[Geoserver-devel] Build failed in Jenkins: geofence-master #42
See <http://ares.boundlessgeo.com/jenkins/job/geofence-master/42/changes&gt;
Changes:
[afabiani] - gitignore
[afabiani] - poms cleanup
[...truncated 1243 lines...]
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
  at org.junit.rules.TestWatcher$1.evaluate(TestWatcher.java:55)
  at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:264)
  at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:153)
  at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:124)
  at org.apache.maven.surefire.booter.ForkedBooter.invokeProviderInSameClassLoader(ForkedBooter.java:200)
  at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:153)
  at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:103)
testAttributeNullAccessType(org.geoserver.geofence.core.dao.RuleDAOTest) Time elapsed: 0.005 sec <<< ERROR!
java.lang.NoSuchMethodError: org.hibernate.metadata.ClassMetadata.getIdentifier(Ljava/lang/Object;Lorg/hibernate/engine/spi/SessionImplementor;)Ljava/io/Serializable;
  at com.googlecode.genericdao.search.hibernate.HibernateEntityMetadata.getIdValue(HibernateEntityMetadata.java:58)
  at com.googlecode.genericdao.search.hibernate.HibernateMetadataUtil.getId(HibernateMetadataUtil.java:63)
  at com.googlecode.genericdao.dao.jpa.JPABaseDAO._removeEntity(JPABaseDAO.java:143)
  at com.googlecode.genericdao.dao.jpa.GenericDAOImpl.remove(GenericDAOImpl.java:85)
  at org.geoserver.geofence.core.dao.impl.UserGroupDAOImpl.remove(UserGroupDAOImpl.java:68)
  at org.geoserver.geofence.core.dao.impl.UserGroupDAOImpl.remove(UserGroupDAOImpl.java:27)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
  at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:99)
  at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281)
  at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
  at com.sun.proxy.$Proxy54.remove(Unknown Source)
  at org.geoserver.geofence.core.dao.BaseDAOTest.removeAllUserGroups(BaseDAOTest.java:137)
  at org.geoserver.geofence.core.dao.BaseDAOTest.removeAll(BaseDAOTest.java:97)
  at org.geoserver.geofence.core.dao.BaseDAOTest.setUp(BaseDAOTest.java:80)
  at sun.reflect.GeneratedMethodAccessor27.invoke(Unknown Source)
testPersistLayerDetails(org.geoserver.geofence.core.dao.RuleDAOTest) Time elapsed: 0.005 sec <<< ERROR!
testCheckDAOs(org.geoserver.geofence.core.dao.RuleDAOTest) Time elapsed: 0.005 sec <<< ERROR!
Running org.geoserver.geofence.core.dao.util.PwEncoderTest
ENC --> w0kbcNE5tucahe57M5xelQ==
DEC --> test
ENC --> adGPwB49R5oshn4dZbNbww==
DEC --> topolino
ENC --> Gl8KyLAjEnA1CL0UUg1NOQ==
DEC -->
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.183 sec - in org.geoserver.geofence.core.dao.util.PwEncoderTest
Results :
Tests in error:
  UserDAOTest>BaseDAOTest.setUp:80->BaseDAOTest.removeAll:97->BaseDAOTest.removeAllUserGroups:137 » NoSuchMethod
  RuleDAOTest>BaseDAOTest.setUp:80->BaseDAOTest.removeAll:97->BaseDAOTest.removeAllUserGroups:137 » NoSuchMethod
Tests run: 22, Failures: 0, Errors: 15, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] Master GeoFence POM ................................ SUCCESS [ 0.297 s]
[INFO] GeoFence - 0 Services .............................. SUCCESS [ 0.138 s]
[INFO] GeoFence - Core .................................... SUCCESS [ 0.009 s]
[INFO] GeoFence - Core - Model internal ................... SUCCESS [ 7.360 s]
[INFO] GeoFence - Core - Model external ................... SUCCESS [ 5.362 s]
[INFO] GeoFence - Core - Persistence ...................... FAILURE [ 25.034 s]
[INFO] GeoFence - Core - Services API ..................... SKIPPED
[INFO] GeoFence - Core - Services implementation .......... SKIPPED
[INFO] GeoFence - Core - Web Test Module .................. SKIPPED
[INFO] GeoFence - Modules - 0 Root ........................ SKIPPED
[INFO] GeoFence - Module - Generic API .................... SKIPPED
[INFO] GeoFence - Modules - Login ......................... SKIPPED
[INFO] GeoFence - Modules - Login - API ................... SKIPPED
[INFO] GeoFence - Modules - Login - Impl .................. SKIPPED
[INFO] GeoFence - Modules - REST root ..................... SKIPPED
[INFO] GeoFence - Modules - REST API ...................... SKIPPED
[INFO] GeoFence - Modules - REST services implementation .. SKIPPED
[INFO] GeoFence - Modules - REST services test ............ SKIPPED
[INFO] GeoFence - Modules - REST client ................... SKIPPED
[INFO] GeoFence - Module - LDAP Support ................... SKIPPED
[INFO] GeoFence - GUI ..................................... SKIPPED
[INFO] GeoFence - GUI - Core .............................. SKIPPED
[INFO] GeoFence - GUI - Resources ......................... SKIPPED
[INFO] GeoFence - GUI - Plugin module ..................... SKIPPED
[INFO] GeoFence - GUI - User plugin ....................... SKIPPED
[INFO] GeoFence - GUI - Map plugin ........................ SKIPPED
[INFO] GeoFence - GUI - Web ............................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 40.281 s
[INFO] Finished at: 2016-07-14T17:29:23+00:00
[INFO] Final Memory: 30M/408M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.17:test (default-test) on project geofence-persistence: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/services/core/persistence/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :geofence-persistence
See <http://ares.boundlessgeo.com/jenkins/job/geofence-master/43/changes&gt;
