See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/19/changes>
Changes:
[ridethepenguin] [GEOT-5526] SQL Encoding of Filters on Nested Attributes
[afabiani] JIRA GEOS-7802 - Add a URL Mangler injecting Bearer type access tokens
[...truncated 17342 lines...]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/classes>
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [408 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.war
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.119 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.951 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.470 s]
[INFO] Main Module ........................................ SUCCESS [02:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.076 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.754 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:52 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.174 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.889 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.864 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 51.754 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.424 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.956 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:17 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.071 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.994 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.742 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.886 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.824 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.463 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:48 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:11 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.634 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.201 s]
[INFO] Printing Module .................................... SUCCESS [ 13.513 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.788 s]
[INFO] Community Space .................................... SUCCESS [ 0.072 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 4.761 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.995 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.279 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.279 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.072 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.462 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.248 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.241 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.548 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.993 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.289 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.038 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.030 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.867 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:35 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.281 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.674 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.499 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.984 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.998 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.819 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.184 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.900 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.620 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.117 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.420 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.212 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.063 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.218 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.049 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.477 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.585 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.694 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.289 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.074 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.163 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.643 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.269 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.294 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.026 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.110 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.991 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.039 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.109 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.908 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.025 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.074 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.331 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 45.858 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.054 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.564 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.955 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.555 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.135 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:07 min (Wall Clock)
[INFO] Finished at: 2016-10-25T17:53:45+00:00
[INFO] Final Memory: 116M/396M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-app-schema-test: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[51,24\] error: cannot find symbol
[ERROR] package org.geotools.jdbc
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[693,14\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[34,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[23,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[24,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>:\[27,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[23,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[677,44\] error: cannot find symbol
[ERROR] class AppSchemaDataAccessConfigurator
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[711,8\] error: cannot find symbol
[ERROR] class AbstractAppSchemaTestSupport
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[711,50\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1405,8\] error: cannot find symbol
[ERROR] class FeatureChainingWfsTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1434,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1460,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1478,47\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1480,55\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1491,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1515,23\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1521,51\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[759,19\] error: cannot find symbol
[ERROR] class PolymorphismWfsTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[784,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[809,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[811,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[419,8\] error: cannot find symbol
[ERROR] class SimpleAttributeFeatureChainWfsTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[444,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[477,20\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[504,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[531,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[565,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>:\[258,19\] error: cannot find symbol
[ERROR] class SRSReprojectionTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[118,8\] error: cannot find symbol
[ERROR] class NestedIdSupportTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[145,19\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
