[Geoserver-devel] Build failed in Jenkins: geofence-master #56
See <http://ares.boundlessgeo.com/jenkins/job/geofence-master/56/changes&gt;
Changes:
[etj] Improve LDAP support (#82). Externalize DB/LDAP selection. Add caching
[etj] GUI: Sort users and groups in rule editor. Fix LDAP cache expire unit.
[etj] Version 3.3-SNAPSHOT
[etj] Release 3.3.0
Started by an SCM change
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geofence.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geofence.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geofence.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 0323e5727d364d82bda466beeb4505a02c24920a (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 0323e5727d364d82bda466beeb4505a02c24920a
> git rev-list 6492d3fc528864228aa1b4891f81a2c90c85ccc6 # timeout=10
[geofence-master] $ /opt/apache-maven-3.2.5/bin/mvn -f src/pom.xml -Dhudson.buildId=56 -U clean install
[INFO] Scanning for projects...
[INFO] Reactor Build Order:
[INFO]
[INFO] Master GeoFence POM
[INFO] GeoFence - 0 Services
[INFO] GeoFence - Core
[INFO] GeoFence - Core - Model internal
[INFO] GeoFence - Core - Model external
[INFO] GeoFence - Core - Persistence
[INFO] GeoFence - Core - Services API
[INFO] GeoFence - Core - Services implementation
[INFO] GeoFence - Core - Web Test Module
[INFO] GeoFence - Modules - 0 Root
[INFO] GeoFence - Module - Generic API
[INFO] GeoFence - Modules - Login
[INFO] GeoFence - Modules - Login - API
[INFO] GeoFence - Modules - Login - Impl
[INFO] GeoFence - Modules - REST root
[INFO] GeoFence - Modules - REST API
[INFO] GeoFence - Modules - REST services implementation
[INFO] GeoFence - Modules - REST services test
[INFO] GeoFence - Modules - REST client
[INFO] GeoFence - Module - LDAP Support
[INFO] GeoFence - GUI
[INFO] GeoFence - GUI - Core
[INFO] GeoFence - GUI - Resources
[INFO] GeoFence - GUI - Plugin module
[INFO] GeoFence - GUI - User plugin
[INFO] GeoFence - GUI - Map plugin
[INFO] GeoFence - GUI - Web
[INFO]
[INFO] Building Master GeoFence POM 3.3-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ geofence ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geofence ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence/3.3-SNAPSHOT/geofence-3.3-SNAPSHOT.pom
[INFO]
[INFO] Building GeoFence - 0 Services 3.3-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ geofence-root ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geofence-root ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/services/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-root/3.3-SNAPSHOT/geofence-root-3.3-SNAPSHOT.pom
[INFO]
[INFO] Building GeoFence - Core 3.3-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ geofence-core ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geofence-core ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/services/core/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-core/3.3-SNAPSHOT/geofence-core-3.3-SNAPSHOT.pom
[INFO]
[INFO] Building GeoFence - Core - Model internal 3.3-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ geofence-model-internal ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/services/core/model/target&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ geofence-model-internal ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/services/core/model/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ geofence-model-internal ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 43 source files to <http://ares.boundlessgeo.com/jenkins/job/geofence-master/ws/src/services/core/model/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] javac: invalid target release: 1.8
Usage: javac <options> <source files>
use -help for a list of possible options
[INFO] 1 error
[INFO] Reactor Summary:
[INFO]
[INFO] Master GeoFence POM ................................ SUCCESS [ 0.305 s]
[INFO] GeoFence - 0 Services .............................. SUCCESS [ 0.132 s]
[INFO] GeoFence - Core .................................... SUCCESS [ 0.008 s]
[INFO] GeoFence - Core - Model internal ................... FAILURE [ 0.959 s]
[INFO] GeoFence - Core - Model external ................... SKIPPED
[INFO] GeoFence - Core - Persistence ...................... SKIPPED
[INFO] GeoFence - Core - Services API ..................... SKIPPED
[INFO] GeoFence - Core - Services implementation .......... SKIPPED
[INFO] GeoFence - Core - Web Test Module .................. SKIPPED
[INFO] GeoFence - Modules - 0 Root ........................ SKIPPED
[INFO] GeoFence - Module - Generic API .................... SKIPPED
[INFO] GeoFence - Modules - Login ......................... SKIPPED
[INFO] GeoFence - Modules - Login - API ................... SKIPPED
[INFO] GeoFence - Modules - Login - Impl .................. SKIPPED
[INFO] GeoFence - Modules - REST root ..................... SKIPPED
[INFO] GeoFence - Modules - REST API ...................... SKIPPED
[INFO] GeoFence - Modules - REST services implementation .. SKIPPED
[INFO] GeoFence - Modules - REST services test ............ SKIPPED
[INFO] GeoFence - Modules - REST client ................... SKIPPED
[INFO] GeoFence - Module - LDAP Support ................... SKIPPED
[INFO] GeoFence - GUI ..................................... SKIPPED
[INFO] GeoFence - GUI - Core .............................. SKIPPED
[INFO] GeoFence - GUI - Resources ......................... SKIPPED
[INFO] GeoFence - GUI - Plugin module ..................... SKIPPED
[INFO] GeoFence - GUI - User plugin ....................... SKIPPED
[INFO] GeoFence - GUI - Map plugin ........................ SKIPPED
[INFO] GeoFence - GUI - Web ............................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3.125 s
[INFO] Finished at: 2017-01-26T00:57:31+00:00
[INFO] Final Memory: 19M/230M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project geofence-model-internal: Compilation failure
[ERROR] Usage: javac <options> <source files>
[ERROR] use -help for a list of possible options
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :geofence-model-internal
See <http://ares.boundlessgeo.com/jenkins/job/geofence-master/57/changes&gt;
