[...truncated 3125 lines...]
[exec] at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[exec] at java.lang.reflect.Method.invoke(Method.java:597)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
[exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
[exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
[exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:625)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.callTest(TECore.java:586)
[exec] at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
[exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
[exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
[exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
[exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
[exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] Fatal Parsing error at line 1, column 1:
[exec] Content is not allowed in prolog.
[exec] 1 validation error detected.
[exec]
[exec] Test wcs:GetCoverage_Store_Bogus Passed
[exec] Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12687_1)...
[exec] Assertion: Verify that when a GetCoverage request with a store parameter
[exec] set to a bogus value is submitted, the response is an exception.
[exec] Using XML encoding.
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec] Test wcs:GetCoverage-main Passed
[exec] Test wcs:Main Failed (Inherited failure)
[exec] Suite wcs:suite Failed
[copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/cite-wcs-1.1/ws/tools/users/geoserver/wcs-1.1.1>
BUILD SUCCESSFUL
Total time: 1 minute 42 seconds
+ ant wcs-1.1-log
+ grep Failed
[exec] Test wcs:Main (wcs-1.1.1) Failed (Inherited Failure)
[exec] Test wcs:DescribeCoverage-main (wcs-1.1.1/d41e334_1) Failed (Inherited Failure)
[exec] Test wcs:DescribeCoverage_MissingVersion (wcs-1.1.1/d41e334_1/d41e6940_1) Failed
[exec] Test wcs:DescribeCoverage_MissingIdentifier (wcs-1.1.1/d41e334_1/d41e7010_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.6-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.6-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
[...truncated 3145 lines...]
[exec] at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:124)
[exec] at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:223)
[exec] at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:170)
[exec] at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1549)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
[exec] at com.occamlab.te.TECore.request(TECore.java:1123)
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.1-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3133 lines...]
BUILD SUCCESSFUL
Total time: 1 minute 39 seconds
+ grep Failed
+ ant wcs-1.1-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
BUILD SUCCESSFUL
Total time: 1 minute 44 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
BUILD SUCCESSFUL
+ grep Failed
+ ant wcs-1.1-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3155 lines...]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3152 lines...]
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[exec] at java.lang.reflect.Method.invoke(Method.java:606)
[exec]
[exec]
BUILD SUCCESSFUL
Total time: 1 minute 48 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3185 lines...]
[exec]
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3164 lines...]
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551) Content is not allowed in prolog.
[exec]
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)1 validation error detected.
[exec]
[exec]
[exec]
BUILD SUCCESSFUL
Total time: 1 minute 47 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3174 lines...]
[exec]
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3252 lines...]
[exec]
BUILD SUCCESSFUL
Total time: 2 minutes 19 seconds
+ grep Failed
+ ant wcs-1.1-log
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
BUILD SUCCESSFUL
Total time: 1 minute 46 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3163 lines...]
[exec]
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[...truncated 3196 lines...]
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175) Test wcs:GetCoverage_Store_Bogus Passed
[exec]
[exec] Assertion: Verify that when a GetCoverage request with a store parameter at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec]
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551) Using XML encoding.
[exec]
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
[exec]
BUILD SUCCESSFUL
Total time: 1 minute 50 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
[exec]
BUILD SUCCESSFUL
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
