[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #112
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/112/changes&gt;
Changes:
[gabriel.roldan] Update geogig plugin with latest functional test changes.
[...truncated 14886 lines...]
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-jms-geoserver ---
[INFO] Copying 0 resource
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-jms-geoserver ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/classes&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.725 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.727 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.998 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.512 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.484 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.225 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 5.770 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.410 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.294 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.899 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 24.506 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.442 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.477 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.425 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.206 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.682 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [02:09 min]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.065 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.463 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.970 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.090 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.198 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.806 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.471 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.811 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 8.204 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.048 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.525 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.597 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.431 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.260 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 6.561 s]
[INFO] GeoFence Server .................................... SUCCESS [ 7.983 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.672 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.569 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.700 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.946 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.520 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.969 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.696 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.819 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.044 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 7.507 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.132 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.735 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.155 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.574 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 11.548 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.093 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.601 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.604 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.034 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.451 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.411 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.496 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.515 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.410 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.126 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 4.703 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:18 min (Wall Clock)
[INFO] Finished at: 2016-12-15T19:07:49+00:00
[INFO] Final Memory: 135M/408M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[406,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[411,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[421,1\] error: method does not override or implement a method from a supertype
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/113/changes&gt;
