1.0.0/d41e2339_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d41e2355_1)...
     [exec] Assertion: When a GetCoverage request is made with a BBOX partly contained in the defined Bounding BOX, the server returns content.
     [exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP: -21.999999999999996,38.000000000019995,18.99999999998401,89
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d41e2375_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d41e2396_1)...
     [exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_FIRST: -21.999999999999996 38.000000000019995
     [exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_SECOND: 18.99999999998401 89
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d41e2416_1)...
     [exec] Assertion: When a GetCoverage request is made with a BBOX inside the defined Bounding BOX, the server returns content.
     [exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE: -18.999999999999996,41.000000000019995,18.99999999998401,89
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d41e2436_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d41e2457_1)...
     [exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_FIRST: -18.999999999999996 41.000000000019995
     [exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_SECOND: 18.99999999998401 89
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden (wcs-1.0.0/d41e2476_1)...
     [exec] Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses resolution parameters to request a coverage that is not at the native resolution returns an exception.
     [exec] VAR_WCS_TEMP_RPCRS:
     [exec] VAR_WCS_COVERAGE_1_RESPONSE_CRS: EPSG:4326
     [exec] VAR_WCS_COVERAGE_1_BBOX: -19.999999999999996,40.000000000019995,19.99999999998401,90.0
     [exec] VAR_WCS_TEMP_INTERPLATION_METHOD: nearest neighbor
     [exec] VAR_WCS_INTERPLATION_METHOD: nearest neighbor
     [exec] INTERPLATION_METHOD_COUNT: 3
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden (wcs-1.0.0/d41e2494_1)...
     [exec] Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses height and width parameters to request a coverage that is not at the native resolution returns an exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions (wcs-1.0.0/d41e2512_1)...
     [exec] Assertion: A coverage request using RESX, RESY, RESZ and INTERPOLATION=none raises an exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs (wcs-1.0.0/d41e2531_1)...
     [exec] Assertion: A coverage request using RESPONSE_CRS and INTERPOLATION=none raises an exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method (wcs-1.0.0/d41e2549_1)...
     [exec] Assertion: For each of the advertised interpolation methods, the server returns content.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method Passed
     [exec] Test wcs1-0-0:main Failed (Inherited failure)
     [exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/tools/users/geoserver/wcs-1.0.0&gt;
BUILD SUCCESSFUL
Total time: 27 seconds
+ ant wcs-1.0-log
+ grep Failed
     [exec] Test wcs1-0-0:main (wcs-1.0.0) Failed (Inherited Failure)
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-xml-1 (wcs-1.0.0/d41e792_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 (wcs-1.0.0/d41e2072_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 (wcs-1.0.0/d41e2093_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.6-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.6-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 12143
  PID TTY STAT TIME COMMAND
12143 ? Sl 0:56 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 12143
+ exit 1
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/182/&gt;
[...truncated 2500 lines...]
BUILD SUCCESSFUL
Total time: 24 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 29810
29810 ? Sl 0:58 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 29810
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/183/&gt;
[...truncated 2490 lines...]
BUILD SUCCESSFUL
Total time: 25 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 2963
2963 ? Sl 0:54 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 2963
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/184/&gt;
BUILD SUCCESSFUL
Total time: 26 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 4553
4553 ? Sl 0:52 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 4553
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/185/&gt;
[...truncated 2489 lines...]
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.0-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 9472
9472 ? Sl 0:53 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 9472
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/186/&gt;
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 2011
2011 ? Sl 0:52 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 2011
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/187/&gt;
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 28488
28488 ? Sl 0:54 /usr/lib/jvm/java-6-sun/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 28488
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/188/&gt;
[...truncated 2517 lines...]
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:606)
     [exec]
BUILD SUCCESSFUL
Total time: 28 seconds
+ grep Failed
+ ant wcs-1.0-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 7716
7716 ? Sl 1:04 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 7716
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/189/&gt;
[...truncated 2508 lines...]
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 20723
20723 ? Sl 1:00 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 20723
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/190/&gt;
[...truncated 2530 lines...]
     [exec]
BUILD SUCCESSFUL
Total time: 29 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 21387
21387 ? Sl 1:02 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 21387
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/191/&gt;
[...truncated 2519 lines...]
     [exec]
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.0-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 11532
11532 ? Sl 1:04 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 11532
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/192/&gt;
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 2339
2339 ? Sl 1:04 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 2339
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/193/&gt;
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 1265
1265 ? Sl 1:01 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 1265
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/194/&gt;
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 27727
27727 ? Sl 1:01 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 27727
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/195/&gt;
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 29699
29699 ? Sl 1:04 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 29699
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/196/&gt;
[...truncated 2662 lines...]
     [exec]
BUILD SUCCESSFUL
Total time: 59 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 2178
2178 ? Sl 1:02 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 2178
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/197/&gt;
     [exec]
BUILD SUCCESSFUL
Total time: 30 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 10100
10100 ? Sl 1:01 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 10100
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/198/&gt;
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 541
  541 ? Sl 1:05 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 541
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/199/&gt;
[...truncated 2539 lines...]
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 14675
14675 ? Sl 1:10 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 14675
+ exit 1
See <http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/200/&gt;
[...truncated 2552 lines...]
     [exec]
BUILD SUCCESSFUL
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 17960
17960 ? Sl 1:15 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/cite-wcs-1.0/ws/geoserver_data/master/citewcs-1.0&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 17960
+ exit 1
